Author Topic: mouse position  (Read 2371 times)
jsr
mouse position
« on: January 01, 2011, 01:45:16 AM »
Hi All
How can we get the current position of mouse using dot NET, in lisp we have grread. Is this function available in dot NET. inside PointMonitor event handler we can use args.Context.ComputedPoint but without hooking into that event can we get mouse position.
Thanks.
Re: mouse position
« Reply #1 on: January 01, 2011, 04:14:13 AM »
I'm wondering why you don't want to use PointMonitor ?
but anyway,
http://www.theswamp.org/index.php?topic=25760.msg310498#msg310498
