Author Topic: regeneration problem  (Read 4426 times)
ELOQUINTET
« on: January 11, 2005, 10:04:16 AM »
hey guys i have a coworker who's drawings take forever to regen when opening and switching layouts. it says please wait formatting text in the bottom left hand corner and he's using alot of hatch. it regens fine on his computer but everybody else has problems. can you guys give it a look and tell me what you think the problem is so i can hopefully remedy the situation.
http://theswamp.org/lilly_pond/dan/Glass%20Panels%20and%20Cladding%20At%20Elevator%20Lobby_recover.dwg?nossi=1
« Reply #1 on: January 11, 2005, 10:27:09 AM »
Dan,
Works fine here. Probably a truetype font....I noticed that there are many loaded in the drawing. I'm thinking the font that is slowing you down isn't on my machine. That's why I see no effect in my performance.
Try this one:
http://theswamp.org/lilly_pond/ronjonp/Glass%20Panels%20and%20Cladding%20At%20Elevator%20Lobby_recover.dwg?nossi=1
Ron
« Reply #2 on: January 11, 2005, 10:29:27 AM »
I did not download the file, but I can tell you that the problem you describe is associated with mtext and true type fonts. I personally avoid TTF as much as I can, and when you get large blocks of mtext, particularly when there are multiple mtext blocks, it tends to drag the system down.
ELOQUINTET
« Reply #3 on: January 11, 2005, 10:40:18 AM »
i couldn't open ron you are using 2005. i need more folks to try it out
ELOQUINTET
« Reply #4 on: January 11, 2005, 10:41:00 AM »
by the way what did you do to the changes file you wanted me to try?
ELOQUINTET
« Reply #5 on: January 11, 2005, 10:42:52 AM »
that's what i was thinking too keith i've experienced that in the past too. how do i find out if ttf's are being used and convert them?
« Reply #6 on: January 11, 2005, 10:43:36 AM »
Dan,
Download again and try opening it now.
Ron
ELOQUINTET
« Reply #7 on: January 11, 2005, 10:50:00 AM »
that's it ron. it still takes a bit longer than mine to regen but i guess that due to the hatch but no more text message at bottom. how did you do it, do tell?
« Reply #8 on: January 11, 2005, 10:54:18 AM »
It's one of your fonts. I filtered out all the text in the drawing and changed it to romans.
Ron
ELOQUINTET
« Reply #9 on: January 11, 2005, 11:01:23 AM »
ummm could you ellaborate a little more. i've never used the filter command.
how do i filter it out and change it to romans. better yet how do i figure out which is the problem font and annihilate it  :twisted:
« Reply #10 on: January 11, 2005, 11:18:05 AM »
Dan,
To filter objects:
Command filter.
In the dialogue box use Select Filter pulldown and scroll down to text.
Then push Add to List button. Apply and select all. Now all the text entities are selected and you can manipulate their style through the properties dialogue.
The only way I know of to find the "evil font" is process of elimination and testing regen time after changing each font style to a non TTF.
HTH
Ron
ELOQUINTET
« Reply #11 on: January 11, 2005, 11:42:05 AM »
i'm sorry ron but i followed your instructions but i don't see where i can manipulate the style in the properties dialogue. when i select the objects they do not become highlighted. am i missing something?
Command: filter
Applying filter to selection.
Select objects: all
7760 found
7760 were filtered out.
Select objects: *Cancel*
« Reply #12 on: January 11, 2005, 12:35:08 PM »
Sorry Dan....I cheated a little  :oops: Once every thing was selected I exploded the mtext so all text would be single line.
You can use these filters (paste them into the command line) to separate the two:
(setq s1 (ssget "x"'((0 . "MText"))))
(setq s1 (ssget "x"'((0 . "Text"))))
Or you can use qselect.
Ron
ELOQUINTET
« Reply #13 on: January 11, 2005, 03:16:53 PM »
i never got this resolved and they told me i couldn't spend anymore time on it as it wasn't that important. (short term thinking)  :roll:
« Reply #14 on: January 11, 2005, 03:25:49 PM »
Dan,
Instead of using filter you could just bring up the text style dialogue and change each style name in the drawing to point to romans.shx until the drawing regened without scanning.
Ron
ELOQUINTET
« Reply #15 on: January 11, 2005, 04:23:33 PM »
ok ron i'll get to it when it really pisses me off and i can no longer tolerate it anymore. right now i'm just too swamped (or deswamped rather)
