Author Topic: Question about selecting an object from a point  (Read 5481 times)
Brick_top
« on: December 28, 2010, 06:02:12 AM »
I'm trying to select an object from a selected point, I'm able to do it but only if the object is on screen
Here is the code
(defun c:bd ()
   (setq pt1 (getpoint "\nPonto para detectar ilha:")
         pre 0.0001
         xpt1 (car pt1)
         ypt1 (cadr pt1)
         ss1 nil
   (while
          (= (setq ss1 (ssget (list xpt1 ypt1))) nil)
              (setq xpt1 (- xpt1 pre))
       );if
   );while
I'm only testing in "-x" direction.
How can I select the object if it is "off screen"?
Off Topic - Also would it be better to stop creating topics? I have three already with this one
Re: Question about selecting an object from a point
« Reply #1 on: December 28, 2010, 06:09:17 AM »
I assume you mean 'three including this one'
That seems fine to me ... If they were all related to the same topic someone will probably have a little whinge though.
The topic is well named, so that will save you some grief. ;)
Brick_top
« Reply #2 on: December 28, 2010, 06:11:33 AM »
I found out that I can just zoom to extents and it will select the object with no problem.
So this is not a problem anymore
It would be interesting to see if anyone has the answer though
Thanks a lot
Brick_top
« Reply #3 on: December 28, 2010, 06:13:43 AM »
Yeah that was what I meant!
My english could be better
Thanks for the clarification
« Reply #4 on: December 28, 2010, 12:53:29 PM »
Another way would be to use nentselp
DEVITG
« Reply #5 on: December 31, 2010, 06:04:17 PM »
Here is the code
(defun c:bd ()
         pre 0.0001
         xpt1 (car pt1)
         ypt1 (cadr pt1)
         ss1 nil
   (while
       );if
   );while
SSGET works only with object on screen , except by( ssget  ¨X¨
You can do a ZOOM center point
cmwade77
« Reply #6 on: January 06, 2011, 06:33:05 PM »
My suggestion is to use something like the following (unless there is more than one object at the point):
(defun c:bd ()
         pre 0.0001
         xpt1 (car pt1)
         ypt1 (cadr pt1)
         ss1 nil
   (while
          (= (setq ss1 (nentselp "" (list cpt1 ypt1)) nil)
       );if
   );while
This should select items off the screen as well.
Brick_top
« Reply #7 on: January 07, 2011, 04:21:06 AM »
thats interesting, i have to look into that nentselp "" part, I don't know about.
but yeah there is one more object at that point, and that is a closed polyline. I have to check if pt1 is inside the selected closed polyline and if not select another one.
I found a routine that checks if a point is inside a closed polyline but, I'll have to understand how it works
thanks for all the help guys
« Last Edit: January 07, 2011, 05:27:02 AM by Brick_top »
Brick_top
« Reply #8 on: January 07, 2011, 04:53:12 AM »
apparently it isn't working, I typed the missing parenthesis and corrected the misspelled variable
(defun c:bd ( / ss1)
         pre 0.01
         xpt1 (car pt1)
         ypt1 (cadr pt1)
   (while
          (= (setq ss1 (nentselp "" (list xpt1 ypt1))) nil)
       );if
   );while
it works if the object is onscreen
« Last Edit: January 07, 2011, 05:14:19 AM by Brick_top »
« Reply #9 on: January 07, 2011, 05:10:14 AM »
Brick_top
Do you know what that code is doing ??
Brick_top
« Reply #10 on: January 07, 2011, 05:19:26 AM »
I haven't really understood the part of the nentselp.
It is changing the value of the x coordinate until it selects an object. I wrote the code, I just don't understand the tip about the nentselp.
edit - but I guess that the user that gave the tip was trying to tell me how to select the object if it is offscreen
« Reply #11 on: January 07, 2011, 05:31:53 AM »
Does it select objects on screen ??
Brick_top
« Reply #12 on: January 07, 2011, 05:35:25 AM »
yes it does
I guess I can just do a zoomextents
« Last Edit: January 07, 2011, 05:48:06 AM by Brick_top »
Brick_top
« Reply #13 on: January 07, 2011, 05:45:09 AM »
I tried doing zoom extents
(defun c:bd ()
         pre 0.01
         xpt1 (car pt1)
         ypt1 (cadr pt1)
         ss1 nil
 (command "zoom" "E")
   (while
       );if
   );while
 (command "zoom" "P")
But I guess this introduces some kind of precision error since it selects objects in other directions
« Reply #14 on: January 07, 2011, 05:50:11 AM »
yes,
Selecting objects using a point off screen has always been an issue.
regarding your code ... I'll be back is a bit ..
