Author Topic: VB.NET to C#  (Read 8672 times)
pkohut
Re: VB.NET to C#
« Reply #15 on: December 27, 2010, 03:01:22 AM »
in that case, how about
if(Convert.ToBoolean(e.Context.History & PointHistoryBits.NotDigitizer))
Hm, heard something about boats and floating...
New tread (not retired) - public repo at https://github.com/pkohut
It's Alive!
  • Retired
  • AKA Daniel
Re: VB.NET to C#
« Reply #16 on: December 27, 2010, 03:05:43 AM »
eh :roll:?    just throwing out alternatives
gile
  • Marseille, France
Re: VB.NET to C#
« Reply #17 on: December 27, 2010, 03:08:05 AM »
This seems to be closer to the VB syntax. It seems to me, VB can have non explcit casts.
It's Alive!
  • Retired
  • AKA Daniel
Re: VB.NET to C#
« Reply #18 on: December 27, 2010, 03:14:46 AM »
It's just C# is a bit more "type safe" than other languages, I wonder what refector shows in this case...
pkohut
Re: VB.NET to C#
« Reply #19 on: December 27, 2010, 03:14:55 AM »
Understood. The humor must of stopped at keyboard  ;-)
It's Alive!
  • Retired
  • AKA Daniel
Re: VB.NET to C#
« Reply #20 on: December 27, 2010, 03:21:03 AM »
Yeah, I better go get myself a few happy pills BRB  :-)
It's Alive!
  • Retired
  • AKA Daniel
Re: VB.NET to C#
« Reply #21 on: December 27, 2010, 03:26:27 AM »
Ok chugged a redbull... where was I   :laugh:
Re: VB.NET to C#
« Reply #22 on: December 27, 2010, 04:28:26 AM »
That should teach me about not testing before posting.  :oops:
sinc
Re: VB.NET to C#
« Reply #23 on: December 27, 2010, 01:05:02 PM »
Now as per the suggestions given yesterday, if I use
 if(args.Context.History & PointHistoryBits.NotDigitizer == 2)
compiler says that we cannot compare int with PointHistoryBits.NotDigitizer, so even this version is not working.
That's because of operator precedence.  You would need to do something like the following:
if ((args.Context.History & PointHistoryBits.NotDigitizer) == 2)
Without explicit parentheses, it gets parsed as:
if (args.Context.History & (PointHistoryBits.NotDigitizer == 2))
gile
  • Marseille, France
Re: VB.NET to C#
« Reply #24 on: December 27, 2010, 05:04:47 PM »
After some tests:
((args.Context.History & PointHistoryBits.NotDigitizer) == 2) => does not work
((e.Context.History & PointHistoryBits.NotDigitizer) > 0) => does not work
((e.Context.History & PointHistoryBits.NotDigitizer) != 0)) => works
(((int)e.Context.History & (int)PointHistoryBits.NotDigitizer) == 2) => works
(((int)e.Context.History & 2) == 2) => works
((e.Context.History & PointHistoryBits.NotDigitizer) == PointHistoryBits.NotDigitizer) => works
((e.Context.History & PointHistoryBits.NotDigitizer) > PointHistoryBits.DidNotPick) => works
(Convert.ToBoolean(e.Context.History & PointHistoryBits.NotDigitizer)) => works
Re: VB.NET to C#
« Reply #25 on: December 27, 2010, 11:24:07 PM »
Just to confuse the iisue more,
The VB code as written is massaged behind the scenes and the decision logic is changed ... one of the reasons ( no, we won't go there today :) )
This is the VB code
   ' ok, so now lets do something really pointless! space invaders!
    If (e.Context.History And PointHistoryBits.NotDigitizer) Then
      ' this means the mouse has been clicked... so...
      ' create a Circle
      Dim circle As Circle = New Circle(e.Context.RawPoint, Vector3d.ZAxis, 10)
      ' draw it
      e.Context.DrawContext.Geometry.Draw(circle)
      ' wait for a while
      System.Threading.Thread.Sleep(50)
      ' draw it
      circle.Radius = 20
      ' wait for a while
      ' draw it
      circle.Radius = 40
      ' wait for a while
      ' draw it
      circle.Radius = 80
      ' wait for a while
    End If
These are snaphots into the compiled code in Reflector // both the VB and C# representation of the Intermediate Langusge in the compiled DLL
note : the piccys will only be visible to members logged-in.
« Last Edit: December 27, 2010, 11:28:21 PM by Kerry »
jgr
Re: VB.NET to C#
« Reply #26 on: December 28, 2010, 08:11:48 AM »
This code is not correct because it only works if Option Strict = off. (this is a compiler option)
This is the right way.
If (e.Context.History And PointHistoryBits.NotDigitizer) = PointHistoryBits.NotDigitizer Then
This also works
If (CInt(e.Context.History) And Cint(PointHistoryBits.NotDigitizer)) = 64 Then
If (CInt(e.Context.History) And 64) = 64 Then
If CBool(e.Context.History And PointHistoryBits.NotDigitizer) Then
Re: VB.NET to C#
« Reply #27 on: December 28, 2010, 08:20:40 AM »
That statement is debatable.
Option Strict = off is an available Option .. so the code is correct in the form it's used.
The real discussion should be "why is Option Strict available as an Option, and should it be used at all"
.. but I won't participate 'cause I'm prejudiced  :-P
.. just my opinion :)
jgr
Re: VB.NET to C#
« Reply #28 on: December 28, 2010, 08:55:28 AM »
It is an inheritance from vb6. This option does not exist in vb6 but internally is always off.
Option Strict On provides strong typing.
http://msdn.microsoft.com/en-us/library/zcd4xwzs%28v=VS.100%29.aspx
