Author Topic: VB.NET to C#  (Read 8663 times)
jsr
VB.NET to C#
« on: December 25, 2010, 04:23:05 AM »
Hi all
while going through Fenton Web's .NET API video tutorial, He searched for left mouse clicks using following code in an event handler routine .
if(args.Context.History AND PointHistoryBits.NotDigitizer)
I am coding in C# and dont know how to translate above to C# statement. Please guide.
Jeff H
Re: VB.NET to C#
« Reply #1 on: December 25, 2010, 05:22:28 AM »
In VB the And is a logical and bitwise operator
Re: VB.NET to C#
« Reply #2 on: December 25, 2010, 07:39:12 PM »
(args.Context.History && PointHistoryBits.NotDigitizer);
jsr
Re: VB.NET to C#
« Reply #3 on: December 26, 2010, 06:03:03 AM »
Thanks for the replies,
but I have tried that syntax and getting following error message. Please guide.
            // Check to see if mouse has been Clicked.
            if(args.Context.History && PointHistoryBits.NotDigitizer)
                // Create a Circle
                Circle c = new Circle(args.Context.RawPoint, Vector3d.ZAxis, 10);
                args.Context.DrawContext.Geometry.Draw(c);
                System.Threading.Thread.Sleep(50);
                // Set the new Radius.
                c.Radius = 20;
                c.Radius = 40;
Operator '&&' cannot be applied to operands of type 'Autodesk.AutoCAD.EditorInput.PointHistoryBits' and 'Autodesk.AutoCAD.EditorInput.PointHistoryBits'.
gile
  • Marseille, France
Re: VB.NET to C#
« Reply #4 on: December 26, 2010, 07:57:59 AM »
So, it's a bitwise AND operator: '&' in C#.
if (args.Context.History & PointHistoryBits.NotDigitizer == 2) ...
sinc
Re: VB.NET to C#
« Reply #5 on: December 26, 2010, 10:37:25 AM »
You would not want to use the "== 2" part...   That wouldn't work right.
gile
  • Marseille, France
Re: VB.NET to C#
« Reply #6 on: December 26, 2010, 11:03:57 AM »
Oopss !
Some casts and parents missing...
Maybe:
if (((int)args.Context.History & (int)PointHistoryBits.NotDigitizer) == 2) ...
or (more concise)
if (((int)args.Context.History & 2) == 2) ...
sinc
Re: VB.NET to C#
« Reply #7 on: December 27, 2010, 12:12:40 AM »
Actually, the "== 2" would work right, it's just that the whole point of having an enumeration like PointHistoryBits is so that you don't hard-code enumeration values in your code.  (Well, that, and the fact that the enumeration helps "comment" the code.)
So you should use something like this:
if ((e.Context.History & PointHistoryBits.NotDigitizer) == PointHistoryBits.NotDigitizer)
Or, a bit simpler:
if ((e.Context.History & PointHistoryBits.NotDigitizer) > 0)
It's Alive!
  • Retired
  • AKA Daniel
Re: VB.NET to C#
« Reply #8 on: December 27, 2010, 12:27:28 AM »
would this work as well?
if ((e.Context.History & PointHistoryBits.NotDigitizer) != 0)
Re: VB.NET to C#
« Reply #9 on: December 27, 2010, 01:19:01 AM »
jsr
do you have the link to the original source ??
pkohut
Re: VB.NET to C#
« Reply #10 on: December 27, 2010, 01:34:08 AM »
Semantic sugar. Sinc's version is clearer to the casual observer by not introducing a negative context into the statement.
New tread (not retired) - public repo at https://github.com/pkohut
jsr
Re: VB.NET to C#
« Reply #11 on: December 27, 2010, 01:35:44 AM »
Thanks everybody for the interest in my post.
Kerry, I saw this code in AutoCAD .NET  api tutorial from Fenton Web. It was in VB.NET and what he wrote was
Now as per the suggestions given yesterday, if I use
 if(args.Context.History & PointHistoryBits.NotDigitizer == 2)
compiler says that we cannot compare int with PointHistoryBits.NotDigitizer, so even this version is not working.
Thanks again.
Re: VB.NET to C#
« Reply #12 on: December 27, 2010, 02:00:31 AM »
did it look something like this ?
// ok, so now lets do something really pointless! space invaders!
if ((e.Context.History & PointHistoryBits.NotDigitizer) > PointHistoryBits.DidNotPick)
// this means the mouse has been clicked... so...
// create a Circle
Circle circle = new Circle(e.Context.RawPoint, Vector3d.ZAxis, 10);
// draw it
e.Context.DrawContext.Geometry.Draw(circle);
// wait for a while
// draw
circle.Radius = 20;
// wait for a while
// draw it
circle.Radius = 40;
// wait for a while
// draw it
circle.Radius = 80;
// wait for a while
ie:
was it related to this http://www.theswamp.org/index.php?topic=19780.0
Was the original something like this ?
    ' ok, so now lets do something really pointless! space invaders!
    If (e.Context.History And PointHistoryBits.NotDigitizer) Then
      ' this means the mouse has been clicked... so...
      ' create a Circle
      Dim circle As Circle = New Circle(e.Context.RawPoint, Vector3d.ZAxis, 10)
      ' draw it
      ' wait for a while
      ' draw it
      circle.Radius = 20
      ' wait for a while
      ' draw it
      circle.Radius = 40
      ' wait for a while
      ' draw it
      circle.Radius = 80
      ' wait for a while
    End If
« Last Edit: December 27, 2010, 02:15:41 AM by Kerry »
gile
  • Marseille, France
Re: VB.NET to C#
« Reply #13 on: December 27, 2010, 02:44:53 AM »
OK, the (corrected) solutions I posted are verbose and not very elegant.
I learned about Enum using...
Another thing about the code contained in the 'then' statement: IMO the created circle (which isn't added to the database) have to be explicitly disposed.
Use this:
                // create a Circle
                using (Circle circle = new Circle(e.Context.RawPoint, Vector3d.ZAxis, 10))
                    // draw it
                    // wait for a while
                    // draw
                    circle.Radius = 20;
                    // wait for a while
                    // draw it
                    circle.Radius = 40;
                    // wait for a while
                    // draw it
                    circle.Radius = 80;
                    // wait for a while
                } // Dispose the Circle
To avoid this:
« Last Edit: December 28, 2010, 05:41:27 PM by gile »
It's Alive!
  • Retired
  • AKA Daniel
Re: VB.NET to C#
« Reply #14 on: December 27, 2010, 02:48:35 AM »
in that case, how about
if(Convert.ToBoolean(e.Context.History & PointHistoryBits.NotDigitizer))
