Author Topic: ANGLE FORMED BY 2 PLANES so fast and infallible?  (Read 4647 times)
SOFITO_SOFT
« on: December 23, 2010, 04:39:21 AM »
Hi all:
For example, from 3 points (not coliniars) of each plane.
Any input is appreciated. :wink:
« Last Edit: December 23, 2010, 03:25:14 PM by CAB »
Re: ANGLE FORMED BY 2 PLANS so fast and infallible?
« Reply #1 on: December 23, 2010, 05:04:08 AM »
depends  ..
In what plane do you want the angle expressed ?
Do you want the angle in the plane of the 3 points ?
or the angle in the current View ?
or the angle when viewed in World plan ?
How are the points defined  .. In world ordinates in in relation to the current UCS ?
See what happens here ... ask a question and someone will ask you at least 4 more :)
« Reply #2 on: December 23, 2010, 05:55:55 AM »
This?
;; Angle Between Planes - Lee Mac 2010
;; Args: p1,p2,p3 - Points on First Plane
;;       p4,p5,p6 - Points on Second Plane
(defun AngleBetweenPlanes ( p1 p2 p3 p4 p5 p6 )
    (lambda ( u v )
      (acos (/ (vxv u v) (* (norm u) (norm v))))
    (v^v (mapcar '- p3 p2) (mapcar '- p2 p1))
    (v^v (mapcar '- p6 p5) (mapcar '- p5 p4))
;; Vector Cross (Wedge) Product - Lee Mac 2010
;; Args: u,v - vectors in R^3
(defun v^v ( u v )
  (list
    (- (* (cadr u) (caddr v)) (* (cadr v) (caddr u)))
    (- (* (car  v) (caddr u)) (* (car  u) (caddr v)))
    (- (* (car  u) (cadr  v)) (* (car  v) (cadr  u)))
;; Vector Dot Product - Lee Mac 2010
;; Args: u,v - vectors in R^n
(defun vxv ( u v )
  (apply '+ (mapcar '* u v))
;; Vector Norm - Lee Mac 2010
;; Args: v - vector in R^n
(defun norm ( v )
  (sqrt (apply '+ (mapcar '* v v)))
;; ArcCosine - Lee Mac 2010
;; Args: -1 <= x <= 1
(defun acos ( x )
  (if (<= (abs x) 1.0)
    (if (equal x 0.0 1e-8)
      (* pi 0.5)
      (atan (/ (sqrt (- 1.0 (* x x))) x))
« Reply #3 on: December 23, 2010, 06:01:55 AM »
Lee, don't have time to play ..
Does that return the  Dihedral angle ?
I couldn't see the question intent exactly, but that may be it.
« Reply #4 on: December 23, 2010, 06:04:25 AM »
Correct, the angle between the normals  :-)
SOFITO_SOFT
Re: ANGLE FORMED BY 2 PLANS ..4 good questions ... or more?
« Reply #5 on: December 23, 2010, 07:30:35 AM »
Hello:
Lee Marc is known about that question.
His program is perfect. You only need to add a verfificacion for 3 points of each plane (in UCS W) form a plane (not aligned).
A possible improvement is to ensure the 2 planes are the same. What angle are 2 planes overlap? The angle is not 0.0 ... Is Null? is infinite ? is not definided ? :-o Thank you all. :-)
« Reply #6 on: December 23, 2010, 07:46:35 AM »
That is the caller's responsibility  :lol:
SOFITO_SOFT
Re: ANGLE FORMED BY 2 PLANS....infallible?
« Reply #7 on: December 23, 2010, 07:49:45 AM »
Hello again:
Sorry ... Another second verfificacion: all the 3 points of each plan must be differents, else it cause a division by 0 and the resulting error.
So I added the word "infallible". The "truck" thickens with points taken from who knows where (other progarms / geometrics functions.)  Anyway, it's a good basis for a unfailing foolproof function. Thanks again. Health for the swamp people.
« Reply #8 on: December 23, 2010, 07:50:58 AM »
This subfunction is for the calculation - IMO all error trapping should be in the calling function.
« Reply #9 on: December 23, 2010, 08:26:05 AM »
soffit,
You will need to check that the 3 points in each plane are colinear (ie not in a straight line)
Then check that the planes are NOT coplanar (ie: that the normal (Z Direction) of one plane is not the same and does not negate the other plane.
Then you can run a routine similar to Lee's.
« Reply #10 on: December 23, 2010, 08:42:20 AM »
Just to satisfy my curiosity,
How are you collecting these Points ??
SOFITO_SOFT
« Reply #11 on: December 23, 2010, 09:36:23 AM »
Hello:
-  UPPER CASE CODE : ADDEMDUM VERIFICATION GEOMETRY CASES WITH SOLUTION BIZARRE BY SOFITO_SOFT :)
-  RETURN :
           nil                  = FAIL DATA... NO 2DPTS OR 3DPTS, CO-LINEAR PTS PLAN, nil PTS, VERY NEAR PTS
           0.0                  = PARALEL OR OVERLAP PLANS   !!! < REVISION
           >  0.0 REAL <  PI    = ONE OF 2 ANGLE INTER PLANS , ANOTER IS PI - RETURN
-  PARA PRUEBAS
  ( ANGLEBETWEENPLANES  (G) (G) (G) (G) (G) (G) )
  ( DEFUN G (/) (GETPOINT) )
-  ORIGINAL
    (lambda ( u v )
(defun AngleBetweenPlanes ( p11 p22 p33 p44 p55 p66 /
 P1  P2  P3  P4  P5  P6
; TOLER ES PUBLICA
( IF ( OR
       ( NOT TOLER )
       ( NOT ( NUMBERP TOLER ) )
     ( SETQ TOLER 1E-8 )
 ( IF ( AND
         ( SETQ P1  (FUERZ_PUNTO3D P11))  ; PRUEBA PUNTOS Y 2D -> 3D (Z=0.0)
         ( SETQ P2  (FUERZ_PUNTO3D P22))
         ( SETQ P3  (FUERZ_PUNTO3D P33))
         ( SETQ P4  (FUERZ_PUNTO3D P44))
         ( SETQ P5  (FUERZ_PUNTO3D P55))
         ( SETQ P6  (FUERZ_PUNTO3D P66))
         ( > (DISTANCE P1 P2) TOLER )     ; PRUEBA DISTINTOS
         ( > (DISTANCE P2 P3) TOLER )
         ( > (DISTANCE P4 P5) TOLER )
         ( > (DISTANCE P5 P6) TOLER )
         ( COLIN_3PUNTO P1 P2 P3 )        ; PRUEBA EXISTEN INTERS.-> NO CO-LINEALES
         ( COLIN_3PUNTO P4 P5 P6 )
      )                           ; AND
  ( ABS
    (lambda ( u v )
      (acos (/ (vxv u v) (* (norm u) (norm v))))     ; <- CODIGO MAGISTRAL !! :)
    (v^v (mapcar '- p3 p2) (mapcar '- p2 p1))        ; <- CODIGO MAGISTRAL !! :)
    (v^v (mapcar '- p6 p5) (mapcar '- p5 p4))        ; <- CODIGO MAGISTRAL !! :)
 ) ; IF
)                ; DEFUN
(DEFUN ES_PUNTO (PUNTO /
  (AND (LISTP PUNTO)
        ( OR
           ( = 2 (LENGTH PUNTO) )
           ( = 3 (LENGTH PUNTO) )
        (APPLY
  (FUNCTION AND)
  (MAPCAR (FUNCTION NUMBERP) PUNTO)
(DEFUN FUERZ_PUNTO3D (PUNTO /
  (IF (AND
        (LISTP PUNTO)
(ES_PUNTO PUNTO)
    (IF (CADDR PUNTO)
      (LIST (FLOAT (CAR PUNTO)) (FLOAT (CADR PUNTO)) (FLOAT (CADDR PUNTO)))
      (LIST (FLOAT (CAR PUNTO)) (FLOAT (CADR PUNTO)) 0.0)
(DEFUN COLIN_3PUNTO (V11 V22 V33 /
V1  V2  V3
  (IF
    (AND
      (SETQ V1  (FUERZ_PUNTO3D V11))
      (SETQ V2  (FUERZ_PUNTO3D V22))
      (SETQ V3  (FUERZ_PUNTO3D V33))
      (NOT (EQUAL 0.0 (DISTANCE V1  V2 ) TOLER))
      (NOT (EQUAL 0.0 (DISTANCE V1  V3 ) TOLER))
      (NOT (EQUAL 0.0 (DISTANCE V2  V3 ) TOLER))
     (INTERS V1  V2  V1  V3 )
(defun v^v ( u v )
  (list
(defun vxv ( u v )
(defun norm ( v )
(defun acos ( x )
      (* pi 0.5)
I think that now is almost indestructible. The points are passed to other functions, such as "inters line / plan", "inters cone / line " "interes plan / planXY ", etc. It has given me many problems here. I want to do this in the picture. Thank you all for your interest. :-)
SOFITO_SOFT
oopsss :) Sorry...
« Reply #12 on: December 23, 2010, 09:43:38 AM »
« Reply #13 on: December 23, 2010, 09:53:29 AM »
Just for fun, try with these planes
(setq p1 '(-1000. 0. 0.)
      p2 '(0. 0. 0.)
      p3 '(0. 500. 100.)
      p4 '(1000. 0. 0.)
      p5 '(0. 0. 0.)
      p6 '(0. 500. 100.)
(setq p1 '(-1000. 200. 0.)
      p2 '(0. 0. 0.)
      p3 '(0. 500. 100.)
      p4 '(1000. 200. 100.)
      p5 '(0. 0. 0.)
      p6 '(0. 500. 100.)
« Last Edit: December 23, 2010, 10:43:58 AM by Kerry »
« Reply #14 on: December 23, 2010, 11:29:46 AM »
No, The dihedral angle is between faces, not between normals.
