Author Topic: UnhandledException event doesn't happen  (Read 2759 times)
Andrey Bushman
« on: December 22, 2010, 08:46:10 AM »
Windows XP SP3 x86 Rus
AutoCAD 2009 SP3 x86 Enu
.Net Framework 3.5 SP1
MS VS 2010
AppDomain.CurrentDomain.UnhandledException+=new UnhandledExceptionEventHandler(CurrentDomain_UnhandledException);
//Test
int ggg = 4;
int fff = 5 / (4 - ggg);//Error generate.
        void CurrentDomain_UnhandledException(object sender, UnhandledExceptionEventArgs e) {
            if (Drawing != null) Drawing.Editor.WriteMessage(string.Format("\n{0}: {1}\n", Resource.ErrorMessage, ((System.Exception)e.ExceptionObject).Message));
            if (XmlCommonSettings != null) SendErrorMail(Resource.UnhandledException, (System.Exception) e.ExceptionObject);
But after an error there is no event UnhandledException. How it is possible to solve this problem?
Andrey Bushman
Re: UnhandledException event doesn't happen
« Reply #1 on: January 19, 2011, 05:20:18 AM »
up
Jeff H
« Reply #2 on: January 19, 2011, 05:35:10 AM »
Have you tried putting it in a try catch block?
And using the DivideByZeroException class?
using System;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace ConsoleApplication1
    class Program
        static void Main(string[] args)
            try
                int ggg = 4;
                int fff = 5 / (4 - ggg);//Error generate.\
            catch (DivideByZeroException e)
                // Do what you want
                MessageBox.Show(e.Message);
Andrey Bushman
« Reply #3 on: January 19, 2011, 06:10:18 AM »
>Jeff H
I must get mail with error information, when unhandled exception occur on user's computer.
In my code (look my first post) the error is generated intentionally to cause event UnhandledException. But the specified event doesn't come (in AutoCAD plugins). Why UnhandledException not happend?
Andrey Bushman
« Reply #4 on: January 19, 2011, 06:20:10 AM »
Real code screen:
In line 128 I register event UnhandledException.
In line 149 I generate an exception but after that I don't get to a line 160 because AutoCAD completes plug-in operation.
It is necessary for me, that the code from a line 160 was fulfilled in the presence of a raw exception.
Glenn R
« Reply #5 on: January 19, 2011, 10:11:04 AM »
This will not catch anything and AutoCAD does not fail:
void IExtensionApplication.Initialize()
      throw new DivideByZeroException();
This will catch the exception:
    try
    catch (DivideByZeroException ex)
        acadApp.ShowAlertDialog(ex.ToString());
When AutoCAD calls Initialize(), it must wrap it in an try/catch block and swallow the exception.
