Author Topic: Help about print hatch in block!  (Read 5003 times)
Re: Help about print hatch in block!
« Reply #15 on: December 22, 2010, 11:34:56 AM »
And Lee is correct about the dxf code not being there is the color of an entity is ByLayer.  You will have to put it in the dxf code list like he shows.
Thanks Tim, I completely overlooked the original request with my explanations...  :oops:
duyhung
« Reply #16 on: December 22, 2010, 12:41:11 PM »
Thanks all.
Hey I don't know much about advance lisp. I write lisp as beginner, apload and run lisp. Can you give me one complete lisp?
In my country it's 0 hour 37 minutes. When you are working I'm sleep  :-)
Thanks!
« Reply #17 on: December 22, 2010, 12:54:58 PM »
Usually we help, we don't give, but since you are new here, here is a complete lisp.
(defun c:ChangeHatchColor ()
    (vlax-for blk (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-Acad-Object)))
        (vlax-for i blk
            (if (= (vla-get-ObjectName i) "AcDbHatch")
                (vla-put-Color i 250)
    (command "_.regenall")
duyhung
« Reply #18 on: December 22, 2010, 01:02:24 PM »
Thanks Tim I know and I'll study more about lisp!.
pBe
« Reply #19 on: December 23, 2010, 12:45:54 AM »
Hence the 2nd post
plain and simple  :-)
and it works
except the nested part of course:
« Last Edit: December 23, 2010, 12:54:57 AM by pBe »
