Thanks so much smadsen.
I'll try it out and see what happens.
@whdjr : Yes, the selection-set is valid after rotation (the entity hasn't changed, just it's vertex data).
I actually have several entities rotating in a while() loop, subsequent iterations using the same ssbox entity(ies) all succeed without a hitch.
All this is for is to replace an item fellow detailers at work are now using blocks for, this routine draws everything procedurally with parameters gathered at the comand line and does away with hand-edits, blocks etc.
Thanks again, very kind of you to take the time to help.
