Author Topic: What does this error message mean?  (Read 1668 times)
HasanCAD
« on: December 14, 2010, 04:49:50 AM »
When Run a lisp this error message comes but when repeat the same lisp working good
; error: An error has occurred inside the *error* functionbad argument type:
VLA-OBJECT nil
This is erorr subroutine
(defun *error* (msg)
  (if oldEcho (setvar "CMDECHO" oldEcho))
  (if oSnp (setvar "OSMODE" oSnp))
  (if oZin (setvar "DIMZIN" oZin))
  (if mSp  (vla-EndUndoMark actDoc))
  (princ msg)
Re: What does this error message mean?
« Reply #1 on: December 14, 2010, 05:24:23 AM »
The only VLA Object there is  actDoc
Perhaps it is nil.
« Reply #2 on: December 14, 2010, 05:36:35 AM »
Perhaps add something like this to the *error* function
  ;;----- Display error message if applicable _---------------------------
    ((not msg))                              ; no error, so do nothing
    ((member (strcase msg t)                 ; if cancel or quit
             '("console break" "function cancelled" "quit / exit abort")
    ((princ (strcat "\nApplication Error: " (itoa (getvar "errno")) " :- " msg))
     ;;----- Display backtrace ------------------------------------------
     (vl-bt)
HasanCAD
« Reply #3 on: December 14, 2010, 09:01:24 AM »
Thanks Kerry
