Author Topic: File Open Dialogs  (Read 5351 times)
Columbia
File Open Dialogs
« on: January 07, 2005, 02:23:31 PM »
Okay, I'm stumped.  I've been looking for a way to tap into the file dialogs in AutoCAD but I can't seem to do it.  Can anybody shed some light.??
File Open Dialogs
« Reply #1 on: January 07, 2005, 02:29:27 PM »
Exactly what are you needing to do ... I have done some open file dialogs using the Windows Classes and API calls .. it is pretty simple ...
Columbia
File Open Dialogs
« Reply #2 on: January 07, 2005, 02:32:31 PM »
What I want to do is just browse for and select a file.  I would also like the option for multiple file select.  Sort of like the (getfiled) and (getfilem) functions in AutoLISP.
TR
File Open Dialogs
« Reply #3 on: January 07, 2005, 02:36:42 PM »
Here's CommonDialog.cls by Frank Oquendo
VERSION 1.0 CLASS
BEGIN
  MultiUse = -1  'True
END
Attribute VB_Name = "CommonDialog"
Attribute VB_GlobalNameSpace = False
Attribute VB_Creatable = False
Attribute VB_PredeclaredId = False
Attribute VB_Exposed = False
' COMMONDIALOG.CLS v1.2 (Last updated 6/15/2000)
' Copyright 2000 by Frank Oquendo
' Permission to use, copy, modify, and distribute this software
' for any purpose and without fee is hereby granted, provided
' that the above copyright notice appears in all copies and
' that both that copyright notice and the limited warranty and
' restricted rights notice below appear in all supporting
' documentation.
' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH
' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  THE AUTHOR
' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
' UNINTERRUPTED OR ERROR FREE.
' Use, duplication, or disclosure by the U.S. Government is subject to
' restrictions set forth in FAR 52.227-19 (Commercial Computer
' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
' (Rights in Technical Data and Computer Software), as applicable.
' CommonDialog.cls allows developers to access the Windows Open, Save
' and Browse For Folder dialogs without the need for an OCX.
' Notes:
' All code for this class module is publicly available througout various posts
' at news://discussion.autodesk.com/autodesk.autocad.customization.vba as well
' as http://msdn.microsoft.com. I do not claim copyright or authorship on code
' presented in these posts, only on this compilation of that code.
' Dependencies:
' Use of this class module requires the following files:
' 1. shell32.dll  (SHBrowseForFolder)
' 2. comdlg32.dll (GetOpenFileName and GetSaveFileName)
Option Explicit
Private Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" _
    (pOpenfilename As OPENFILENAME) As Long
Private Declare Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" _
Private Declare Function SHBrowseForFolder Lib "shell32.dll" Alias "SHBrowseForFolderA" _
    (lpBrowseInfo As BROWSEINFO) As Long
Private Declare Function SHGetPathFromIDList Lib "shell32.dll" Alias "SHGetPathFromIDListA" _
    (ByVal pidl As Long, _
     ByVal pszPath As String) As Long
Private Declare Sub CoTaskMemFree Lib "ole32.dll" _
    (ByVal pv As Long)
Private Declare Function CommDlgExtendedError Lib "comdlg32.dll" () As Long
Private Type OPENFILENAME
        lStructSize As Long
        hwndOwner As Long
        hInstance As Long
        lpstrFilter As String
        lpstrCustomFilter As String
        nMaxCustFilter As Long
        nFilterIndex As Long
        lpstrFile As String
        nMaxFile As Long
        lpstrFileTitle As String
        nMaxFileTitle As Long
        lpstrInitialDir As String
        lpstrTitle As String
        Flags As Long
        nFileOffset As Integer
        nFileExtension As Integer
        lpstrDefExt As String
        lCustData As Long
        lpfnHook As Long
        lpTemplateName As String
End Type
Private Type BROWSEINFO
    hOwner As Long
    pidlRoot As Long
    pszDisplayName As String
    lpszTitle As String
    ulFlags As Long
    lpfn As Long
    lParam As Long
    iImage As Long
End Type
Private Const ERROR_SUCCESS As Long = 0
Private Const MAX_PATH As Long = 260
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private mvarPath As String
Private mvarInitDir As String
Private mvarDialogTitle As String
Private mvarFilter As String
Private mvarUserFilter As String
Private mvarDefaultExt As String
Private mvarFileName As String
Private mvarFileTitle As String
Private mvarFilterIndex As Integer
Private mvarFlags As Long
Private mvarMaxFileSize As Integer
Private mvarErrorCode As Long
Private mvarErrorDescription As String
Public Enum cdlFlags
    OFN_ALLOWMULTISELECT = &H200
    OFN_CREATEPROMPT = &H2000
    OFN_ENABLEHOOK = &H20
    OFN_ENABLETEMPLATE = &H40
    OFN_ENABLETEMPLATEHANDLE = &H80
    OFN_EXPLORER = &H80000
    OFN_EXTENSIONDIFFERENT = &H400
    OFN_FILEMUSTEXIST = &H1000
    OFN_HIDEREADONLY = &H4
    OFN_LONGNAMES = &H200000
    OFN_NOCHANGEDIR = &H8
    OFN_NODEREFERENCELINKS = &H100000
    OFN_NOLONGNAMES = &H40000
    OFN_NONETWORKBUTTON = &H20000
    OFN_NOREADONLYRETURN = &H8000
    OFN_NOTESTFILECREATE = &H10000
    OFN_NOVALIDATE = &H100
    OFN_OVERWRITEPROMPT = &H2
    OFN_PATHMUSTEXIST = &H800
    OFN_READONLY = &H1
    OFN_SHAREAWARE = &H4000
    OFN_SHAREFALLTHROUGH = 2
    OFN_SHARENOWARN = 1
    OFN_SHAREWARN = 0
    OFN_SHOWHELP = &H10
End Enum
Public Enum cdlError
    CDERR_DIALOGFAILURE = &HFFFF
    CDERR_FINDRESFAILURE = &H6
    CDERR_GENERALCODES = &H0
    CDERR_INITIALIZATION = &H2
    CDERR_LOADRESFAILURE = &H7
    CDERR_LOADSTRFAILURE = &H5
    CDERR_LOCKRESFAILURE = &H8
    CDERR_MEMALLOCFAILURE = &H9
    CDERR_MEMLOCKFAILURE = &HA
    CDERR_NOHINSTANCE = &H4
    CDERR_NOHOOK = &HB
    CDERR_NOTEMPLATE = &H3
    CDERR_REGISTERMSGFAIL = &HC
    CDERR_STRUCTSIZE = &H1
End Enum
Private Sub Class_Initialize()
    mvarMaxFileSize = 256
    mvarFileName = String(mvarMaxFileSize, 0)
End Sub
Public Property Let InitDir(newVal As String)
    mvarInitDir = newVal
End Property
Public Property Get InitDir() As String
    InitDir = mvarInitDir
End Property
Public Property Let DialogTitle(ByVal newVal As String)
    mvarDialogTitle = newVal
End Property
Public Property Get DialogTitle() As String
    DialogTitle = mvarDialogTitle
End Property
Public Property Let Filter(ByVal newVal As String)
    Dim tmp, i As Integer
    tmp = Split(newVal, "|")
    mvarFilter = ""
    mvarUserFilter = newVal
    For i = LBound(tmp) To UBound(tmp)
        mvarFilter = mvarFilter & tmp(i) & Chr(0)
    Next
    mvarFilter = mvarFilter & Chr(0)
End Property
Public Property Get Filter() As String
    Filter = mvarUserFilter
End Property
Public Property Get Path() As String
    Path = mvarPath
End Property
Public Property Get DefaultExt() As String
    DefaultExt = mvarDefaultExt
End Property
Public Property Let DefaultExt(ByVal newVal As String)
    mvarDefaultExt = newVal
End Property
Public Property Let FileName(ByVal newVal As String)
    mvarFileName = newVal
End Property
Public Property Get FileName() As String
    FileName = mvarFileName
End Property
Public Property Get FileTitle() As String
    FileTitle = mvarFileTitle
End Property
Public Property Let FilterIndex(ByVal newVal As Integer)
    mvarFilterIndex = newVal
End Property
Public Property Get FilterIndex() As Integer
    FilterIndex = mvarFilterIndex
End Property
Public Property Let Flags(ByVal newVal As cdlFlags)
    mvarFlags = newVal
End Property
Public Property Get Flags() As cdlFlags
    Flags = mvarFlags
End Property
Public Property Let MaxFileSize(ByVal newVal As Integer)
    mvarMaxFileSize = newVal
    mvarFileName = String(newVal, 0)
End Property
Public Property Get MaxFileSize() As Integer
    MaxFileSize = mvarMaxFileSize
End Property
Public Property Get LastError() As cdlError
    LastError = mvarErrorCode
End Property
Public Function Browse() As Long
    ' Displays the Browse For Folder dialog
    Dim Path As String * MAX_PATH
    Dim retval As Long, bi As BROWSEINFO
    bi.ulFlags = BIF_RETURNONLYFSDIRS
    bi.lpszTitle = mvarDialogTitle
    retval = SHBrowseForFolder(bi)
    If retval Then
        Call SHGetPathFromIDList(retval, Path)
        mvarPath = Left(Path, InStr(Path, Chr(0)))
    End If
    Call CoTaskMemFree(retval)
    Browse = retval
End Function
Public Function ShowOpen() As Long
    ' Displays the Open dialog.
    ' A positive return value indicates success (the user selected a file)
    ' A zero return indicates the user either cancelled or closed the dialog
    ' A negative return value indicates the API call failed
    Dim retval As Long, ofn As OPENFILENAME
    With ofn
        .lStructSize = Len(ofn)
        .Flags = mvarFlags
        .lpstrDefExt = mvarDefaultExt
        .lpstrFile = mvarFileName
        .lpstrInitialDir = mvarInitDir
        .lpstrTitle = mvarDialogTitle
        .lpstrFilter = mvarFilter
        .nFilterIndex = mvarFilterIndex
        .lpstrFileTitle = mvarFileName
        .nMaxFile = mvarMaxFileSize
        .nMaxFileTitle = mvarMaxFileSize
    End With
    retval = GetOpenFileName(ofn)
    If retval > 0 Then
        Call GetComponents(ofn)
    Else
        mvarErrorCode = CommDlgExtendedError
    End If
    ShowOpen = retval
End Function
Public Function ShowSave() As Long
    ' Displays the Save/SaveAs dialog.
    With ofn
        .Flags = mvarFlags
    End With
    retval = GetSaveFileName(ofn)
    If retval > 0 Then
    Else
    End If
    ShowSave = retval
End Function
Public Function ParseFileNames() As Variant
    Dim tmp, retval(), i As Integer
    Dim min As Integer, max As Integer
    tmp = Split(mvarFileName, Chr(0))
    min = LBound(tmp): max = UBound(tmp)
    If min = max Then
        ReDim retval(min To min)
        retval(min) = mvarFileName
    Else
        ReDim retval(min To max - 1)
        For i = min To max - 1
            retval(i) = tmp(min) & "\" & tmp(i + 1)
        Next
    End If
    ParseFileNames = retval
End Function
Private Sub GetComponents(ofn As OPENFILENAME)
    mvarFileName = Left$(ofn.lpstrFile, _
                         InStr(ofn.nFileOffset + 1, _
                               ofn.lpstrFile, _
                               Chr(0) & Chr(0), _
                               vbBinaryCompare) - 1 _
    mvarFileTitle = Left$(ofn.lpstrFileTitle, InStr(ofn.lpstrFileTitle, Chr(0) & Chr(0)) - 1)
    mvarPath = Left(mvarFileName, ofn.nFileOffset)
End Sub
Private Function Split(ByVal Str As String, ByVal Delim As String) As Variant
    Dim tokens() As String, pos As Long, i As Integer
    pos = InStr(1, Str, Delim, vbTextCompare)
    i = 0
    Do While pos > 0
      ReDim Preserve tokens(0 To i)
      tokens(i) = Mid$(Str, 1, pos - 1)
      If tokens(i) = Delim Then tokens(i) = ""
      Str = Mid$(Str, pos + Len(Delim))
      i = i + 1
    Loop
    If Len(Str) > 0 Then
      tokens(i) = Str
    End If
    Split = tokens
End Function
File Open Dialogs
« Reply #4 on: January 07, 2005, 03:17:50 PM »
Ok here is my code ... use it in good health ...
Option Explicit
Private Declare Function GetOpenFileName _
                Lib "comdlg32.dll" _
                Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
    lStructSize       As Long
    hwndOwner         As Long
    hInstance         As Long
    lpstrFile         As String
    nMaxFile          As Long
    flags             As Long
    lCustData         As Long
    lpfnHook          As Long
End Type
Private Const OFN_ALLOWMULTISELECT = &H200
Private Const OFN_CREATEPROMPT = &H2000
Private Const OFN_ENABLEHOOK = &H20
Private Const OFN_ENABLETEMPLATE = &H40
Private Const OFN_ENABLETEMPLATEHANDLE = &H80
Private Const OFN_EXPLORER = &H80000
Private Const OFN_EXTENSIONDIFFERENT = &H400
Private Const OFN_FILEMUSTEXIST = &H1000
Private Const OFN_HIDEREADONLY = &H4
Private Const OFN_LONGNAMES = &H200000
Private Const OFN_NOCHANGEDIR = &H8
Private Const OFN_NODEREFERENCELINKS = &H100000
Private Const OFN_NOLONGNAMES = &H40000
Private Const OFN_NONETWORKBUTTON = &H20000
Private Const OFN_NOREADONLYRETURN = &H8000
Private Const OFN_NOTESTFILECREATE = &H10000
Private Const OFN_NOVALIDATE = &H100
Private Const OFN_OVERWRITEPROMPT = &H2
Private Const OFN_PATHMUSTEXIST = &H800
Private Const OFN_READONLY = &H1
Private Const OFN_SHAREAWARE = &H4000
Private Const OFN_SHAREFALLTHROUGH = 2
Private Const OFN_SHARENOWARN = 1
Private Const OFN_SHAREWARN = 0
Private Const OFN_SHOWHELP = &H10
Function Open_Comdlg32(ByVal strFilter As String, ByVal strTitle As String, ByVal lStyle As Long, ByVal strStartFolder As String) As Variant
Dim OpenFile As OPENFILENAME
OpenFile.lStructSize = Len(OpenFile)
With OpenFile
    .lpstrFilter = strFilter
    .nFilterIndex = 1
    .lpstrFile = String(4096, 0)
    .nMaxFile = Len(.lpstrFile) - 1
    .lpstrFileTitle = .lpstrFile
    .nMaxFileTitle = .nMaxFile
    .lpstrInitialDir = strStartFolder
    .lpstrTitle = strTitle
    .flags = lStyle
End With
If GetOpenFileName(OpenFile) = 0 Then
 Open_Comdlg32 = GetOpenFileName(OpenFile)
Else
 Open_Comdlg32 = OpenFile.lpstrFile
End If
End Function
The syntax for a typical open file would be ...
FileList = Open_Comdlg32("AutoCAD Drawing File (*.dwg)" & Chr(0) & "*.dwg" & Chr(0) & _
                         "AutoCAD Drawing Exchange File (*.dxf)" & Chr(0) & "*.dxf" & Chr(0), _
                         "Select Drawing File", _
                         OFN_EXPLORER + OFN_ALLOWMULTISELECT, _
                         "C:\Drawings")
Now a few caveats ... note the filter must be followed and separated by a null character ... follow the example above for changing the filters
If you select multiple files, the returned list is a null separated string .. you must iterate through the string to get each successive file.
If no file was selected, it will return 0
Columbia
File Open Dialogs
« Reply #5 on: January 07, 2005, 03:31:09 PM »
Thanks to both.  I will enjoy pouring over this and coming up with another diabolical scheme to help my fellow 'evil doers' in taking over the AutoCAD world...one byte at a time. Muhahahahahahahaha!!!!!
Oh, wait a minute.  Did I just say that in my out loud voice??
whdjr
File Open Dialogs
« Reply #6 on: January 10, 2005, 09:53:46 AM »
Quote from: Columbia
What is (getfilem)?  Is that a command AutoCAD forgot to add to the help files or is that 3rd party progy?
File Open Dialogs
« Reply #7 on: January 10, 2005, 09:56:19 AM »
Will, this is for VBA ....
whdjr
File Open Dialogs
« Reply #8 on: January 10, 2005, 11:16:52 AM »
Quote from: Keith
Yes I know that, but (getfiled) is an Autolisp command.  I was unfamiliar with (getfilem).  I didn't find it in the VBA help files or the Autolisp help files.  Just asking about it?
File Open Dialogs
« Reply #9 on: January 10, 2005, 12:36:24 PM »
getfilem is likely an externally defined function
