Author Topic: Prevent Block Explode  (Read 10084 times)
Jeff H
« on: December 13, 2010, 05:25:03 PM »
I threw this idea out to someone at Autodesk fourms and decided to code real quick  http://forums.autodesk.com/t5/NET/how-top-revent-a-block-from-explode-using-vb-net/td-p/2850744
The basic idea was setting the blocks explodable property to false. That cadMeUp suggested
And I think the only way to change that is through the block editor so added a event handler for CommandEnded and check for "BCLOSE" and if so change explodable property back to false.
   [CommandMethod("BlockBlock2")]
         public void BlockBlock2()
            Application.DocumentManager.MdiActiveDocument.CommandEnded += new CommandEventHandler(blkEdClosed);
           blockNames.Add("C");
         static void blkEdClosed(object sender, Autodesk.AutoCAD.ApplicationServices.CommandEventArgs e)
             if (e.GlobalCommandName == "BCLOSE")
                 Database db = doc.Database;
                 using (Transaction trx = db.TransactionManager.StartTransaction())
                     BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                     foreach (string bName in blockNames)
                         if (bt.Has(bName))
                             ObjectId btrObjId = bt["C"].GetObject(OpenMode.ForRead).ObjectId;
                             BlockTableRecord btr = (BlockTableRecord)btrObjId.GetObject(OpenMode.ForRead);
                             if (btr.Explodable == true)
                                 btr.UpgradeOpen();
                                 btr.Explodable = false;
                     trx.Commit();
         static void BlockEditorOpen(object sender, Autodesk.AutoCAD.ApplicationServices.SystemVariableChangedEventArgs  e)
             if (e.Name == "BLOCKEDITOR" && e.Changed == true)
                 if ((int)Application.GetSystemVariable("BLOCKEDITOR") == 0)
                             if (bt.Has(bName))
                                     btr.UpgradeOpen();
                         trx.Commit();
Re: Prevent Block Explode
« Reply #1 on: December 13, 2010, 07:00:32 PM »
Just a note, but you can change the explode'ability of a block by code also, so if you really wanted a fool proof method, then I would think that you would have to put an event on the block itself.  If anything about the block changes, then fire the event, and check if the block's explode'ability has changed.
« Reply #2 on: December 13, 2010, 07:02:38 PM »
but of course, the events will only fire if the code is loaded :)
.. so any solution will only work if the user wants it to work.
Jeff H
« Reply #3 on: December 13, 2010, 07:17:39 PM »
I did not go that path because of the overhead of event handlers
And If I am corrrect about the only to change it is throught the BlockEditor and "BCLOSE" is always called when the block editor closes then this should work.
And the part of it demand loading and taking away the rights of the user not to change the installation
Here is another I started messing with that makes the blocks go invisible when the explode command starts.
Definetly not fool proof. And needs work, It sounded better in my head and thrown together quickly.
     ObjectIdCollection btrBlkObjIds = new ObjectIdCollection();
        public static ObjectIdCollection brefObjIds = new ObjectIdCollection();
        [CommandMethod("BlockBlock")]
        public void BlockBlock()
            Editor ed = doc.Editor;
                if (bt.Has("C"))
                    btrBlkObjIds.Add(btrObjId);
                     ObjectIdCollection blkRefs =  btr.GetBlockReferenceIds(true, true);
                     foreach (ObjectId brefId in blkRefs)
                        brefObjIds.Add(brefId);
                doc.CommandWillStart += new CommandEventHandler(ExplodeStart);
                trx.Commit();
         static void ExplodeStart(object sender, CommandEventArgs e )
                if (e.GlobalCommandName == "EXPLODE")
                    doc.CommandEnded += new CommandEventHandler(ExplodeEnd);
                    doc.CommandCancelled += new CommandEventHandler(ExplodeEnd);
                    ed.SelectionAdded += new SelectionAddedEventHandler(SelectionAdd);
                        foreach (ObjectId brefId in brefObjIds)
                            Entity ent = brefId.GetObject(OpenMode.ForWrite) as Entity;
                            ent.Visible = false;
                        trx.Commit();
         static void ExplodeEnd(object sender, CommandEventArgs e)
                 Database db = HostApplicationServices.WorkingDatabase;
                 doc.CommandEnded -= new CommandEventHandler(ExplodeEnd);
                 doc.CommandCancelled -= new CommandEventHandler(ExplodeEnd);
                 ed.SelectionAdded -= new SelectionAddedEventHandler(SelectionAdd);
                         ent.Visible = true;
                     trx.Commit();
                 ed.UpdateScreen();
         static void SelectionAdd(object sender, SelectionAddedEventArgs e)
                 ObjectId[] selectId = e.AddedObjects.GetObjectIds();
                 if (brefObjIds.Contains(selectId[0]))
                     Application.SetSystemVariable("PICKFIRST", 0);
                 else
                     Application.SetSystemVariable("PICKFIRST", 1);
                 trx.Commit();
Left this off the first one
public static List<string> blockNames= new List<string>();
« Reply #4 on: December 13, 2010, 07:30:17 PM »
<snip>
That is what I'm saying.  Use this code ( below ).  It will change the ability to explode the block, even with your code running.
(vla-put-explodable (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget (car (entsel "\n Select block.")))))) :vlax-true)
Jeff H
« Reply #5 on: December 13, 2010, 07:40:10 PM »
That is that smart people stuff. I get scared and confused when I see Lisp, but I at least want to be able to understand it before I start going the Lisp fourm and stealing it.
« Reply #6 on: December 14, 2010, 01:20:23 AM »
Didn't get a lot of sleep last night, so I'm off to bed now, but if no one explains it before tomorrow, I'll explain what the code is doing, step by step.  Basically it is just setting the exploade'ability of a selected block to true ( allowing it to be exploded ).
« Reply #7 on: December 14, 2010, 11:36:29 AM »
Hope this makes it clearer what the code is doing.
(vla-put-explodable     ;  the property to set
    (vla-item           ;  a way to get something within a collection
        (vla-get-blocks ;  the collection ( table ) of block definitions
            (vla-get-activedocument     ;  the active drawing
                (vlax-get-acad-object)  ;  the current session of autocad
        (cdr            ;  the rest of the items in a list, excluding the first one
            (assoc      ;  returns the list that matches the arguement, in a associated list of lists
                2       ;  the dxf code for name
                (entget ;  gets the dxf code list of the entity
                    (car    ;  gets the first item in a list
                        (entsel "\n Select block.")     ;  selects a single entity, non-nested
        )               ;  this whole section just gets the name of the block selected
    )                   ;  this whole section gets the blocks definition ( BlockTableRecord ) from the block collection ( BlockTable )
    :vlax-true          ;  the value we want to set the property
Jeff H
« Reply #8 on: December 14, 2010, 01:35:36 PM »
Thanks alot!!!!
David Hall
  • Automatic Duh Generator
« Reply #9 on: January 15, 2011, 11:43:22 AM »
what about setting the currentDrawing to explodable?  I have hundreds of blocks I just inherited that need that property changed
Jeff H
« Reply #10 on: January 15, 2011, 12:12:38 PM »
I am not sure about setting the drawing but should not take long to iterate through a 100
This prints out the block name and its Explodable property then changes the value and prints it
[CommandMethod("ChangeExplodableProperty")]
        public void ChangeExplodableProperty()
                foreach (ObjectId objId in bt)
                    BlockTableRecord btr = (BlockTableRecord)objId.GetObject(OpenMode.ForRead);
                    if (!btr.IsLayout)
                        ed.WriteMessage("\n" + btr.Name + " Explodable property is set to " + btr.Explodable.ToString());
                        btr.UpgradeOpen();
                        btr.Explodable = !btr.Explodable;
                        ed.WriteMessage("\n" + btr.Name + " Explodable property has changed to " + btr.Explodable.ToString());
                trx.Commit();
David Hall
« Reply #11 on: January 17, 2011, 08:23:53 AM »
that works for the blocks IN the drawing, but what about the drawing itself?  meaning, the file that gets inserted as a block needs the property set
vegbruiser
« Reply #12 on: January 18, 2011, 08:40:16 AM »
Hi Tim (going back to your LISP sample),
How would I make that work in AutoCAD 2009/2011? I've tried adding it to a .lsp file provided by a colleague, but can't figure out the correct syntax to call it.
Thanks,
Alex.
« Reply #13 on: January 18, 2011, 11:06:27 AM »
Thanks,
Alex.
Right now you would just copy / paste it to the command line.  If you want to make it a callable command, then you need to wrap the whole function in a ' defun ' call like so:
(defun c:MakeExplodable ()
vegbruiser
« Reply #14 on: January 18, 2011, 12:19:55 PM »
I'm getting an error when I run this in both AutoCAD (Mechanical) 2011 & AutoCAD (Civil 3d) 2009:
Thoughts?
