Author Topic: Sheet/Layout background color behind "Uniform background".  (Read 6328 times)
Re: Sheet/Layout background color behind "Uniform background".
« Reply #15 on: December 13, 2010, 09:56:01 AM »
Did that method change the gray area behind the paper?
« Reply #16 on: December 13, 2010, 10:09:40 AM »
yes and no...
it turns the ENTIRE layout to chosen color...
right up until you toggle the Display Paper Background back on....
it's a FAIL
« Reply #17 on: December 13, 2010, 10:16:09 AM »
According to the post in the link it should change the gray color only.
Maybe i miss read it.
Have you ever wanted to change the background color in paper space?  I’m referring to the gray area outside of the paper border.  Suppose you wanted the entire background to be black, just like model space.  Here is how you can change it.
Jeff H
« Reply #18 on: December 13, 2010, 04:51:36 PM »
BackColor is probably ffffff
