Author Topic: Challenge - Find interior angles of a closed polyline  (Read 13436 times)
« on: December 09, 2010, 04:49:32 PM »
Inspired by this post over at the Adesk Ng - http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Find-included-angles-of-Pline/td-p/2847672
I thought it would be a fun challenge, that wasn't too hard, but I got a little more than I thought I would.  I have a solution already, posted in that thread, but wondered how others would tackle it.  One of the issues was getting the angle value of 289 instead of 71, as shown in the pic attached.
VovKa
  • Ukraine
Re: Challenge - Find interior angles of a closed polyline
« Reply #1 on: December 09, 2010, 05:16:35 PM »
(defun vk_GetLeftAngle (p1 p2 p3 / Ang)
  (if (minusp (setq Ang (rem (+ pi (angle p2 p1) (- (angle p3 p2))) (* pi 2.0))))
    (+ pi pi Ang)
    Ang
(defun test (/ lst)
  (setq lst (mapcar 'cdr
   (vl-remove-if-not (function (lambda (e) (= (car e) 10)))
     (entget (car (entsel)))
  (mapcar (function
   (lambda (p1 p2 p3 / Ang) (angtos (- (* 2 pi) (vk_GetLeftAngle p1 p2 p3))))
 (cons (last lst) lst)
 lst
 (append (cdr lst) (list (car lst)))
had vk_GetLeftAngle already in my libs
« Reply #2 on: December 09, 2010, 05:34:19 PM »
I guess you would just need to test which way the polyline goes then Vovka?
I like how you get the angle.  I didn't think of that one, and I tried a couple.
« Reply #3 on: December 09, 2010, 07:30:14 PM »
yes, he's generally very frugal.
« Reply #4 on: December 09, 2010, 08:34:24 PM »
VovKa,
After studying your code, would this also work for the GetLeftAngle?
(defun LM:GetLeftAngle ( p1 p2 p3 )
  (rem (+ pi pi (- (angle p2 p1) (angle p2 p3))) (+ pi pi))
« Reply #5 on: December 09, 2010, 09:11:36 PM »
Not too imaginative, and using most of VovKa's code:
(defun c:test ( / l m )
  (setq l (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= (car x) 10)) (entget (car (entsel))))))
  (setq l
    (mapcar '(lambda ( p1 p2 p3 ) (LM:GetLeftAngle p1 p2 p3))
      (cons (last l) l) l (append (cdr l) (list (car l)))
  (mapcar 'angtos (if (< (apply '+ l) (apply '+ (setq m (mapcar '(lambda ( x ) (- (* 2. pi) x)) l)))) l m))
VovKa
  • Ukraine
« Reply #6 on: December 10, 2010, 03:12:03 AM »
then i will need something like...
(defun vk_IsBoundaryClockwise (CoordsList)
  (minusp
    (apply '+
     (mapcar (function
(lambda (p1 p2)
 (* (+ (car p1) (car p2)) (- (cadr p1) (cadr p2)))
     CoordsList
     (cons (last CoordsList) CoordsList)
VovKa,
i think it perfectly will
« Last Edit: December 10, 2010, 03:25:24 AM by VovKa »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: December 10, 2010, 04:04:14 AM »
  (setq l
I like your program, I want to shorten it a bit:
  (setq l (mapcar 'LM:GetLeftAngle (cons (last l) l) l (append (cdr l) (list (car l)))))
as an alternative, I propose a different approach:
(defun c:test (/ e)
 (if (setq e (car (entsel)))
  (reverse (f e (1- (cdr (assoc 90 (entget e)))) 0))
(defun f (e i1 i2)
 (if (>= i1 0)
  (cons (angtos (rem (+ pi
                        pi
                        (- (angle (vlax-curve-getFirstDeriv e i1) '(0 0))
                           (angle '(0 0) (vlax-curve-getFirstDeriv e i2))
                     (+ pi pi)
        (f e (1- i1) i1)
roy_043
  • BricsCAD 18
« Reply #8 on: December 10, 2010, 07:42:18 AM »
  (setq l
  [color=red](mapcar 'angtos (if (< (apply '+ l) (apply '+ (setq m (mapcar '(lambda ( x ) (- (* 2. pi) x)) l)))) l m))[/color]
That's a clever line of code!
« Reply #9 on: December 10, 2010, 09:09:19 AM »
  (setq l (mapcar [color=red]'LM:GetLeftAngle[/color] (cons (last l) l) l (append (cdr l) (list (car l)))))
Ah yes! Of course - no lambda needed  :oops:
Thanks Evgeniy!
Time for more studying  :-)
« Reply #10 on: December 10, 2010, 09:09:51 AM »
Thanks Roy  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: December 10, 2010, 10:16:22 AM »
I really liked the design
(Rem (+ pi pi (- (angle p2 p1) (angle p2 p3))) (+ pi pi))I will take it on his arms!
Previously, I always use multiple IF...
« Reply #12 on: December 10, 2010, 11:57:11 AM »
Man you guys are good!
Vovka - with the added function, yours shows the correct angles now.
Lee - yours shows the correct angles.
Evgeniy - yours shows the correct angles only half the time.  I think the issue is the same as Vovka's first post, where the polyline direction matters.  In the attached drawing, the bottom two polylines should only have one angle of 270, but you code shows the opposite.
I don't even want to show my code now, as the only way I could think of see which angle to get, was to test a point, and see if that was inside the polyline.  But I'll show, just don't laugh.
(defun c:Test ( / ActDoc CurSp Sel Data PlObj PtList cnt MaxCnt Ang tempAng Pt tempObj AngList Norm Pt2 tempAng2 )
    (setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
    (setq CurSp
        (vlax-get
            ActDoc
            (if (equal (getvar 'CvPort) 1)
                'PaperSpace
                'ModelSpace
            (setq Sel (entsel "\n Select closed polyline: "))
            (setq Data (entget (car Sel)))
            (= (cdr (assoc 0 Data)) "LWPOLYLINE")
            (equal (logand 1 (cdr (assoc 70 Data))) 1)
            (setq PlObj (vlax-ename->vla-object (car Sel)))
            (foreach i Data
                (if (equal (car i) 10)
                    (setq PtList (cons (cdr i) PtList))
            (setq PtList (reverse PtList))
            (setq cnt 0)
            (setq MaxCnt (1- (length PtList)))
            (while (<= cnt MaxCnt)
                (setq Ang
                    (abs
                            (setq tempAng
                                    (angle
                                        (setq Pt (nth cnt PtList))
                                        (setq Pt2 (nth (if (zerop cnt) MaxCnt (1- cnt)) PtList))
                            (setq tempAng2
                                    (equal
                                        (setq tempAng2
                                                (angle
                                                    Pt
                                                    (nth (if (equal cnt MaxCnt) 0 (1+ cnt)) PtList)
                                        0.
                                    (* pi 2.)
                                    tempAng2
                (setq Pt (trans Pt (setq Norm (cdr (assoc 210 Data))) 0))
                (setq StPt (polar Pt tempAng 0.0001))
                (setq tempObj (vlax-invoke CurSp 'AddRay StPt (trans Pt2 Norm 0)))
                (vlax-invoke tempObj 'Rotate Pt (* (/ Ang 2.) (if (< tempAng tempAng2) 1. -1.)))
                    (equal
                        (rem
                            (/ (length (vlax-invoke PlObj 'IntersectWith tempObj acExtendNone)) 3)
                            2
                        1
                    (setq AngList (cons Ang AngList))
                    (setq AngList (cons (- (* pi 2.) Ang) AngList))
                ;(print (car AngList))
                ;(getstring "\n Hit enter to continue: ")
                (if tempObj (vla-Delete tempObj))
                (setq tempObj nil)
                (setq cnt (1+ cnt))
    (print (mapcar (function RTD) (reverse AngList)))
Off to study the code posted, so I can test somethings.  Thanks for posting guys!!
LE3
« Reply #13 on: December 10, 2010, 01:10:16 PM »
here are some outputs using some of my old stuff:
« Reply #14 on: December 10, 2010, 01:34:21 PM »
Thanks Evgeniy - that's quite a compliment coming from you!  :-)
