Author Topic: Tool not register properly error  (Read 2895 times)
slappy
« on: December 09, 2010, 03:59:20 pm »
Using the old ADT detail callouts from the tool palettes.  The command is AECANNODETAILBOUNDARYADD and errors "Tool Not Registered Properly".  I've seen this before and usually it's when the layering key style doesn't jive with the file, but I've checked this and doesn't seem to correct the issue.
It's on a ACA 2010 install that is fresh.  I've tried a repair to no avail.
Any thoughts?
Slap
Diving into DEEP .NET waters
Re: Tool not register properly error
« Reply #1 on: December 09, 2010, 04:03:13 pm »
so...how did you add this OLD tool into your 2010 instalation?
is this the only tool that fails to function?
slappy
« Reply #2 on: December 09, 2010, 04:39:27 pm »
Pushed it in to the Content browser from 2007 and each release (2009, 2010) migrate over the Content Brower files.
Be aware, the tool works in all of the other installs only occasionally this will happen.  First time for 2010.
All the tools that use the AEC Callout command fail in this way.  (Section tools, Titles, etc...)
Slap
« Reply #3 on: December 09, 2010, 04:48:37 pm »
and what happens if you give yourself a new user profile with super user(admin) level privileges?
slappy
« Reply #4 on: December 09, 2010, 05:22:38 pm »
Won't happen...  Is this a means to an end?
« Reply #5 on: December 09, 2010, 05:26:31 pm »
does possible solution to the issue qualify?
slappy
« Reply #6 on: December 09, 2010, 05:37:48 pm »
If the solution is to give super user rights, No.  That is not an option.
Slap
Jeff H
« Reply #7 on: December 09, 2010, 05:51:45 pm »
Instead of super how about half-super rights
« Reply #8 on: December 09, 2010, 05:55:09 pm »
the 'test' is to give admin and or super user powers
IF
    (this solves the problem)
THEN
    (you decide how to implement)
ELSE
    (end loop)
OR
One might even consider testing creating a NEW user profile with 'lesser' powers and verify that the tools do or do not register correctly.
Jeff H
« Reply #9 on: December 09, 2010, 06:14:53 pm »
IF
THEN
ELSE
    (end loop)
OR
But if it solves the problem won't you be stuck on deciding  how to implement forever
If you solve the problem then the (end loop) after ELSE will never happen
Save your breath I am already telling myself to shut-up.
« Reply #10 on: December 09, 2010, 06:17:21 pm »
 ;-)  does this fix it?
IF
THEN
OR
    (do nothing)
ELSE
    (end loop)
« Last Edit: December 09, 2010, 07:01:33 pm by Higgs Boson's Mate »
slappy
« Reply #11 on: December 10, 2010, 01:57:25 pm »
After thinking on this a bit... :ugly:  I realize I attempted to use these commands as the local admin I was using to do the Repair...  Still failed.  Doing a reinstall now, will update on results.
Slap
slappy
« Reply #12 on: December 10, 2010, 03:51:29 pm »
EUREAKA!
Found out it was a missing ADTStockTools.atc file from the enu\Support\Register Tools\ folder under the profile.  Not sure how this file gets generated but without it the "Stock" tools don't work....  Copied over one from another system and bodabing, FIXED!
Slap
« Reply #13 on: December 10, 2010, 04:55:32 pm »
EUREAKA!
Slap
and that would be one reason I wanted you to create a NEW user profile
slappy
« Reply #14 on: December 10, 2010, 05:17:46 pm »
EUREAKA!
Slap
Define "New User Profile"...  After each install I deleted the AutoCAD profile folder and cleared out the Local User Registry settings.  By doing this AutoCAD has to recreate these setting from it's new user cache....  Not sure what else could be done.
