Author Topic: lisp to email  (Read 15452 times)
andrew_nao
lisp to email
« on: December 08, 2010, 11:01:14 AM »
anyone have any code or a method of bypass they can share that will send email messages without a warning from outlook or user interaction?
i have some code but when its activated i get this message from my outlook that is saying "a program is sending an email on your behalf bla bla bla... do you wish to continue"
and im trying to get around this and automatically send without user interaction
here is the code im using
(defun email ()
         (setq olApp (vlax-get-or-create-object "Outlook.Application"))
         (setq objMail (vlax-invoke olApp 'CreateItem 0))
         (vlax-put-property objMail 'Subject "subject here")
         (vlax-put-property objMail 'To "email here")   ;<-----specified email
         (vlax-put-property objMail 'Body "message here")
         (vlax-invoke objMail 'Send)
thanks
cmwade77
Re: lisp to email
« Reply #1 on: December 08, 2010, 12:00:05 PM »
Unfortunately, I do not; however, I would also be interested in this.....could do some automatic bug reports, as well as get a better idea of how users are using the routines.
Re: lisp to email
« Reply #2 on: December 08, 2010, 12:09:16 PM »
This is pretty similar to what you are using (except you can add attachments). I tested it and do not get a prompt to send the mail.
http://www.theswamp.org/index.php?topic=26953.msg324794#msg324794
TimSpangler
  • CAD Naked!!
Re: lisp to email
« Reply #3 on: December 08, 2010, 12:18:58 PM »
I got the prompt with this Ron.  Maybe it is a security setting?
I am running Outlook '03 if that matters.
ACA 2015 - Windows 7 Pro
Re: lisp to email
« Reply #4 on: December 08, 2010, 01:09:35 PM »
Perhaps the antivirus is not up to date. I have 2007 and when disabled gave the send warning.
There is also a checkbox Tools>>Trust Center>>Programmatic Access (Never warn about suspicious activity) that stopped the prompt.
http://office.microsoft.com/en-us/outlook-help/i-get-warnings-about-a-program-accessing-e-mail-address-information-or-sending-e-mail-on-my-behalf-HA001229943.aspx#BM3
andrew_nao
Re: lisp to email
« Reply #5 on: December 08, 2010, 01:24:42 PM »
i was hoping there was a way around this my IT admin isnt going to turn off the security settings for this
andrew_nao
Re: lisp to email
« Reply #6 on: December 08, 2010, 01:46:37 PM »
after much searching the net i found this...
it has to be setup to work for you with your smpt info and account name and passwords but its worth a try
as soon as I get ahold of my IT admin i will test this out but if someone else tests this out before i do report back and let us know if this works
; use (sendmail cRecip cSender cServer cUser cPass cSubject cMessage)
(defun SendMail (cRecip cSender cServer cUser cPass cSubject cMessage / iMsg iConf Flds fItem)
; create our CDO object
  (setq iMsg  (vlax-create-object "CDO.Message")
iConf (vlax-create-object "CDO.Configuration")
Flds  (vlax-get-property iConf 'Fields)
  ) ; setq
; configure the settings
  (setq
    fItem (vlax-get-property
    Flds
    'Item
    "http://schemas.microsoft.com/cdo/configuration/sendusing"
  (vlax-put-property FItem 'Value 2)
  (setq fItem
(vlax-get-property
   Flds
   'Item
   "http://schemas.microsoft.com/cdo/configuration/smtpserver"
  (vlax-put-property FItem 'Value cServer)
; @@ SMTP SERVER
  (setq fItem
(vlax-get-property
   Flds
   'Item
   "http://schemas.microsoft.com/cdo/configuration/smtpserverport"
  (vlax-put-property FItem 'Value 25)
  (setq fItem
(vlax-get-property
   Flds
   'Item
   "http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout"
  (vlax-put-property FItem 'Value 5) ; smtp server timeout in seconds
  (setq fItem
(vlax-get-property
   Flds
   'Item
   "http://schemas.microsoft.com/cdo/configuration/smtpauthenticate"
  (vlax-put-property FItem 'Value 1)
  (setq fItem
(vlax-get-property
   Flds
   'Item
   "http://schemas.microsoft.com/cdo/configuration/sendusername"
  (vlax-put-property FItem 'Value cUser) ; @@ ACCOUNT
  (setq fItem
(vlax-get-property
   Flds
   'Item
   "http://schemas.microsoft.com/cdo/configuration/sendpassword"
  (vlax-put-property FItem 'Value cPass) ; @@ PASSWORD
  (vlax-invoke-method Flds 'Update)
; Build HTML for message body.
  (setq strHTML "<HTML>"
strHTML (strcat strHTML "<HEAD>")
strHTML (strcat strHTML "</HEAD>")
strHTML (strcat strHTML "<BODY>")
strHTML (strcat strHTML cMessage)
strHTML (strcat strHTML "</BODY>")
strHTML (strcat strHTML "</HTML>")
  ) ; setq
; Apply the settings to the message.
  (vlax-put-property iMsg 'Configuration iConf)
  (vlax-put-property iMsg 'To cRecip)
  (vlax-put-property iMsg 'From cSender); @@ FROM ADDRESS
  (vlax-put-property iMsg 'Subject cSubject)
  (vlax-put-property iMsg 'HTMLBody strHTML)
  (vlax-invoke-method iMsg 'Send)
  (vlax-release-object iMsg)
  (vlax-release-object iConf)
) ; SendMail
cmwade77
Re: lisp to email
« Reply #7 on: December 08, 2010, 02:01:21 PM »
Can you please provide where you got this, so that proper credit can be given?
andrew_nao
Re: lisp to email
« Reply #8 on: December 08, 2010, 02:05:34 PM »
when googling it linked me to the autodesk forums
but im affraid i dont know how to set this up
maybe one of you other master coders can inform me/us
on how to set this up?
alanjt
  • Standby for witty remark...
Re: lisp to email
« Reply #9 on: December 08, 2010, 02:06:46 PM »
Ron, on your routine, I didn't receive a prompt, but I still have to press send in the new email document, or is this supposed to happen?
Dropbox
Re: lisp to email
« Reply #10 on: December 08, 2010, 02:13:27 PM »
It should have just sent? What version of Outlook are you using?
alanjt
Re: lisp to email
« Reply #11 on: December 08, 2010, 02:14:26 PM »
'03 in win7
Dropbox
Re: lisp to email
« Reply #12 on: December 08, 2010, 02:18:20 PM »
From the usage in the file provided by Ron ..
;;Usage
(rjp-OutlookMessage
  ;;email address (multiple separated by semicolon)
  "johndoe@nowhere.com;johndoewife@nowhere.com"
  ;;Subject
  "Test Email"
  ;;Attachments as a list of strings
  '("C:\\test\\file1.txt" "C:\\test\\file2.txt" "C:\\test\\file3.txt")
  ;;Text in body of email
  "Nothing to read here :)"
 ;;nil will open email to edit...T will send email in the background
  nil
Check your syntax ...
Re: lisp to email
« Reply #13 on: December 08, 2010, 02:18:29 PM »
'03 in win7
Did you specify T for the last arg?
alanjt
Re: lisp to email
« Reply #14 on: December 08, 2010, 02:20:05 PM »
'03 in win7
I'm retarded - didn't even notice that.  :ugly:
FYI, it also gives me the warning.
Dropbox
