Author Topic: Ocx in 64 bit  (Read 7117 times)
velasquez
Ocx in 64 bit
« on: December 04, 2010, 08:44:46 AM »
Hi
Please I seek somebody to test the file .ocx enclosed in a system of 64 bits.
I don't find who compiled.
Any help is well coming tanks.
velasquez
<edit CAB: File Removed...>
« Last Edit: December 04, 2010, 11:52:41 AM by CAB »
velasquez
Re: Ocx in 64 bit
« Reply #1 on: December 04, 2010, 08:49:52 AM »
I forgot.
First to register.
Then to use:
(setq vlaLock (vlax-create-object "draftteam.suppctrl"))
thanks
velasquez
Re: Ocx in 64 bit
« Reply #2 on: December 04, 2010, 10:40:16 AM »
I would be very cautious about testing a file of this type without knowing more about who and what it is about.
http://answers.yahoo.com/question/index?qid=20080305070718AAPeMR7
http://filext.com/file-extension/OCX
Re: Ocx in 64 bit
« Reply #3 on: December 04, 2010, 11:26:05 AM »
times one billion
if I were a mod I'd remove it from the original post, the op can link offsite
LE3
Re: Ocx in 64 bit
« Reply #4 on: December 04, 2010, 07:46:45 PM »
I forgot.
First to register.
Then to use:
thanks
velasquez
Hey.... that's it is mine.
it may be one of the only VB stuff I wrote in the past or that it simple the icons for my old program menu...
It is something I did based on the old activelock activex control - some moons ago and that was part of a book of visual lisp - btw.
where did you got it?
;;; Copyright © 2003,2004,2005 Luis Esquivel
;;; draftteam Software, All rights reserved
;;; Web site: http://www.draftteam.com
;;; E-mail: support@draftteam.com
;;; WARNING: All the source code included here is intelectual property
;;; of the author Luis Esquivel, if you can read this message you are
;;; violating the law and not following the license document agreement
;;; that you accepted at the installation time.
;;;(pragma '((unprotect-assign dtt-loadKey)))
(defun dtt-loadKey  (/ vlaLock appCode)
  (setq appCode "")
  (if (and vlaLock (= (type vlaLock) 'vla-object))
      (vlax-put-property
vlaLock
'SoftwareName
dtt_softname)
      (vlax-put-property vlaLock 'LiberationKeyLength 16)
      (vlax-put-property vlaLock 'SoftwareCodeLength 16)
      (vlax-put-property vlaLock 'HashAlgorithm 4)
      (vlax-put-property
vlaLock
'LockToComputerName
« Last Edit: December 04, 2010, 07:58:44 PM by LE »
Re: Ocx in 64 bit
« Reply #5 on: December 04, 2010, 08:27:54 PM »
 :-o
LE3
Re: Ocx in 64 bit
« Reply #6 on: December 04, 2010, 08:44:52 PM »
 :-o
I went to do a search into my old stuff, and found that I did a 'light version' and posted somewhere, he/she might be using that one.
Re: Ocx in 64 bit
« Reply #7 on: December 04, 2010, 09:07:44 PM »
dig it, kinda like "if you can smell the nerve gas it's too late, you're dead mf"
velasquez
Re: Ocx in 64 bit
« Reply #8 on: December 05, 2010, 06:48:37 AM »
I forgot.
First to register.
Then to use:
thanks
velasquez
  (setq appCode "")
      (vlax-put-property
vlaLock
'SoftwareName
dtt_softname)
      (vlax-put-property
vlaLock
'LockToComputerName
Hi  LE
I got this with you.
You included until the code source.
I didn't get to use new ActiveLock.
I am only seeking help to update the work.
I don't want to harm the work of anybody
I sent the e-mail below to you in the address -> luis@slarchitects.com
Hello Luis,
Did you stop working with the project LOCKVLISP that uses AciveLock?
I am trying to develop some thing with this.
Do you can me to help of some way?
Thanks,
Velasquez
velasquez
Re: Ocx in 64 bit
« Reply #9 on: December 05, 2010, 07:06:24 AM »
Excuse me.
I only posted the file after doing all the tests.
I know so that he serves.
Tanks
velasquez
LE3
Re: Ocx in 64 bit
« Reply #10 on: December 05, 2010, 10:08:32 AM »
Olá Velasquez,
Desculpe, não posso lembrar :(
Debe ser una version basica.
O projeto foi abandonado há vários anos, tenho o código fonte, mas eu não poderia fazer qualquer atualização.
Além do projeto original também foi abandonado.
Hi Velasquez,
I do not recall :(
I see you are using the light version.
My project was abandoned some years ago, I still have the source code, but I can't do any update, sorry.
Also, the original project was abandoned too, as far as I know.
Hello Luis,
Thanks,
Velasquez
velasquez
Re: Ocx in 64 bit
« Reply #11 on: December 06, 2010, 05:56:47 AM »
Olá Velasquez,
Hi Velasquez,
I do not recall :(
Hello Luis,
Thanks,
Velasquez
Hi LE,
Thank you.
I hope you have understood that I didn't want to harm you and your work.
LE3
Re: Ocx in 64 bit
« Reply #12 on: December 06, 2010, 09:47:44 AM »
Hi LE,
Thank you.
No problem at all. :)
LE3
Re: Ocx in 64 bit
« Reply #13 on: December 06, 2010, 08:57:59 PM »
Hi LE,
Thank you.
And Velasquez, if you know VB or want it to give it a try to port the project into .NET, let me know and I can open a new topic here for LockVlisp as open source.
velasquez
Re: Ocx in 64 bit
« Reply #14 on: December 07, 2010, 12:17:37 PM »
Hi LE,
Thank you.
Hi  LE
I don't still know VB.
But I find a great idea a project for LockVlisp.
I believe that a lot of people could help.
Great idea.
