Author Topic: Star Trek Enterprise?  (Read 5831 times)
craigr
« on: January 05, 2005, 12:07:21 PM »
Approx. 10 years ago, there was an AutoCad 2d dwg of the Star Trek Enterprise from the Next Generation TV Show, floating around the web. It showed the crews quarters, etc.... I had it for awhile, but have lost the file.
Do any of you have it or know where I can find it?
craigr
« Reply #1 on: January 05, 2005, 12:33:24 PM »
I'll look... I had it too....
  • Custom Title
« Reply #2 on: January 05, 2005, 12:54:01 PM »
Look in your folder on the lilly pond craigr, is that it?
« Reply #3 on: January 05, 2005, 01:11:28 PM »
Mark, that looks like some sort of electrical schematic
dubb
« Reply #4 on: January 05, 2005, 01:16:22 PM »
i love star trek
  • Custom Title
« Reply #5 on: January 05, 2005, 01:23:21 PM »
Quote from: Keith
lmao ....... that's what I get for not opening the dwg. ummm ......... nevermind.  :roll:
« Reply #6 on: January 05, 2005, 01:26:53 PM »
at least you knew that 1701 was the numbers....
I am not sure what software you have but this site has lots of 3D Studio Max (and R4) as well as lightwave and TrueSpace meshes you could likely export to DXF. http://www.trekmeshes.ch/
  • Custom Title
« Reply #7 on: January 05, 2005, 01:28:03 PM »
craigr
« Reply #8 on: January 05, 2005, 02:11:27 PM »
I have downloaded some from the links that some of you have suggested. None of them are the file I am looking for. This dwg is of the Enterprise from 'The Next Generation' series, (I don't know which 1700 series it is.
Still looking, craigr
PDJ
« Reply #9 on: January 05, 2005, 02:57:13 PM »
Might wanna check over at http://www.3dcafe.com and look in the free stuff section, I seem to remember a few Enterprise drawings in there..  That or it could be all the glue I ate as a child playing tricks on me.
Jeff_M
  • C3D user & customizer
« Reply #10 on: January 05, 2005, 03:16:30 PM »
M-dub
« Reply #11 on: January 05, 2005, 03:22:19 PM »
www.nerds.com?
:twisted:
ps...don't know if that's an actual website or not.
hendie
« Reply #12 on: January 05, 2005, 04:28:03 PM »
fucarro had a great one recently on cadtutor ~ it was created using grvecs and had the enterprise diappearing into the distance
« Reply #13 on: January 05, 2005, 07:07:49 PM »
(defun c:enterprise ()
  (setvar "cmdecho" 0)
  (command "zoom" (list -55 -30) (list 80 80))
  (setq a0 (list -32  -8   -17 -8   -2  -7   13   -4 21   1   22
3    20   6 13   8  4    9    -10 8    -21  7
-34  4   -41 0    -42  -2   -42  -4 -39  -6   -32
-8   -34  -13 -42  -16  -49  -20  -53 -24  -54  -26
-54  -28  -52 -28  -40  -31  -37  -29 -37  -28  -44
-28  -52  -28 "e"  -28  -23  -28  -25 -29  -27  -39
-32  -68  -28 -70  -26  -71  -22  -75 -22  -76  -20
-75  -17  -51 -7   -47  -8   -46  -10 -46  -12  -47
-13  -70  -22 -71  -22  "e"  -53  -24 -58  -24  -61
-22  -62  -19 -70  -22  -69  -25  -68 -27  "e"  -28
-25  -22  -22 -18  -19  -14  -17  -13 -16  -13  -13
-17  -12  -19 -12  -17  -9   -19  -12 -23  -14  -33
-13  -23  -14 -42  -22  -43  -24  -41 -26  -37  -27
-18  -19
  (setq i  0
j  2
ax nil
  (while (< j (length a0))
    (if (= (nth j a0) "e")
      (setq j (+ 3 j)
   i (+ 3 i)
      (setq ax (cons (list (nth i a0) (nth (1+ i) a0)) ax)
   ax (cons (list (nth j a0) (nth (1+ j) a0)) ax)
   i  j
   j  (+ i 2)
  (setq i 10)
  (repeat 150
    (setq i (1+ i)
 color 255
 s (/ 15.0 i)
    (setq matr (list
(list s 0 0 (/ i 1.5))
(list 0 s 0 (/ i 2.0))
(list 0 0 1 0)
(list 0 0 0 1)
    (grvecs (cons color ax) matr)
    (command "delay" (fix (- 80 (* 0.5 i))))
    (setq color 256)
  (grvecs ax)
(command ".regen")
(command ".zoom" "previous")
hendie
« Reply #14 on: January 06, 2005, 05:47:07 AM »
thanks Ronjonp ~ I was going to try and find the link this morning but you've saved me the trouble
craigr
« Reply #15 on: January 06, 2005, 08:44:46 AM »
Thanks for all of your suggestions, I ended up finding it and more on FreeCadapps.com.
Thanks again, craigr :)
RebarDWG
« Reply #16 on: January 07, 2005, 12:50:42 PM »
7 of 9 is hot!!
« Reply #17 on: January 07, 2005, 01:08:43 PM »
Quote from: RebarDWG
7 of 9 is hot!!
You got that right!!!
