Author Topic: Middle button - AutoCad 2010/Cadworx 2010 - Windows 7 64 bit  (Read 7389 times)
laison
« on: November 23, 2010, 08:30:06 PM »
Hello
I am currently working off of a new system that has the newest of everything. I am not compaining. There is one the though, ever since I first started with AutoCad I always had my middle button configured so that I could pull up my osnaps. Just click on it and there it was. If I were to roll the middle button it would still zoom in and out.
Well with Windows 7 64 bit (I don't think that is it)  AutoCad 2010 & Cadworx 2010 I can not figure out to bring back my osnaps to the middle button.
Has AutoCad taken that feature away? If not could someone please inform me on how to fix this.
Re: Middle button - AutoCad 2010/Cadworx 2010 - Windows 7 64 bit
« Reply #1 on: November 23, 2010, 08:32:18 PM »
What is the setting for your MBUTTONPAN System Variable ??
Jeff H
« Reply #2 on: November 23, 2010, 11:00:22 PM »
Like Kerry replied and make sure, which I think always or normally is button 3
laison
« Reply #3 on: November 28, 2010, 12:26:01 AM »
thank you
