Author Topic: Dynamic Blocks Names vs. Non Dynamic Block names  (Read 7573 times)
alanjt
  • Standby for witty remark...
Re: Dynamic Blocks Names vs. Non Dynamic Block names
« Reply #15 on: February 03, 2011, 10:51:50 AM »
cat...
(defun getBlocksByName (bname / ss)
  (if (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 (strcat bname ",`*U*")))))
    ((lambda (i n / e)
       (while (setq e (ssname ss (setq i (1+ i))))
         (or (eq n (strcase (vla-get-effectivename (vlax-ename->vla-object e)))) (ssdel e ss))
       (sssetfirst nil ss)
      -1
      (strcase bname)
Dropbox
Harrie
« Reply #16 on: February 03, 2011, 11:36:50 AM »
Thanks Ronjonp,
But I prefer it, like this:
(defun getblocksbyname2 (bname / obj ss ss2)
  (setq ss2 (ssadd))
    (foreach blk (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (setq obj (vlax-ename->vla-object blk))
      (and (eq (strcase bname) (strcase (vla-get-effectivename obj))) (setq ss2 (ssadd blk ss2)))
  ;(sssetfirst nil ss2)
  ss2
Because with (sssetfirst nil ss2), I can't use it in _.PSELECT from PROPERTIES.
Regards, Harrie.
Harrie
« Reply #17 on: February 03, 2011, 11:41:00 AM »
Thanks Alanjt,
But your program gives the same problem as the program from Lee Mac.
Regards, Harrie.
gile
  • Marseille, France
« Reply #18 on: February 03, 2011, 11:41:21 AM »
cat...
    ((lambda (i n / e)
       (sssetfirst nil ss)
      -1
      (strcase bname)
Alan, while you're removing items from the selection set you're stepping, you cannot increment with 1+ systematically...
EDIT: Same problem with Lee's code.
Increment by 1+ only if the item isn't deleted
    ((lambda (i n / e)
       (while (setq e (ssname ss i))
         (if (eq n (strcase (vla-get-effectivename (vlax-ename->vla-object e))))
   (setq i (1+ i))
   (ssdel e ss)
       (sssetfirst nil ss)
      0
      (strcase bname)
Or décrement (1-)
    ((lambda (i n / e)
       (while (setq e (ssname ss (setq i (1- i))))
       (sssetfirst nil ss)
      (sslength ss)
      (strcase bname)
« Last Edit: February 03, 2011, 11:44:39 AM by gile »
« Reply #19 on: February 03, 2011, 11:49:06 AM »
Just a little FYI.
This is over kill
You only need this:
(ssadd blk ss2) ; adds blk to selection set
Harrie
« Reply #20 on: February 03, 2011, 11:57:00 AM »
Thanks Gile,
Your programs gives a good result in DynBlkTest.dwg.
But, I prefer at the end:
ss
Because then I can use it in  _.PSELECT from PROPERTIES.
Regards, Harrie.
gile
  • Marseille, France
« Reply #21 on: February 03, 2011, 12:13:29 PM »
Thanks Gile,
ss
Regards, Harrie.
So, here's the way I'd have written it:
(defun ssBlocksByName (bname / ss n blk)
    (setq bname (strcase bname)
     (repeat (setq n (sslength ss))
(setq blk (ssname ss (setq n (1- n))))
(/= bname (strcase (vla-get-effectivename (vlax-ename->vla-object blk))))
(ssdel blk ss)
  ss
« Last Edit: February 03, 2011, 12:21:01 PM by gile »
Harrie
« Reply #22 on: February 03, 2011, 12:24:55 PM »
Thanks Gile,
So, here's the way I'd have written it: Yes.
Regards, Harrie.
alanjt
« Reply #23 on: February 03, 2011, 01:27:53 PM »
Crap, I didn't even think about that. Thanks Gile.
cat...
    ((lambda (i n / e)
       (sssetfirst nil ss)
      -1
      (strcase bname)
    ((lambda (i n / e)
   (setq i (1+ i))
   (ssdel e ss)
       (sssetfirst nil ss)
      0
      (strcase bname)
Or décrement (1-)
    ((lambda (i n / e)
       (sssetfirst nil ss)
      (sslength ss)
      (strcase bname)
Dropbox
« Reply #24 on: February 03, 2011, 02:07:19 PM »
Ditto, completely overlooked that  :ugly:
Thanks guys  :-)
« Reply #25 on: February 03, 2011, 03:17:48 PM »
Thanks Ronjonp,
  (setq ss2 (ssadd))
  ss2
Regards, Harrie.
sssetfirst wil select them for you ... what is pselect?
alanjt
« Reply #26 on: February 03, 2011, 03:19:08 PM »
Thanks Ronjonp,
  (setq ss2 (ssadd))
  ss2
Regards, Harrie.
The only difference I've ever noticed is that, unlike Select, PSelect will leave the selected item(s) selected.
Dropbox
HofCAD
« Reply #27 on: February 03, 2011, 06:14:57 PM »
Like this:
(defun GetBlocksByName (bname / obj ss ss2)
  (setq ss2 (ssadd))
      (and (eq (strcase bname) (strcase (vla-get-effectivename obj))) (ssadd blk ss2))
  ss2
(defun c:SELDYNBLK(/ BlkName)
(setq BlkName (getstring "\nEnter block name or <Select>:"))
(if (= BlkName "")
(setq BlkName (vla-get-effectivename (vlax-ename->vla-object(car (entsel)))))
(setq S (GetBlocksByName BlkName))
;(princ (strcat "\nThere are " (itoa (sslength S)) " blocks in the selection.\n"))
(command "_.PSELECT" S "")
(defun C:SDB() (c:SELDYNBLK))
Regards, HofCAD CSI.
« Last Edit: February 03, 2011, 06:20:35 PM by HofCAD »
« Reply #28 on: February 03, 2011, 06:27:53 PM »
Of course, there is another method  8-)
(defun test ( block )
  (ssget "_X"
    (list
      (cons 0 "INSERT")
      (cons 2 (LM:BlockList->Str (cons block (LM:AnonymousInstancesof block)) ","))
(defun LM:AnonymousInstancesof ( block / def rec nme ref lst )
  (while (setq def (tblnext "BLOCK" (null def)))
    (if (= 1 (logand 1 (cdr (assoc 70 def))))
        (setq rec
          (entget
            (cdr
              (assoc 330
                (entget
                  (tblobjname "BLOCK" (setq nme (cdr (assoc 2 def))))
        (while (setq ref (assoc 331 rec))
              (eq block (vla-get-effectivename (vlax-ename->vla-object (cdr ref))))
              (not (member nme lst))
            (setq lst (cons nme lst))
          (setq rec (cdr (member (assoc 331 rec) rec)))
  (reverse lst)
(defun LM:BlockList->Str ( lst del / f )
  (defun f ( s ) (if (wcmatch s "`**") (strcat "`" s) s))
  (if (cdr lst)
    (strcat (f (car lst)) del (LM:BlockList->Str (cdr lst) del))
    (f (car lst))
« Last Edit: February 03, 2011, 06:33:05 PM by Lee Mac »
« Reply #29 on: February 04, 2011, 12:54:42 PM »
Similar to Lee's but will output a list '(("blockname" (ename1 ename2 ename3)))
(defun rjp-getinsertedblocks (/ b brec inserts name o out)
  (while (setq b (tblnext "block" (not b)))
    (if (not (assoc 1 b))
      ;;xref path
      (progn (setq name   (cdr (assoc 2 b))
  brec   (entget (cdr (assoc 330 (entget (tblobjname "block" name)))))
  inserts (cdr (member '(102 . "{BLKREFS") brec))
  inserts (mapcar (function cdr) (cdr (member '(102 . "}") (reverse inserts))))
    (if (and (setq inserts (vl-remove-if-not (function (lambda (x) (entget x))) inserts))
     (setq o (vlax-ename->vla-object (car inserts)))
     (vlax-property-available-p o 'effectivename)
     (setq name (vla-get-effectivename o))
      (if (assoc name out)
(setq out (mapcar (function (lambda (x)
      (if (eq (car x) name)
(list name (append (cadr x) inserts))
x
  out
(setq out (cons (list name inserts) out))
  (vl-sort out (function (lambda (n1 n2) (< (car n1) (car n2)))))
(mapcar '(lambda (x) (print (strcat (car x) " - " (itoa (length (cadr x))))))
(rjp-getinsertedblocks)
