Author Topic: Dynamic Blocks Names vs. Non Dynamic Block names  (Read 7552 times)
BuckoAk
« on: November 16, 2010, 03:37:09 PM »
I have situations where I need to know what titleblocks are inserted so certain lisp programs can run.
I am currently using this statement to locate the titleblocks but when it comes to dynamic blocks it retrieves "(2 . *U52)".
If you list the titleblock it comes back a normal name, is it possible to retrieve the true block name from an anonymous name.
Or possibly add additional code that can gather this info?
Any help would greatly be appreciated.
(setq $CLIENT#2 nil)
;;;********** Check For CLIENT#2
(setq BrdrList (list '"CLIENT2_8x11" '"CLIENT2_22X34"))
(foreach Item BrdrList
      (if (= $CLIENT#2 nil)
(setq $CLIENT#2 (ssget "X" (list (cons 0 "INSERT") (cons 2 Item) ))))
       );_end foreach
Re: Dynamic Blocks Names vs. Non Dynamic Block names
« Reply #1 on: November 16, 2010, 03:38:45 PM »
Perhaps use a SelectionSet of:
(cons 2 (strcat Item ",`*U*"))
Then, when iterating through the SelectionSet, test:
(if (eq Item (vla-get-EffectiveName (vlax-ename->vla-object <entity>)))
Oh BTW, quotes are not needed, use
(setq BrdrList (list "CLIENT2_8x11" "CLIENT2_22X34"))
or:
(setq BrdrList '("CLIENT2_8x11" "CLIENT2_22X34"))
« Reply #2 on: November 16, 2010, 03:49:59 PM »
You could use this sub in place of the ssget call:
(defun GetBlockSelectionSet ( name / ss ) (vl-load-com)
  (if (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 (strcat name ",`*U*")))))
      (lambda ( i / e )
        (while (setq e (ssname ss (setq i (1+ i))))
          (if (not (eq name (vla-get-EffectiveName (vlax-ename->vla-object e))))
            (ssdel e ss)
        ss
      -1
Then in your code:
(foreach item '("CLIENT2_8x11" "CLIENT2_22X34")
  (if (setq ss (GetBlockSelectionSet item))
BuckoAk
« Reply #3 on: November 16, 2010, 10:58:24 PM »
Thank you very much Lee Mac
I added it to the rest of my code and It works great!
« Reply #4 on: November 17, 2010, 10:11:13 AM »
Good to hear mate  :-)
alanjt
  • Standby for witty remark...
« Reply #5 on: November 17, 2010, 10:30:46 AM »
I would study Lee's code and try and implement the procedure, rather than just issuing the sub. Right now, you are executing ssget on every `*U* block for each given name - extremely inefficient. Use his method, make one selection with ssget, then filter accordingly and use cond to make appropriate modifications.
Dropbox
« Reply #6 on: November 17, 2010, 10:45:50 AM »
Completely agree - minimise the number of iterations through the same items.
alanjt
« Reply #7 on: November 17, 2010, 10:49:28 AM »
Precisely.
Dropbox
BuckoAk
« Reply #8 on: December 20, 2010, 10:39:28 PM »
I understand what your saying, Now only if I could count on my users to implement the tool the way is was originally intended (by selection).
It gets to be a hassle at submittal time when things are not printing correctly, the main code is only being seen on certain times.
As it stands the code is saving me a lot of hassle and barley puts a dent in processor overhead.
Harrie
« Reply #9 on: February 03, 2011, 04:55:02 AM »
      (lambda ( i / e )
            (ssdel e ss)
        ss
      -1
Then in your code:
Dear Lee Mac and BuckoAk,
What is wrong, when I do a test in the drawing DynBlkTest.dwg I get a wrong result.
Regards Harrie.
      (lambda ( i / e )
            (ssdel e ss)
        ss
      -1
(defun C:test(/ )
(princ "\n***************************Test*********************************************")
(princ "\n*******In drawing DynBlkTest.dwg I count 12 Cars and 6 Trees****************")
(princ "\n****************************************************************************\n")
(princ "\n****************************************************************************")
(princ "\n************************Test Results****************************************")
(setq S nil S (GetBlockSelectionSet "Car"))
(setq SL (sslength s))
(If (= SL 12)
(princ "\nThis result is good, because the selection set for the block 'Car' Counts 12")
(princ (strcat "\nThis result is wrong, because the selection set for the block 'Car' Counts " (itoa SL)))
(setq S nil S (GetBlockSelectionSet "Tree"))
(If (= SL 6)
(princ "\nThis result is good, because the selection set for the block 'Tree' Counts 6")
(princ (strcat "\nThis result is wrong, because the selection set for the block 'Tree' Counts " (itoa SL)))
(textpage)
« Last Edit: February 03, 2011, 06:43:02 AM by Harrie »
fixo
« Reply #10 on: February 03, 2011, 05:56:58 AM »
Try this
(defun getblocksbyname (bname / ss)
      (list (cons 0 "INSERT") (cons 2 (strcat bname ",`*U*")))))
    (vl-remove-if
      '(lambda (blk) (not (eq bname (vla-get-effectivename blk))))
      (mapcar 'vlax-ename->vla-object
      (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
;;;Use:
(alert (strcat " Selected: "(itoa (length(getblocksbyname "Car")))" blocks \"Car\""));<-case-sensitive
Harrie
« Reply #11 on: February 03, 2011, 06:49:35 AM »
Try this
    (vl-remove-if
;;;Use:
Thanks Fixo,
(alert (strcat " Selected: "(itoa (length(getblocksbyname "Car")))" blocks \"Car\""))and
(alert (strcat " Selected: "(itoa (length(getblocksbyname "Tree")))" blocks \"Tree\""))gives a good result in DynBlkTest.dwg.
Regards Harrie.
« Last Edit: February 03, 2011, 08:23:49 AM by Harrie »
fixo
« Reply #12 on: February 03, 2011, 07:06:47 AM »
Glad, if so
Cheers :)
Harrie
« Reply #13 on: February 03, 2011, 07:10:17 AM »
Dear Fixo,
But how I get the selection set?
I want to change the Visibility State in PROPERTIES.
Is this the correct way:
(defun GetBlocksByName2 (bname / ss)
  (if (setq ss
    (ssget "_X"
      (setq SSLst
    (vl-remove-if
      '(lambda (blk)
 (not (eq (strcase bname) (strcase (vla-get-effectivename blk))))
      (setq i  0
   ss nil
   ss (ssadd)
      (repeat (length SSLst)
(setq ss (ssadd (vlax-vla-object->ename (nth i SSLst)) ss))
(setq i (1+ i))
ss
and for drawing DynBlkTest.dwg with dynamic block Tree
(alert (strcat " Selected: "(itoa (sslength (GetBlocksByName2 "Tree")))" blocks \"Tree\""))and
(command "_.SELECT" (GetBlocksByName2 "Tree"))and
(command "_.PSELECT" (GetBlocksByName2 "Tree") "")Regards Harrie.
« Last Edit: February 04, 2011, 06:58:24 AM by Harrie »
« Reply #14 on: February 03, 2011, 10:39:43 AM »
Look into sssetfirst:
(defun getblocksbyname2 (bname / obj ss ss2)
  (setq ss2 (ssadd))
  (if (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 (strcat bname ",`*U*")))))
    (foreach blk (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (setq obj (vlax-ename->vla-object blk))
      (and (eq (strcase bname) (strcase (vla-get-effectivename obj))) (setq ss2 (ssadd blk ss2)))
  (sssetfirst nil ss2)
« Last Edit: February 03, 2011, 10:42:54 AM by ronjonp »
