I was off topic here:
http://www.theswamp.org/index.php?topic=34277.msg409429#msg409429 so as promised I will ask again.
Basically this is the question: Is there a way to retrieve a blocks insertion point when the block itself is in an xref?
And if possible, can that be done multiple times, for when there are 100 block in the xref?
At this point I have some routines that place blocks over other blocks, using the insertion points to insert and align.
All works nice and there are no problems besides some extra "handling": when "done" I only need to "copy and paste" the newly created blocks into a clean *.dwg.
What I do is lock all the layers that do not contain any of my new blocks, use [ctrl]+[shift]+[c] to copy with a basepoint.
Opening a new *.dwg and paste with basepoint.
I thought when having the clean *.dwg and attaching the *.dwg with all the blocks would be a faster way, just need to attach / detach the xref.
That's why my question came up. But I do not know if it can be done, for the solutions I can make start with "
Nentsel".
This only returns the data of a nested entity but not of a block...
I am not asking for code, at least not yet, but only for some info where to look or what to look for.
Thank you in advance for helping me out.
