Author Topic: Pipe Network Quantities (C3D 2008)  (Read 2884 times)
dfarris75
« on: November 11, 2010, 11:24:58 AM »
Is there a way to export pipe network quantities to a .xls, .csv, .txt, etc. file (from C3D 2008)? It's been a looong time since I swam in the c3d pool and I don't recall if this can be done. I thought I could just do a pipe table and export it to .csv, but that option is not available in a c3d based table apparently.
Please advise.
Re: Pipe Network Quantities (C3D 2008)
« Reply #1 on: November 11, 2010, 11:30:10 AM »
open the toolbox
there should be a couple of usable pipe reports....
also explore SAMPLE LINE GROUP and Quantity Take Off procedures
dfarris75
« Reply #2 on: November 11, 2010, 11:32:25 AM »
Yeah I just found where to run a report on it. I don't like the way the report is set up though. Isn't there a way to modify the report template?
« Reply #3 on: November 11, 2010, 11:32:50 AM »
for a table there is a label style trick that will let one attach to the pipe...then drag label into table to keep dynamic link between the pipe and it's properties shown on a table
« Reply #4 on: November 11, 2010, 11:37:06 AM »
yeah sure....
you go now and LEARN how to format XML reports,
WAIT first go download and learn how to use a(n) XML Editor because autodesk didn't give us any kind of report generator.
Then you can create and format your own reports...
dfarris75
« Reply #5 on: November 11, 2010, 12:10:03 PM »
I found the file and figured it out!  NEENER NEENER! :-P
 :-D
