Author Topic: layer color  (Read 2141 times)
Andrea
layer color
« on: January 03, 2005, 09:49:14 PM »
Hi all...
I need to get the color of a specific layer in LISP...
any idea how ??
thanks.
Keep smile...
daron
layer color
« Reply #1 on: January 03, 2005, 11:46:01 PM »
Yeah, ask it in the proper forum. Nevermind, I'll move you to it. Hmm. How do you intend to get the info out of the layer? I believe the activex route makes it easier, but I can't look, don't have cad here. I'm sure dxf will give it to you if it's not bylayer. I believe the dxf value you would look for is 62. Someone correct me if I'm wrong.
layer color
« Reply #2 on: January 04, 2005, 01:35:56 AM »
This should give you the idea :
;;; return the item if existing, or nil
;;; kwb 20050104
(defun kbpf:safeitem (collection item / returnvalue)
  (if (not (vl-catch-all-error-p
             (setq returnvalue
                    (vl-catch-all-apply 'vla-item (list collection item)))
    returnvalue
;;; return the color of the named layer, or nil
;;; Does not allow explicitly for TrueColor RGB colors.
;;; kwb 20050104
(defun get_LayerColor (sLayerName / oLayer oColor)
  (if (setq oLayer (kbpf:safeitem
                     (vla-get-layers
                     sLayerName
    (setq oColor (vla-get-color oLayer))
  oColor
;;; kwb 20050104
(defun c:test (/ result)
  (foreach sLayerName '("0" "DoesNotExist")
    (if (setq result (get_LayerColor sLayerName))
      (alert (strcat "Color for Layer '" slayerName "' : " (itoa result)))
      (alert (strcat "Color for Layer '" slayerName "' : undetermined "))
Andrea
layer color
« Reply #3 on: January 04, 2005, 08:23:16 AM »
thanks. Kerry,
I've modified the routine for my use and it work well.
Keep smile...
