Author Topic: newbie question: COND limits?  (Read 9388 times)
CHulse
Re: newbie question: COND limits?
« Reply #30 on: November 12, 2010, 07:24:04 PM »
I thought it'd be better to provide hints than to just give the complete code  :-)  But maybe some of my hints aren't too clear :-(
Believe me, I appreciate it. Hints are best (usually) as it actually helps me learn :)
The clarity issue is that I have been up since about 3am  :ugly: , not your hints
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
CHulse
« Reply #31 on: November 12, 2010, 07:25:00 PM »
Ok, but now I get this:
** Error: bad function: "BOTANICAL" **
(setq atlist (("ID" tnum)("BOTANICAL" species)("COMMON" common)("CULTIVAR" cultivar)("DBH" dbh)("CONDITION" condition)("UNIQUEID" unique)("STEMS" stem)))
(foreach att (vlax-invoke obj 'GetAttributes)
            (if (setq attval (cadr (assoc (strcase(vla-get-TagString att)) atlist)))
               (vla-put-TextString att attval)))
Cary Hulse
« Reply #32 on: November 12, 2010, 07:31:50 PM »
You are getting closer, well done  :-)
The problem is that the list needs to be constructed using the proper functions, as it cannot be taken as a literal.
To be taken as a literal, (i.e. not evaluated), an apostrophe must be used, but, in your case, you cannot use this method as you need to evaluate the variables within your list.
The error occurs because elements of your list are interpreted as function expressions, e.g.
Is attempting to evaluate "BOTANICAL" as a function, which, of course, it is not.
To construct the list, look into using the list function, (and cons function if you want to use a dotted pair)
CHulse
« Reply #33 on: November 12, 2010, 07:44:38 PM »
ok, I think I have it now - a list of lists...
(setq atlist (list
        (list "ID" tnum)(list "BOTANICAL" species)(list "COMMON" common)(list "CULTIVAR" cultivar)(list "DBH" dbh)
        (list "CONDITION" condition)(list "UNIQUEID" unique)(list "STEMS" stem)))
But this seems messy - would there be a better/cleaner way?
Cary Hulse
« Reply #34 on: November 12, 2010, 07:47:52 PM »
Excellent - good job  :-)
Yes, it could be done with mapcar:
(setq atlist
  (mapcar 'list
   '("ID" "BOTANICAL" "COMMON" "CULTIVAR" "DBH" "CONDITION" "UNIQUEID" "STEMS")
    (list tnum species common cultivar dbh condition unique stem)
There may be also a cleaner way to obtain your original variables, perhaps making the above even more concise. :-)
CHulse
« Reply #35 on: November 12, 2010, 07:50:25 PM »
Cool. Asside from looking cleaner, would MAPCAR run faster? That is one I still have some trouble grasping...
Well, again, thanks for your help and hints. Much appreciated :)
I still need to drive 2 hours to get home, so have a good weekend.
Cary Hulse
CHulse
« Reply #36 on: November 12, 2010, 07:53:14 PM »
Using your STRBRK function, I have this:
(WHILE (setq line (CAR *lst*))
        (setq ;; method by FIXO @ CadTutor
          tnum (ATOF (nth 0 line))
          ;;common (nth 1 line)
          species (nth 1 line)
          cultivar (nth 2 line)
          dbh (atof (nth 3 line))
          condition (nth 4 line)
          x (atof (nth 5 line))
          y (ATOF (nth 6 line))
          unique (nth 7 line)
          stem (nth 8 line)
          crz (ATOF (nth 9 line))
          photo (nth 10 line)
        );_end of setq
to establish the vars from a csv file input.
Cary Hulse
« Reply #37 on: November 12, 2010, 07:56:04 PM »
I doubt there would be much difference, perhaps mapcar may be slightly faster, but I would think the difference would be negligible.
As for understanding, here is a brief explanation I wrote a while back:
http://www.cadtutor.net/forum/showthread.php?52127-Mapcar-lambda-Description&p=353101&viewfull=1#post353101
You're welcome - have a good weekend yourself too  :-)
« Reply #38 on: November 12, 2010, 07:59:41 PM »
I can't give a complete answer, as I don't know how the variables are used elsewhere in the code, but, I would have thought that if you are dealing with attributes, you would want to deal in strings alone.
With that in mind, perhaps something similar to this may merge the two operations:
(while (setq line (car *lst*))
  (setq atlist (mapcar 'list '("ID" "BOTANICAL" ... ) line))
Lee
« Reply #39 on: November 12, 2010, 08:10:08 PM »
Some more food for thought (apologies in advance: I did not read the entire thread, hope the following fits):
(setq vars '(tnum species cultivar dbh condition x y unique stem crz photo))
    (mapcar 'set vars line)
    ;; perform any additional variable refinement
    ;; I'm suggesting the distof function rather than atof
    ;; however, I've not read the rest of the thread so its
    ;; use may not necessarily be the most appropriate
    ;; also note additional defensive coding may be applicable
    ;; regardless distof or atof function usage
    (mapcar
       '(lambda ( var ) (set var (distof (eval var))))
       '(tnum dbh x y crz)
    ;;  carry on and do other stuff
    ;;  remember to modify the *lst* variable or you'll have an infinite loop
    (setq *lst* (cdr *lst))
« Reply #40 on: November 12, 2010, 08:18:10 PM »
.. additional defensive coding may be applicable
now, there's a concept that could fill a couple of chapters. !
« Reply #41 on: November 12, 2010, 11:50:53 PM »
Another variation, for example only.
  (setq vars '("ID" "BOTANICAL" "COMMON" "CULTIVAR" "DBH" "CONDITION" "UNIQUEID" "STEMS"))
  (setq atlist
           (mapcar '(lambda (var)
                      (list var
                              ((vl-position var '("ID" "DBH" "STEMS"))
                               (distof (eval (read var))))
                              ((eval (read var)))
                             ))) vars)
CHulse
« Reply #42 on: November 14, 2010, 09:09:24 AM »
Lee
After you mentioned MAPCAR, I thought of something liike that, but not all the vars are used to populate attribs, x and y are a point, some are dynamic functions and one is a path for the hyperlink.
Thanks to everyone  - plenty of "food for thot" (if you like Dr John)...
It works as is, but I will continue to refine it just to help me learn some other methods.
Cary Hulse
CHulse
« Reply #43 on: November 14, 2010, 09:25:45 AM »
Ok, would someone like to explain this a bit more...? :)
Cary Hulse
« Reply #44 on: November 14, 2010, 09:29:53 AM »
Google is your friend  :-)
http://en.wikipedia.org/wiki/Defensive_programming
