Author Topic: Need help--How can I separate mass overlapping text?  (Read 3783 times)
xiaxiang
« on: November 09, 2010, 02:04:00 AM »
Just thought I would throw this one out there, in the hope someone may have some clever way to separate masses of single overlapping text.
Thanks a lot!
Maybe this one
« Last Edit: November 11, 2010, 04:54:59 AM by xiaxiang »
roy_043
  • BricsCAD 18
Re: Need help--How can I separate mass overlapping text?
« Reply #1 on: November 09, 2010, 04:37:43 AM »
When you say "separate" what do you mean?
What differentiates the current text entities?
xiaxiang
« Reply #2 on: November 09, 2010, 04:46:17 AM »
Maybe "Automatically avoid"
huiz
  • Certified Prof C3D
« Reply #3 on: November 09, 2010, 05:34:29 AM »
If the overlapping texts contain the same text and closely share the same insertion point, you can use the command OVERKILL to remove duplicates.
roy_043
  • BricsCAD 18
« Reply #4 on: November 09, 2010, 05:42:46 PM »
@ xiaxiang: What scenario would result in "masses of single overlapping text"?
cmwade77
« Reply #5 on: November 09, 2010, 08:00:47 PM »
I can think of a few ways that this can happen. I too want to know more about what needs to be accomplished though to provide a decent suggestion.
xiaxiang
« Reply #6 on: November 09, 2010, 09:15:34 PM »
When Translating from one language to another
roy_043
  • BricsCAD 18
« Reply #7 on: November 10, 2010, 02:32:07 AM »
That's a very short scenario... Please be more specific.
« Reply #8 on: November 10, 2010, 08:24:42 AM »
Perhaps posting a sample drawing would help.
roy_043
  • BricsCAD 18
« Reply #9 on: November 11, 2010, 01:29:02 PM »
@ xiaxiang: Judging by the edit of your first post, you have solved it yourself. Great! Did you already have this code when you first posted and was this topic perhaps intended as a challenge?
xiaxiang
« Reply #10 on: November 11, 2010, 07:34:40 PM »
I have this one,but This is not a program to my satisfaction.Certainly someone has a better routine.
cmwade77
« Reply #11 on: November 12, 2010, 11:25:42 AM »
What do you not like about this routine? It might help with coming up with a better one.
