Author Topic: Extract an attribute value from a block  (Read 12580 times)
diarmuid
« on: November 05, 2010, 06:02:24 AM »
I have 300 titleblocks that have a drawing number in them.  These titleblocks do not match the actual filename. I been asked to save the drawing as the drawing number in the titleblock which is an attribute.  no, my lisp is not great but i am trying to lift this info via an ssget funtion
so
(setq ax1 (ssget "x"  (100 . "AcDbAttribute") (2 . "DRAWING_NO")))
Where the "DRAWING_NO" is the actual value i will assign to a value and get lisp to do a "save as" to another location
Diarmuid
If you want to win something run the 100m, if you want to experience something run a marathon
David Bethel
Re: Extract an attribute value from a block
« Reply #1 on: November 05, 2010, 06:21:33 AM »
You can't ssget attributes like you can other entities.  You will need to make a pickset of the titleblock inserts, and then step thru the set looking for the tagname of the attribute
This could be a starting point:
(defun c:ps-tagvl (/ tag val ps i ss en an ad)
  (while (or (not tag)
             (not (snvalid tag)))
         (setq tag (strcase (getstring "\nTag Name:   "))))
  (while (not val)
         (setq val (strcase (getstring t "\nAttrib Value ( Not Case Sensitive) :   "))))
  (and (setq ps (ssadd)
              i -1
             ss (ssget "X" '((0 . "INSERT")(2 . "TITLEBLOCK")(66 . 1))))
       (setq en (ssname ss (setq i (1+ i)))
             an (entnext en)
             ad (entget an))
       (while (= "ATTRIB" (cdr (assoc 0 ad)))
              (and (= tag (strcase (cdr (assoc 2 ad))))
                   (= val (strcase (cdr (assoc 1 ad))))
                   (not (ssmemb en ps))
                   (ssadd en ps))
              (setq an (entnext an)
                    ad (entget an))))
  (eval ps))
This make a pickset ( ps ) of matching tagnames and attribute values.  -David
R12 Dos - A2K
« Reply #2 on: November 05, 2010, 06:32:01 AM »
Just for something different to play with ..
(setq Border-Number-Attribute-Value (cdr (assoc 1 (entget (car (nentsel "Select File Number Attribute"))))))
This should return the value of the attribute you select.
« Reply #3 on: November 05, 2010, 06:41:40 AM »
.. or if all the borders have the same name and ate attribute is always named "DRAWING_NO"
there is an easier way.
What is the border block name ??
diarmuid
« Reply #4 on: November 05, 2010, 07:06:58 AM »
thanks for the replies guys,
The tileblock name is (for all of them)
amw_title
again, i was clearly barking up the wrong tree  :laugh:
« Reply #5 on: November 05, 2010, 07:08:48 AM »
.. for instance :
;; Library code
(defun getattributes (objselection)
  (if (= (type objselection) 'ename)
    (setq objselection (vlax-ename->vla-object objselection))
  (if (= (vla-get-hasattributes objselection) :vlax-true)
    (mapcar
      '(lambda (x) (cons (vla-get-tagstring x) (vla-get-textstring x)))
      (vlax-safearray->list (variant-value (vla-getattributes objselection)))
Test Code
(defun c:doit ()
  (setq Block-Name     "amw_title"
        Attribute-Name "DRAWING_NO"
  (if (and (setq Border-Blocks (ssget "X" (list (cons 2 Block-Name))))
           (setq Attribute-List (getattributes (ssname Border-Blocks 0)))
           (setq Attribute-Value (cdr (assoc Attribute-Name Attribute-List)))
    (progn (alert Attribute-Value)
           ;; .. save the drawing with the contents of Attribute-Value
« Reply #6 on: November 05, 2010, 07:40:06 AM »
of course, I'm not suggesting for a moment that David's solution is anything other than perfect :)
.. this is just another way to skin the problem.
« Reply #7 on: November 05, 2010, 07:42:07 AM »
To save processing all attributes, I would sometimes use this:
;;----------------=={ Get Attribute Value }==-----------------;;
;;  Returns the attribute value associated with the specified ;;
;;  tag, within the supplied block, if present.               ;;
;;  Author: Lee McDonnell, 2010                               ;;
;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
;;  Arguments:                                                ;;
;;  block - VLA Block Reference Object                        ;;
;;  tag   - Attribute TagString                               ;;
;;  Returns:  Attribute TextString, else nil                  ;;
(defun LM:GetAttributeValue ( block tag )
  ;; © Lee Mac 2010
  (vl-some
    (function
      (lambda ( attrib )
        (if (eq tag (vla-get-Tagstring attrib))
          (vla-get-TextString attrib)
    (vlax-invoke block 'GetAttributes)
Example:
(defun c:test ( / ent )
  (if (setq ent (car (entsel "\nSelect Attributed Block: ")))
    (princ
      (LM:GetAttributeValue
        (vlax-ename->vla-object ent) (strcase (getstring "\nSpecify Tag String: "))
« Reply #8 on: November 05, 2010, 07:45:18 AM »
Lee
If you're going to ask the user for input
ie
and
it would be much better to just use Nentsel as per my first example.
.. a simple one liner.
« Reply #9 on: November 05, 2010, 07:53:04 AM »
Lee
ie
and
'Twas purely example code to show how to call the function - it could be used without any user input at all :-)
diarmuid
« Reply #10 on: November 05, 2010, 08:16:20 AM »
Thanks for the input guy's really appreciate it.
When i run the code i get
Select Attributed Block: ; error: no function definition: VLAX-ENAME->VLA-OBJECT
thanks for this, it been Friday n'all
Diarmuid
diarmuid
« Reply #11 on: November 05, 2010, 08:20:37 AM »
hold the phone, i see now where i screwed up!!!!!
that'll learn me :ugly:
« Reply #12 on: November 05, 2010, 11:49:06 AM »
If you don't mind losing the preview of the drawing, then you can do something like this ( not tested, but should work, so test before ).
(function
    (lambda ( x / BlkName AttTag DwgName OldPath )
        (setq BlkName "EnterBlockName")
        (setq AttTag "EnterAttributeTag")
        (vlax-for lo (vla-get-Layouts x)
            (vlax-for obj (vla-get-Block lo)
                    (and
                        (= (vla-get-ObjectName obj) "AcDbBlockReference")
                        (= (vla-get-Name obj) BlkName)
                    (foreach att (vlax-invoke obj 'GetAttributes)
                        (if (= (vla-get-TagString att) AttTag)
                            (setq DwgName (vla-get-TextString att))
        (if DwgName
                (setq OldPath (vla-get-Name x))
                (vla-SaveAs x (strcat (vl-filename-directory OldPath) DwgName ".dwg"))
                (vl-file-delete OldPath)
In-conjunction with one of these.
[ http://www.theswamp.org/index.php?topic=29933.0 ] - by me
[ http://www.theswamp.org/index.php?topic=31827.0 ] - by Lee
MPD
  • Mosquito
« Reply #13 on: June 01, 2022, 01:55:09 AM »
lee its a great lisp
Is there a way to export the value as a field?
;;  Arguments:                                                ;;
  ;; © Lee Mac 2010
  (vl-some
    (function
      (lambda ( attrib )
Example:
    (princ
