Author Topic: Publish Using DWG to PDF.pc3 AND Suppress Filename Prompt  (Read 3349 times)
M-dub
  • SuperMod
  • I'm never sarcastic...
« on: November 04, 2010, 09:48:04 am »
I didn't think this was as difficult as it's proving to be.  Maybe I was using a different pdf printer.
How do I do it with DWG to PDF?  Anyone know?
Mike Williams | AutoCAD and Raster Design 2012 | Synergis Adept | Windows 7
M-dub
  • SuperMod
Re: Publish Using DWG to PDF.pc3 AND Suppress Filename Prompt
« Reply #1 on: November 04, 2010, 10:14:37 am »
Found it.   :loco:
In the Publish window, hit Publish Options... button and the first option (Default output location (DWG and plot-to-file)) is the one.
mary
« Reply #2 on: April 21, 2011, 08:26:14 pm »
Just saw your post and would like to share with you, that I am running AutoDWG which converts my drawings into PDF file format with easy steps, no more struggle with AutoCAD, I downloaded it from here: http://www.autodwg.com/PDF/
  • Don't be so open-minded that your brains fall out.
« Reply #3 on: April 21, 2011, 09:24:21 pm »
Does it perform hidden line removal / hidden line substitution, and if so, with the same degree of fidelity?
\|// Set goal. Experiment tirelessly until
|oo| practice has become expertise.  Loop.
|- | Dropbox | O'Reilly School | UltraEdit
huiz
  • Certified Prof C3D
« Reply #4 on: April 22, 2011, 02:00:42 am »
I thought there is also an option in AutoCAD to automatically save a pdf and/or dwf everytime you save the dwg.
  • Mesozoic Relic
« Reply #5 on: April 22, 2011, 02:47:01 am »
Not that I know of
... and I'd have it disabled if there was :)
Discipline : absolutely none at all.
--> Donate to TheSwamp <--
  • Mesozoic Relic
« Reply #6 on: April 22, 2011, 03:05:02 am »
Mike,
attached is what I do :
This is intended to run from a toolbar button per drawing, not through publisher :)
Note that I haven't modified the code, so you may want to.
I extract the revision number from the border and append it to the base file name.
The PlotConfigurations are deleted and replaced from a template drawing ...  not critical
A folder is made under the Drawing Folder
The PDF is created there.
;;; CodeHimBelonga kdub@theSwamp
;;; (c:DWGToPDF_A1)
(defun C:DWGToPDF_A1 (/ old-expert rev_value PDFPath dwgname PDFName)
  (DeleteAllPlotConfigurations)
  (setq old-expert (getvar "EXPERT"))
  (setvar "EXPERT" 5)
;; (or (kdub:stringprintable-p (setq rev_value (_getBorderRevision)))
;;      (setq rev_value "--")
;; Workaround for forum posting
  (setq PDFPath (strcat (getvar "DWGPREFIX") "PDF\\")
        dwgname (vl-filename-base (getvar "DWGNAME"))
        PDFName (strcat PDFPath dwgname "[REV " rev_value "].PDF")
  (vl-mkdir PDFPath)
  (if (and (vl-cmdf "-psetupin"
                    "C:/kdub_SteelTools/BLOCKS/_PLOT_Template_2011.DWG"
           (vl-cmdf "-plot"       "no"          "Model"       "DWGToPDF_A1"
                    "DWG To PDF.pc3"            PDFName       "No"
                    "yes"
    (princ (strcat "PDF File Created: " PDFName))
    (princ "Failed to create PDF File ")
  (setvar "EXPERT" old-expert)
(defun DeleteAllPlotConfigurations ()
  (vlax-for ps (vla-get-plotconfigurations
                 (vla-get-activedocument (vlax-get-acad-object))
    (vla-delete ps)
« Last Edit: April 22, 2011, 03:10:45 am by Kerry »
Jeff H
« Reply #7 on: April 22, 2011, 04:22:17 am »
Would Automatic Publish and set for Save work?
« Last Edit: April 22, 2011, 05:46:19 am by Jeff H »
huiz
« Reply #8 on: April 22, 2011, 06:13:43 am »
Not that I know of
That 's what I was talking about. Automatic publish will save a PDF each time you save the drawing.
I have disabled it but I can imagine other people like the option.
Krushert
« Reply #9 on: April 22, 2011, 07:34:02 am »
Not that I know of
Thanks for letting me know about that one.  And Yes I have disabled it for my users.   :evil:
=   =   =  Just another Inquisitive REVIT Idiot running around with Scissors =   =   =   =
Remember folks, these articles are supposed to be fun. Don’t do anything stupid.
=   =   =  ACA 2011 and Revit Arch 2012 on 64bit on Win7P  =   =   =   =
rkmcswain
« Reply #10 on: April 22, 2011, 07:59:08 am »
...and if you use Sheet Set Manager, you can print to any output format including PDF without any prompts.
