Author Topic: Strange Printing Related Crash  (Read 16496 times)
M-dub
« on: November 02, 2010, 09:11:47 AM »
I've got a number of drawings that are giving me trouble.  Originally, I was trying to publish a bunch of drawings to PDF.
When I add the files one by one, some of them come in ok, but others cause a fatal error.  I tried opening the drawings that cause the crash, which I'm able to do... I can open them, audit (finds no errors) and print them, but if I try to do a preview and come back to the plot window (right click, exit), it crashes.  Same result as when I'm adding the files to be published.
FATAL ERROR:  Unhandled e06d7363h Exception at 7c812afbh
Any ideas?  I've repaired my AutoCAD installation and even tried AutoCAD 2011 with the same results.  I'm wondering if it's even AutoCAD that's causing the crash... something that's common to both versions.  .Net, maybe?
Re: Strange Printing Related Crash
« Reply #1 on: November 02, 2010, 09:16:15 AM »
run regedit and look for this entry:
[HKEY_CURRENT_USER\Software\autodesk\AutoCAD\R18.0​\ACAD-8000:409\WebServices\CommunicationCenter]
"LastUpdateTimeLoWord"=dword:4be447d0
Changing the dword to 00000000 solved the problem
M-dub
« Reply #2 on: November 02, 2010, 09:40:36 AM »
No such luck.  :(
Jeff H
« Reply #3 on: November 02, 2010, 09:49:58 AM »
Have you tried creating a new user and see if it works under that profile?
« Reply #4 on: November 02, 2010, 09:56:09 AM »
is this a NEW installation?
is your \TEMP folder EMPTY?
M-dub
« Reply #5 on: November 02, 2010, 01:18:25 PM »
Tried a different profile with the same result.
Existing installation, but I don't know when the problem started.  (Wondering if it was a Windows Update or something...)
I attempted to repair this installation and doing that allowed me to get further than I could before the repair, but didn't solve the problem completely.
The temp folder is now empty and after a reboot, the problem still exists.  I'm going to look into the windows updates... maybe see what was done to .NET Framework recently.
« Reply #6 on: November 02, 2010, 01:37:24 PM »
my research suggests it appears from nowhere in mos all versions and products....and then it either goes away...or the user does
drizzt
« Reply #7 on: November 02, 2010, 02:37:19 PM »
I had the same problem. I started using Acrobat distiller for a couple of plots and that seems to have fixed "DWG to PDF" plotter
M-dub
« Reply #8 on: November 02, 2010, 02:44:30 PM »
I don't know what's going on...
When I print the drawings without doing a preview, everything is ok.  It's when I am on my way back out of a print preview (right click - Exit OR Plot) when it crashes.  It doesn't matter if I've got a printer, plotter or DWG to PDF selected.  They all crash on the same action... coming out of the preview.
Matt__W
  • I like my water diluted.
« Reply #9 on: November 02, 2010, 03:00:03 PM »
That's about as helpful as a kick in the family jewels.
Dub!  He has a solution.  Just go away!   :-)
Autodesk Expert Elite
M-dub
« Reply #10 on: November 02, 2010, 03:03:07 PM »
Yeah, but that causes all sorts of other problems.  I don't like that option.
"Hey boss, I quit... print preview keeps crashing my computer."
Matt__W
« Reply #11 on: November 02, 2010, 03:03:54 PM »
I've seen AutoCAD crash when using publish to plotter (Sheet Set Manager).  The issue was resolved after cleaning the drawing and/or xrefs.
Try running RECOVERALL on the offending drawings.
M-dub
« Reply #12 on: November 02, 2010, 03:10:56 PM »
Negatory on that one.
0 errors
An annoyance of this type is certain to induce twitching of the angry sort.
Rob...
« Reply #13 on: November 02, 2010, 03:14:34 PM »
Are there any attributes that are not associated with blocks?
CAD Tech
M-dub
« Reply #14 on: November 02, 2010, 03:28:33 PM »
There were (and I had JUST found them before I read your post).  I deleted them, saved and tried again with the same result.  I've even deleted EVERYTHING from the dwg and still... same.
Don't know.
