Author Topic: labels along alignment and profile  (Read 17937 times)
drizzt
« on: October 28, 2010, 03:05:18 PM »
Ok, I am getting started on creating styles for the office. I am having a problem getting started on creating a label as in the attached pdf. I want to be able to pick a point along an alignment, like at the beginning of the riprap pad. I want the label to have the line like I have in the attached with STA, Elevation, and the option to enter the additional text like "begin riprap pad.
Can anyone help me get started.
Re: labels along alignment and profile
« Reply #1 on: October 28, 2010, 03:08:01 PM »
Alignment Labels
Station and Offset
Create NEW
go to label style composer
Add a LINE Component
then Add the Label Components attached to the line you added first
drizzt
« Reply #2 on: October 28, 2010, 03:09:24 PM »
but, will the line be perpindicular to the alignment?
« Reply #3 on: October 28, 2010, 03:13:35 PM »
the Begin End feature text could also be defined as a(n)  EXPRESSION and have that added to the label
« Reply #4 on: October 28, 2010, 03:14:11 PM »
Depends on the rotation and the anchor conditions you set for that line...in the style
drizzt
« Reply #5 on: October 28, 2010, 03:19:51 PM »
right! so I set the line to be perpindicular and the test to align with the line... got it. Let's see if I can do it
« Reply #6 on: October 28, 2010, 03:24:00 PM »
I know you can...
drizzt
« Reply #7 on: October 28, 2010, 03:36:17 PM »
ok, I get the line in, but it anchors to the text. I can't figure out how to anchor it to the Anchor Station, as in the geometry point label style "perpindicular with tick".
Should I be starting with perpindicular with tick?
« Reply #8 on: October 28, 2010, 03:47:08 PM »
No you should start with either GENRAL NOTE style that references the alignment
or Station and Offset Label as stated in first response..
« Reply #9 on: October 28, 2010, 03:57:14 PM »
Actually If I understand what you are after...a General Note style set up for this is probably going to prodce the best result easiest.
the WHITE one is a General Note
the Red one an alignment Station/Offset
« Last Edit: October 28, 2010, 04:06:30 PM by Anti Quark »
C3D_User
« Reply #10 on: October 28, 2010, 07:18:22 PM »
Drizz....see attached file, this should get you what you want.
K
« Reply #11 on: October 28, 2010, 07:20:57 PM »
K
I couldn't post one for him...there are version issues... (2010 right drizzt?)
drizzt
« Reply #12 on: October 29, 2010, 10:46:06 AM »
Yes, I am using 2010.
C3D_User. that is almost exactly what I want. I just want the text line to touch the alignment. Which I think I can fix.
Now, I created a General Note style for my profiles, but my station and elevation have ???. See attached pdf for style in use. I have attached a dwt with the style I created. It is in general / label styles / KRW_Sta Text field Elevation.
I must give credit to C3D_User for most of the attached dwt
What did I do wrong?
« Reply #13 on: October 29, 2010, 10:49:48 AM »
you lost the connection to; or did not select the REFERENCE alignment/profile that the note is using....
I think you can reset that in properties...
it may also be a persistent issue with reference text in labels.....
« Reply #14 on: October 29, 2010, 10:58:07 AM »
Seeing how this label will be employed....
a more reliable method might involve some 'trickery'
I would insert a fictional PVI into the design profile....and then add a SPECIAL * Geometry Point Label * to it.
Same for the Hoizontal alignment.
