Author Topic: insert value into attribute  (Read 8404 times)
Pad
« on: October 25, 2010, 10:32:53 AM »
Hello
I wish to insert a stored variable (which happens to be text) into an attributed block, the attribute tag is 'height'.
I also wish to add a prefix of 'H: ' to the stored variable.
I can do the second bit by:
(SETQ HT1 (STRCAT "H: " HT))
this is the lisp I have at the moment.
The block has 7 attributes and the height attribute is the 6th.
A quick hand with this would be appreciated.
I need to change this part:
(COMMAND "text" PTXT THGT "<<0" HT2)
(command "move" "last" "" PTXT pause)
so that 'HT2' is inserted into the attributed block
(defun C:TH()
(setq ent1 (car (entsel "\nPick the Tree Level:"))); single pick
(setq ent4 (car (entsel "\nPick the Height Level:"))); single pick
(if ent1
(setq elist1 (entget ent1)); get a List of that entity
(setq atr1 (entnext ent1)); get 1st attribute entity
(setq en1 (entget atr1)); get a List of attribute entity
(setq val1 (cdr (assoc 1 en1))); get the attrib's value
(setq num1 (atof val1)); make a number of val
(if ent4
(setq elist4 (entget ent4)); get a List of that entity
(setq atr4 (entnext ent4)); get 1st attribute entity
(setq en4 (entget atr4)); get a List of attribute entity
(setq val4 (cdr (assoc 1 en4))); get the attrib's value
(setq num4 (atof val4)); make a number of val
   (prompt (strcat "\nTREE LEVEL=" val1)); display on Command Line
   (prompt (strcat "\nHEIGHT LEVEL=" val4)); display on Command Line
(SETVAR "cmdecho" 0)
(COMMAND "units" "" 2 "" "" "" "")
  (setq HT (rtos (- num4 num1)))
(COMMAND "units" "" 3 "" "" "" "")
(SETVAR "cmdecho" 1)
   (prompt (strcat "\nTREE HEIGHT=" HT)); display on Command Line
 ); progn
 ); if
(SETQ DFLT 0)
(SETQ TXTHG (GETVAR "textsize"))
(PRINC "\nText Height: <")
(PRIN1 TXTHG)
(PRINC ">: ")
(SETQ THGT (GETDIST))
(IF (= THGT nil)
(SETQ THGT TXTHG)
;(SETQ ANNOT (GETSTRING "\nAnnotation: "))
(SETQ HT2 (STRCASE HT1))
;;(SETQ PTXT (GETPOINT "\nLocate Text: "))
(setq old_layer (getvar "clayer")); Get current Layer
(setq PTXT (getvar "viewctr"))
(COMMAND "layer" "se" "tree text" "")
;(COMMAND "text" PTXT THGT "<<0" HT2)
;(command "move" "last" "" PTXT pause)
(setq CLASHING "CLASHING_LEVELS")
(if (not (tblsearch "layer" CLASHING))
(command "_layer" "M" CLASHING ""); Make the Layer, and set it current
); if
(command "_change" ent4 "" "_P" "_LA" CLASHING "")
(command "_layer" "S" old_layer ""); reset Layer
))); function LEV2HT
cheers
P
« Last Edit: October 25, 2010, 10:42:31 AM by Pad »
Re: insert value into attribute
« Reply #1 on: October 25, 2010, 11:03:09 AM »
Are the Tag names for the attributes not constant?
Do you know them in advance?
Can you post a sample DWG with the two blocks in it?
« Reply #2 on: October 25, 2010, 11:05:49 AM »
Here is a OLD example using visual lisp.
;;  Room Number Update by CAB 03/21/2005
;;  Update selected blocks with attribute "ROOM#"
;;  with user entered room number
;;  NOTE: Very little error checking
;;   Modified a subroutine by Jeff Mishler 1/11/05
(defun c:rm#update (/ rm# attname ss count blk atts2 att2 att1 bc)
  (setq rm# (getstring t "\nEnter new room number: ")
        attname "RM#"  ; uppercase only
        bc 0) ; block counter
  (prompt "\n***  Select blocks to change room number.  ***")
  ;;  get only blocks with attributes
  (if (and rm#
           (not (eq rm# ""))
           (setq ss (ssget (list '(0 . "INSERT") '(66 . 1))))
      (setq count -1)
      (while (< (setq count (1+ count)) (sslength ss))
        (setq blk   (vlax-ename->vla-object (ssname ss count))
              atts2 (vlax-invoke blk "getattributes")
        (foreach att2 atts2
          (if (= attname (vla-get-tagstring att2))
              (vla-put-textstring att2 rm#)
              (vla-update att2)
              (vla-update blk)
              (setq bc (1+ bc))
      (prompt (strcat "\n-=< " (itoa bc) " blocked updated  >=-"))
    ) ; progn
    (prompt "\n---  No blocks Updated  ---")
  ) ; endif
) ; defun
(prompt "\nRoom Number Update Loaded, Enter Rm#Update to run.")
Pad
« Reply #3 on: October 25, 2010, 11:27:48 AM »
hi cab
thanks for your reply.
the tag is constant 'height'
attached is an example.
the tree canopies should look familiar to you  :-)
thanks for the example, but i do struggle to understand visual lisp.  But I will give it a study.
P
« Reply #4 on: October 25, 2010, 11:37:08 AM »
Perhaps this subfunction will help you along the way - using Vanilla:
;; block = Attributed Block Entity Name       [ENAME]
;; tag   = Tag of Attribute to set to value   [STR]
;; value = Value to which tag is set          [STR]
(defun SetAttribValue ( block tag value / el )
  (if (= 1 (cdr (assoc 66 (entget block))))
    (while
      (not
        (eq "SEQEND"
          (cdr
            (assoc 0
              (setq el
                (entget
                  (setq block (entnext block))
      (if (eq tag (cdr (assoc 2 el)))
        (entupd
          (cdr
            (assoc -1
              (entmod
                (subst
                  (cons 1 value) (assoc 1 el) el
;; Example
(defun c:test ( / en tg vl )
  (if (and (setq en (car (entsel "\nSelect Block: ")))
           (eq "INSERT" (cdr (assoc 0 (entget en))))
           (setq tg (getstring "\nSpecify Tag to Update: "))
           (setq vl (getstring t "\nSpecify New Value: "))
    (SetAttribValue en (strcase tg) vl)
I have also included an example of how to call the subfunction.
Pad
« Reply #5 on: October 25, 2010, 11:44:04 AM »
oh yeah, I reckon I can do something with that.
Cheers CAB!
P
Pad
« Reply #6 on: October 25, 2010, 12:00:08 PM »
yep got it working! brilliant stuff.
Pad
« Reply #7 on: October 25, 2010, 12:06:25 PM »
one other thing
at the top of the lisp i now have this:
(setq en (car (entsel "\nPick the Tree Level:"))); single pick
and I changed this bit to:
  (if (and ;(setq en (car (entsel "\nSelect Block: ")))
I would like to have the option to select the block again. ie:   (if (and (setq en (car (entsel "\nSelect Block: ")))
but only if the block originally picked is not a 'PT2' block.
Is that possible?
Ta
« Reply #8 on: October 25, 2010, 12:08:45 PM »
Cheers CAB!
P
Sorry Pad, are you referring to my code or CAB's?
Pad
« Reply #9 on: October 25, 2010, 12:10:50 PM »
Sorry Lee.
I had a silly monent and thought your code was posted by CAB.
Your code has done the trick!
Cheers Lee  :-)
David Bethel
« Reply #10 on: October 25, 2010, 12:15:34 PM »
Or maybe something I little older style wise:
  (princ "\nSelect INSERTs To Update....")
  (and (setq i -1 ss (ssget '((0 . "INSERT")(66 . 1))))
       (while (setq en (ssname ss (setq i (1+ i))))
              (setq an (entnext en)
                    ad (entget an)
                    ch nil)
              (while (= "ATTRIB" (cdr (assoc 0 ad)))
                     (and (= (strcase (cdr (assoc 2 ad))) "HEIGHT")
                          (setq ch T)
                          (entmod (subst (cons 1 ht1) (assoc 1 ad) ad)))
                     (setq an (entnext an)
                           ad (entget an)))
              (if ch (entupd en))))
R12 Dos - A2K
« Reply #11 on: October 25, 2010, 12:16:49 PM »
Sorry Lee.
Not a problem :-)
To answer your question, perhaps you could use a construct similar to this:
(defun c:test ( / en )
  (while
      (if (setq en (car (entsel "\nSelect Block: ")))
        (if (and (eq "INSERT" (cdr (assoc 0 (entget en))))
                 (= 1 (cdr (assoc 66 (entget en))))
                 (eq "PT2" (strcase (cdr (assoc 2 (entget en)))))
          (SetAttribValue en
            (strcase (getstring "\nSpecify Tag: "))
          (princ "\n** Please Select a PT2 Block! **")
I'm sure it could be coded in a number of ways  :-)
Pad
« Reply #12 on: October 25, 2010, 12:27:49 PM »
thanks.
I'll give that a go.
snownut2
  • Bricscad 22 Ultimate
« Reply #13 on: November 12, 2012, 07:29:39 PM »
    (while
      (not
        (eq "SEQEND"
          (cdr
            (assoc 0
              (setq el
                (entget
        (entupd
          (cdr
            (assoc -1
              (entmod
                (subst
;; Example
Lee,
I would like to not have to select the block, but to indicate it programmatically.  Have not had much success in that regard.
Bruce
« Reply #14 on: November 13, 2012, 08:31:44 AM »
Without knowing the entity handle of the block reference (for use with handent / vla-handletoobject), you would need to use an automated selection method such as using the ssget function with either the _W / _C / _WP / _CP / _X etc. mode strings, or the nentselp function with a given point argument.
