Thank you to all who helped on this project, CAB, Lee Mac & irned.
Below are the completed Functions, I am sure they are not as concise as Lee Mac's work (probably take 3-lines of code in total).
The below functions will perform the following;
1.- Create a Sub-Dictionary within the NOD.
2.- Create an Xrecord within the Sub-Dictionary.
3.- Retrieve Values within the Xrecord, based in the nth occurrence of the associated DXF Group Code.
4.- Update Values within the Xrecord, based in the nth occurrence of the associated DXF Group Code.
5.- Read the entire contents of the Xrecord.
This should give you enough Xrecord tools to be able to incorporate their use quite easily.
Function to Create the "SADATA_DICT" within the NOD
Syntax for function call;
(GC_Dict < dictname >)
(defun GC_Dict ( dictname / adict)
(if (not (setq adict (dictsearch (namedobjdict) dictname)))
(setq adict (entmakex '((0 . "DICTIONARY")(100 . "AcDbDictionary"))))
(if adict (setq adict (dictadd (namedobjdict) dictname adict)))
(setq adict (cdr (assoc -1 adict)))
);defun
(GC_Dict "SADATA_DICT") Example Calling Line
Function to Create an XRECORD in the "SADATA_DICT" within the NOD
(GM_Xrecord < XRECORD NAME >)
(defun GM_Xrecord ( DATA_VARS / adict anXrec)
((setq adict (GC_Dict "SADATA_DICT"))
((not (setq anXrec (dictsearch adict DATA_VARS)))
(setq anXrec (entmakex values))
(if anXrec (setq anXrec (dictadd adict DATA_VARS anXrec)))
(setq anXrec
(cdr (assoc -1 (dictsearch adict DATA_VARS)))
);setq
);cond
);setq
);cond
);defun
(GM_Xrecord "LDATA_VARS") Example Calling Line ;
Following are some examples for the <Values> variable that needs to be created prior to Calling the (GM_Xrecord) Function.
(setq x 11.23
y 23.43
z 43.23
test 34.54
test2 "This is line 5")
(setq Values (list(cons 0 "XRECORD") ; used for storing integers in "XRECORDS" can also use 270-289
(cons 100 "AcDbXrecord")
(cons 70 2 )
(cons 71 3 )
(cons 72 4 )
(cons 73 5 )
(cons 74 6 )
(cons 75 7 )
(cons 76 8 )
(cons 12 (list x y))
(cons 11 (list x y z))
);setq
(setq Values (list(cons 0 "XRECORD") ; used for storing reals in "XRECORDS" can also use 140-149
(cons 40 2.1234 )
(cons 41 3.4568 )
(cons 42 4.3254 )
(cons 43 5.3214 )
(cons 44 6.3256 )
(cons 45 test )
(cons 46 8.6384 )
(cons 47 9.2458 )
(cons 48 10.7854 )
);setq
(setq Values (list(cons 0 "XRECORD") ; used for storing strings in "XRECORDS" can also use 301-309
(cons 300 "This is line 1" )
(cons 300 "This is line 2" )
(cons 300 "This is line 10" )
(cons 300 "This is line 3" )
(cons 300 "This is line 4" )
(cons 300 test2 )
(cons 300 "This is line 6" )
(cons 300 "This is line 7" )
(cons 300 "This is line 8" )
(cons 300 "This is line 9" )
);setq
Function to retrieve values from an XRECORD using the DXF Group Code
(GetVar_Xrecord <XRECORD NAME> <DXF Group Code to Update> <Nth Group Code>)
Many Thanks to Lee Mac for his LM:mAssoc Function.
(defun GetVar_Xrecord ( DATA_VARS DXF_VAL LnmBr / xRecFile vars )
(defun LM:mAssoc ( DXF_VAL xRecFile / item )
(if (setq item (assoc DXF_VAL xRecFile))
(cons (cdr item) (LM:mAssoc DXF_VAL (cdr (member item xRecFile))))
);defun
(setq vars (GM_Xrecord DATA_VARS))
(cond (vars
(setq xRecFile (entget vars))
(cdr (cons DXF_VAL(nth LnmBr (LM:mAssoc DXF_VAL xRecFile))))
(T nil)
);defun
(setq VARNAME (GetVar_Xrecord "LDATA_VARS" 300 2 )) Calling Line
Function to Update the values in an XRECORD using the nth DXF Group Code
(Update_Xrecord <XRECORD NAME> <DXF Group Code to Update> <New Value> <Nth Group Code>)
(defun Update_Xrecord (DATA_VARS DXF_VAL MOD_VAL LnmBr / xRecFile Values SAdict)
);defun
(setq SAdict (dictsearch (namedobjdict) "SADATA_DICT")
xRecFile (dictsearch (cdr (assoc -1 SAdict)) DATA_VARS)
(setq values (subst (cons DXF_VAL MOD_VAL) (cons DXF_VAL(nth LnmBr (LM:mAssoc DXF_VAL xRecFile))) xRecFile))
(entdel (cdr (assoc -1 xRecFile)))
);defun
(Update_Xrecord "LDATA_VARS" 300 "Update test successful again 3 !" 4) Example Calling line
Function to See the Values in the specified XRECORD
(xRecord_Exist < Xrecord Name >)
(defun xRecord_Exist ( DATA_VARS / SAdict xRecFile )
(princ xRecFile)
(xRecord_Exist "LDATA_VARS") ExampleCalling line
Any comments or feedback is always welcome.
Enjoy,
Bruce
