Author Topic: change active layout in autocad R14  (Read 9440 times)
yaque
Re: change active layout in autocad R14
« Reply #15 on: October 22, 2010, 05:44:50 PM »
alanjt:
yes, when opening a file from a higher acad saved in format R14 with multiple layouts,
the last accessed layout is shown as "paperspace" when "tilemode" is set to "0" in Autocad R14.
The other layouts aren't accessible, but are okay when the file is reopened in the higher Autocad version.
My problem is, where does Autocad store "the last accessed layout"?
« Reply #16 on: October 22, 2010, 05:47:47 PM »
You will have to look at the dxf code for the layouts ' P ' and ' B '.
(foreach i (dictsearch (namedobjdict) "ACAD_LAYOUT")
(if (equal (car i) 3)
(print (cdr i))
(if (equal (car i) 350 )
(foreach j (entget (cdr i) '("*"))
(print j)
This should print to the command line all the layout's dxf codes with the layout name before it.
yaque
« Reply #17 on: October 22, 2010, 05:48:27 PM »
Oh, and if I can find the "the last accessed layout" variable in a dictionary or someplace,
I can then change it, and then Autocad will then display that layout as paperspace.
Voila! multiple layout support in Autocad R14!
alanjt
  • Standby for witty remark...
« Reply #18 on: October 22, 2010, 05:48:48 PM »
Really shows you how spoiled new version users are.
Dropbox
« Reply #19 on: October 22, 2010, 05:51:18 PM »
Man ... I remember installing R14 off a stack of floppies  I sure miss those days  NOT  :-D   second thought that was r12  :oops:
alanjt
« Reply #20 on: October 22, 2010, 05:54:02 PM »
LoL
Just thinking about printing 50 sheet documents by window plots and having to activate the viewports in groups made me sick to my stomach.
Really, floppy discs? We had r14 on CD-ROM.
Dropbox
yaque
« Reply #21 on: October 22, 2010, 05:55:30 PM »
T. Willey:
Hm, I get
"B"
(-1 . <Entity name: 4651c30>)
(0 . "ACAD_PROXY_OBJECT")
(5 . "DF50E")
(102 . "{ACAD_REACTORS")
(330 . <Entity name: 4651c18>)
(102 . "}")
"MODEL"
(-1 . <Entity name: 4651c28>)
(5 . "DF50D")
(102 . "}")
"P"
(-1 . <Entity name: 46e15f8>)
(5 . "111CF7")
(102 . "}") (102 . "}")
in the "B" layout file, and ... the same in the "P" layout file. Damn.
It isn't here.
yaque
« Reply #22 on: October 22, 2010, 05:59:07 PM »
Yeah, I remember R12 too. That was actually a great version, very solid.
So's R14.
And I run 100+ page A4 plots in the same file in R14 using numbered views and a lisp.
« Reply #23 on: October 22, 2010, 06:00:27 PM »
That is what I was scared of.  I can't even think how one would know which paper space layout it would switch to if you just changed the tilemode system variable in the later version of acad, with straight lisp.  I'll see if I can find anything out here.
alanjt
« Reply #24 on: October 22, 2010, 06:00:32 PM »
So's R14.
Sadly, at that time, the only customization I knew was typing and clicking really fast.
Dropbox
yaque
« Reply #25 on: October 22, 2010, 06:01:36 PM »
And I still use a modified version of that lisp to batch plot multiple sheets in Bricscad.
yaque
« Reply #26 on: October 22, 2010, 06:03:51 PM »
Heh, my boss sent me to a short Autolisp course.
Best investment he ever made.
Now I have about a megabyte of lisps in about 140 files, mostly mine.
yaque
« Reply #27 on: October 22, 2010, 06:07:30 PM »
T, Willey
 Thanks! No rush.
I'm really not very familiar with the "AcDbDictionary" jungle.
« Reply #28 on: October 22, 2010, 06:10:32 PM »
Me either.  I know enough to know I don't know enough.  The help, and here, are my friends when I go digging into dictionary items.
You're welcome Yaque.
yaque
« Reply #29 on: October 22, 2010, 06:13:48 PM »
Goodnight! (yeah it's midnight here) I'll check in tomorrow. and thanks again!
