Author Topic: Label copy  (Read 1402 times)
BlueMoon
Label copy
« on: October 21, 2010, 04:39:17 PM »
I created some new line label styles in the labels and tables and a friend wants to have them on his computer.  I have no problems with that but each style has 5 or 6 fields that need to be filled in and I was wondering if there is a faster way to copy the information and put it on his computer without going thru each and every one filling in the blanks.  I have 2010 C3D.
Thanks,
BM
BlueMoon
Re: Label copy
« Reply #1 on: November 10, 2010, 01:07:16 PM »
I finally figured out a way to do this. (it may not be the best but it works)  I decided to post this in case anyone else reads old posts.
Use the labels on any dwg.  Copy that dwg. into a new drawing and the label fields will fill in automatically.  You can then delete the copied dwg. and continue with your new project.
BM
Re: Label copy
« Reply #2 on: November 10, 2010, 01:50:41 PM »
Thanks for posting your solution.
