Author Topic: New Lisp any suggestions are welcomed  (Read 19760 times)
Re: New Lisp any suggestions are welcomed
« Reply #30 on: October 22, 2010, 02:18:51 PM »
what does it matter what side hes on?
BTW, i just did a search for that line in my "junk file" and i found something very similar... So, i would appreciate credit for that little bit every time you use it from now on. Thank you.
« Reply #31 on: October 22, 2010, 02:22:14 PM »
Seriously, there is a limit to how far things can be taken... are we all to credit the first guy to end with (princ)?
« Reply #32 on: October 22, 2010, 02:23:51 PM »
So where do we draw the line (you brought it up didnt you...you tell us)?
« Reply #33 on: October 22, 2010, 02:25:45 PM »
Ah yes, I figured that would be the next post. pass.
alanjt
  • Standby for witty remark...
« Reply #34 on: October 22, 2010, 02:29:15 PM »
Consider: Did you come up with this or did you 'copy' it from someone else?
(wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
I knew you'd bring that up sooner or later as you were involved in the thread in which we were first discussing it. But you also use that code, so which side are you arguing from?
It's a gray area.
Sure, it's wrong and completely unethical to take an entire program and just slap a new author name on it, but do we really have to denote every little snippet because we 'got' that particular method from another user. I mean, isn't that why we're here in the first place and why we post code as open-source?
Hell, right now people are taking open-source code, slapping their name on it and taking full credit. This will not stop. The only thing you can do is suck it up, compile your code or stop posting it.
Dropbox
« Reply #35 on: October 22, 2010, 02:33:52 PM »
*lol* no, you cant do that. No feelings, angst, or whatever involved.
Where do YOU draw the line (is it in your favor--are you playing fair-)? Or what?
I wasnt at one time, and when i realized it, it helped me.
« Reply #36 on: October 22, 2010, 02:39:39 PM »
Where I stand, if I copy a chunk of code from someone, then I'll mark it to say where I've copied it from. Else if I see an idea/way of approaching a problem, I might elaborate on it, but I would always be constructing the code myself from scratch, and hence would not deem it necessary to mark it. That said, for each of these there are fuzzy boundaries - and so, no, I won't be drawing any lines.
« Reply #37 on: October 22, 2010, 02:48:37 PM »
I use it as well  :-P
Copyright© me 2010 to infinity
(wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")[/code
David Bethel
« Reply #38 on: October 22, 2010, 02:51:30 PM »
Here's the oldest .lsp file I have in my library.  Somethings from 1988 still look familiar.
Who gets to claim
(defun rtd (r)
 (* 180 (/ r pi))
-David
R12 Dos - A2K
« Reply #39 on: October 22, 2010, 02:55:10 PM »
They had SETQ back in '88?!
EDIT:
Awesome!
;----- Mode Save -- Saves designated system variables in a list ---
(defun MODES (a)
   (setq MLST '())
   (repeat (length a)
      (setq MLST (append MLST (list (list (car a) (getvar (car a))))))
      (setq a (cdr a)))
;----- Mode Reset -- Resets previously saves system variables ---
(defun MODER ()
   (repeat (length MLST)
      (setvar (caar MLST) (cadar MLST))
      (setq MLST (cdr MLST))
« Last Edit: October 22, 2010, 02:58:39 PM by Se7en »
« Reply #40 on: October 22, 2010, 03:00:22 PM »
Who gets to claim
(defun rtd (r)
 (* 180 (/ r pi))
-David
Euclid
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
David Bethel
« Reply #41 on: October 22, 2010, 03:06:17 PM »
Who gets to claim
(defun rtd (r)
 (* 180 (/ r pi))
-David
Euclid
He should have some major royalties built up by now !   lol!  -David
R12 Dos - A2K
alanjt
« Reply #42 on: October 22, 2010, 03:13:11 PM »
I was studying your matrix rotation routine a while back and for some reason, this stuck in my mind. Probably because I remembered when I was studying some of gile's work on a similar subject.
Here, you post it as such: http://www.theswamp.org/index.php?topic=34955.0
(defun mxv ( m v )
  (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
No, you are not taking credit for it, but you have to stuck in a group of codes you are claiming credit on and without any mention of where from this came.
and with a search, I found this: http://www.theswamp.org/index.php?topic=33700.msg390752#msg390752
;; Matrix x Vector  ~  Vladimir Nesterovsky
(defun mxv ( mat vec )
  (mapcar '(lambda ( row ) (apply '+ (mapcar '* row vec))) mat))
Dropbox
« Reply #43 on: October 22, 2010, 03:19:26 PM »
That was part of my library of math/vector functions -
alanjt
« Reply #44 on: October 22, 2010, 03:24:15 PM »
You are missing my point; both functions are exactly the same and both were posted by you (as I linked).
Dropbox
