Author Topic: txt2mtxt  (Read 17708 times)
PHX cadie
txt2mtxt
« on: October 20, 2010, 03:30:17 PM »
Because of client standards, they do not allow single text, only mtext. The sub gives us dwgs with all single line text and I have to fix it. I've been using Express tools to convert, but I need to pick each one by one, not group everything into one paragraph.
Van Halen has  great rhythm to hitting the space bar, I can't help but wonder if there is an easier way to convert txt to mtxt?
Thx's
Acad 2013 and XM
alanjt
  • Standby for witty remark...
Re: txt2mtxt
« Reply #1 on: October 20, 2010, 03:34:59 PM »
Quickie...
(defun c:Test (/ i ss e)
  (if (setq i  -1
            ss (ssget "_:L" '((0 . "TEXT")))
    (while (setq e (ssname ss (setq i (1+ i)))) (command "_.txt2mtxt" e ""))
Dropbox
Re: txt2mtxt
« Reply #2 on: October 20, 2010, 03:44:05 PM »
Here's my "homegrown" version:  :-)
;;; AUTHOR
;;; Copyright© 2010 Ron Perez (ronperez@gmail.com)
(defun c:t2mt (/  d     doc elst   hgt      lspc n
      nxt  obj     objtxt out   pt      ss txt
      w  x     rjp-removextraspaces  rjp-ent2obj rjp-getbbwdth
      rjp-getbbtlc     rjp-dxf
  (defun rjp-removextraspaces (txt)
    (while (vl-string-search "  " txt)
      (setq txt (vl-string-subst " " "  " txt))
    txt
  (defun rjp-ent2obj (ent)
    (if (= (type ent) 'ename)
      (vlax-ename->vla-object ent)
      ent
  (defun rjp-dxf (code ent)
    (if (and ent (= (type ent) 'ename))
      (cdr (assoc code (entget ent)))
  (defun rjp-getbbwdth (ent / out ll ur)
    (vla-getboundingbox (rjp-ent2obj ent) 'll 'ur)
    (setq out (mapcar 'car (mapcar 'vlax-safearray->list (list ll ur))))
    (abs (- (car out) (cadr out)))
  (defun rjp-getbbtlc (ent / out ll ur)
    (setq out (mapcar 'vlax-safearray->list (list ll ur)))
    (list (caar out) (cadr (last out)) 0.0)
  (if (and (setq ss (ssget ":L" (list '(0 . "text"))))
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
    (progn (setq elst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
;;Get widest piece of text to set mtext width
w (* 1.0125 (car (vl-sort (mapcar 'rjp-getbbwdth elst) '>)))
;;Sort text top to bottom
txt (vl-sort
 (mapcar
   '(lambda (x)
      (list
(cadr (rjp-dxf 10 x))
(strcat (rjp-removextraspaces (rjp-dxf 1 x)) " ")
x
   elst
 (function (lambda (y1 y2) (< (car y2) (car y1))))
hgt (rjp-dxf 40 (last (car txt)))
pt (rjp-getbbtlc (last (car txt)))
;;Grab top text to pull properties from
objtxt (vlax-ename->vla-object (last (car txt)))
  ;;Puts hard returns for text spaced greater than (* 2. hgt)
  (setq n 0)
  (foreach x txt
    (if (setq nxt (nth (setq n (1+ n)) txt))
      (if (>= (setq d (abs (- (car x) (car nxt)))) (* 2. hgt))
(setq out (cons (strcat (cadr x) "\\P\\P") out))
(setq out  (cons (cadr x) out)
      lspc (cons d lspc)
      (setq out (cons (cadr x) out))
  ;;Join the text into one string
  (setq txt (apply 'strcat (reverse out)))
  ;;Insert mtext
  (setq obj (vla-addmtext
      (if (= (getvar 'cvport) 1)
(vla-get-paperspace doc)
(vla-get-modelspace doc)
      (vlax-3d-point pt)
      w
      txt
  ;;Match properties from top text object
  (vla-put-height obj (vla-get-height objtxt))
  (vla-put-attachmentpoint obj actopleft)
  (vlax-put obj 'insertionpoint pt)
  (vla-put-rotation obj 0.0)
  (vla-put-layer obj (vla-get-layer objtxt))
  (vla-put-stylename obj (vla-get-stylename objtxt))
  (if lspc
    (vla-put-linespacingdistance
      obj
      (/ (apply '+ lspc) (length lspc))
  ;;Delete selected single line text
  (mapcar 'entdel elst)
PHX cadie
Re: txt2mtxt
« Reply #3 on: October 20, 2010, 03:44:18 PM »
You are awesome!
Much Thanks both!!!!!!!!!!
(Knew I should have asked yesterday)
« Last Edit: October 20, 2010, 03:56:57 PM by PHX cadie »
Acad 2013 and XM
Re: txt2mtxt
« Reply #4 on: October 21, 2010, 10:11:57 AM »
Did this code work for you? I forgot to include that a portion of my code removes extra spaces ... if you don't want that, remove the portion in red below:
PHX cadie
Re: txt2mtxt
« Reply #5 on: October 21, 2010, 03:15:52 PM »
worked great
Thx's ron!
Acad 2013 and XM
Re: txt2mtxt
« Reply #6 on: October 21, 2010, 03:43:40 PM »
Glad to hear :)
alanjt
Re: txt2mtxt
« Reply #7 on: October 21, 2010, 03:49:14 PM »
Nice work Ron. Much better than my simple solution.
Dropbox
Re: txt2mtxt
« Reply #8 on: October 21, 2010, 03:58:22 PM »
Thanks Alan  :-)
cmwade77
Re: txt2mtxt
« Reply #9 on: October 28, 2010, 12:05:50 PM »
;;; AUTHOR
    txt
      ent
txt (vl-sort
 (mapcar
   '(lambda (x)
      (list
x
   elst
  (setq n 0)
  (foreach x txt
      lspc (cons d lspc)
  ;;Insert mtext
      (vlax-3d-point pt)
      w
      txt
  (if lspc
      obj
This code work great with a routine that I am working on over at http://www.theswamp.org/index.php?topic=35426.0
However, occasionally I need to combine multiple pieces of mtext and this works as long as there is at least on regular piece of text, but I am wondering if there might be a way to modify this to work if the entire selection set is mtext?
Re: txt2mtxt
« Reply #10 on: October 28, 2010, 12:53:48 PM »
Just change the filter ... the way it's grabbing text now it should not get any mtext?
(setq ss (ssget ":L" (list '(0 . "*text"))))
or
(setq ss (ssget ":L" (list '(0 . "mtext,text"))))
cmwade77
Re: txt2mtxt
« Reply #11 on: October 28, 2010, 12:59:53 PM »
No, sorry, i did modify it to where it will get the mtext already, which is what I want. The problem is that if there is no regular text (i.e. all pieces of text are mtext), then it errors out before finishing the command.
Re: txt2mtxt
« Reply #12 on: October 28, 2010, 01:22:52 PM »
Whatever mods you did to the code broke it because I cannot replicate your problem? If you set your VLIDE to break on error you should be able to track down where the code is bonking out.
cmwade77
Re: txt2mtxt
« Reply #13 on: October 28, 2010, 02:02:45 PM »
Must remember to restart AutoCAD when things don't quite seem right....I guess something got screwy in a variable during the testing phase, restarted AutoCAD and all seems to be good now, thank you for confirming that your code was not an issue. Sorry about that.
Robert98
Re: txt2mtxt
« Reply #14 on: October 28, 2010, 02:42:49 PM »
;;; AUTHOR
    txt
      ent
txt (vl-sort
 (mapcar
   '(lambda (x)
      (list
x
   elst
  (setq n 0)
  (foreach x txt
      lspc (cons d lspc)
  ;;Insert mtext
      (vlax-3d-point pt)
      w
      txt
  (if lspc
      obj
Hi ronjonp
I made a sample with 12 numbers and run your codes and for selection , I used a fence so your codes act on separate text correctly but put all of them at a column in right side of screen , like this :
145
12
178
10
I don't know , I'm a bad user or your routine  should acts this way . please tell me if I want mtext made instead one of them or at least around them , what must I do ? I don't work whit vlisp codes and most importantly it I need to your permission.
Until after bye :realmad:
