Author Topic: ObjectARX Wizard and VS2010  (Read 6136 times)
A_LOTA_NOTA
« on: October 19, 2010, 12:51:10 PM »
How do I get ObjectARX Wizard to install with VS2010/utoCAD 2010? I get an error "Microsoft Visual Studio 2008 must be present on the target machine".
« Last Edit: October 19, 2010, 01:10:48 PM by A_LOTA_NOTA »
Jeff H
Re: ObjectARX Wizard and VS2010
« Reply #1 on: October 19, 2010, 01:01:02 PM »
Install VS 2008
jgr
« Reply #2 on: October 19, 2010, 01:08:43 PM »
I think that it is not possible. The assistant is attached to the ObjectARX compiler version (acad2000-VS6, acad2007-VS2005 ...)
(sorry i do not speak English)
Jeff H
« Reply #3 on: October 19, 2010, 01:17:25 PM »
jgr
« Reply #4 on: October 19, 2010, 01:28:37 PM »
Install VS 2008
Sorry, that's what I wanted to explain.
A_LOTA_NOTA
« Reply #5 on: October 19, 2010, 02:08:23 PM »
Can it be the express version of 2008?
A_LOTA_NOTA
« Reply #6 on: October 19, 2010, 03:49:06 PM »
I guess not... I don't have VS2008
« Last Edit: October 19, 2010, 03:56:52 PM by A_LOTA_NOTA »
mohnston
  • CAD Programmer
« Reply #7 on: October 19, 2010, 05:15:21 PM »
Have you tried the newest wizard? Not sure if it works with 2010 but I am using it successfully with 2011.
I found out about it here. http://through-the-interface.typepad.com/through_the_interface/2010/08/new-version-of-the-autocad-net-wizard-posted.html
CAD Programming Solutions
Jeff H
« Reply #8 on: October 19, 2010, 05:25:14 PM »
A_LOTA_NOTA
Are you wanting to develop in .NET? If so my references were to the ObjectARX wizards C++
For .NET yes can use 2010
Here is another link to the .NET wizards with some extra stuff http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
A_LOTA_NOTA
« Reply #9 on: October 19, 2010, 05:46:24 PM »
I'm wanting to develop in C++
« Last Edit: October 20, 2010, 09:09:30 AM by A_LOTA_NOTA »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: October 19, 2010, 07:45:42 PM »
Even if you get the wizard to work,  you still need to match the compiler with the cad version. You "must"  have VS2008 standard/Pro to target Acad 2010-11, VS2005 for Acad 2007-2009,Bricscad and VS2002 for Acad 04-6. Forget about express versions.
Now once you have the older VS versions installed, you can use the VS2010 editor and use specific compilers, but that's another story.
A_LOTA_NOTA
« Reply #11 on: October 20, 2010, 09:10:44 AM »
Thank you, thats what I needed to know. I have VS2010 Pro....
I ordered VS2008 Pro... I'll have it tomorrow
« Last Edit: October 20, 2010, 10:17:10 AM by A_LOTA_NOTA »
