Author Topic: "Wblock Layers", saving the contents of each layer to a separate file  (Read 11492 times)
kaefer
Hi All,
this is the continuation of http://www.theswamp.org/index.php?topic=31858.msg405029#msg405029, with many thanks to fixo.
I tried to reduce his function to the bare minmum, that is:
Get the position of a template file (requires a reference to Autodesk.AutoCAD.Interop)
Collect the relevant layers
For each layer, select all ModelSpace objects
Create a new empty database and read the template file into it
WblockClone the selected objects into the new database
Saveas the database and dispose it implicitly; no need for an open transaction in the last four steps
Am I missing anything?
open Autodesk.AutoCAD.DatabaseServices
open Autodesk.AutoCAD.EditorInput
open Autodesk.AutoCAD.Runtime
type acApp = Autodesk.AutoCAD.ApplicationServices.Application
[<CommandMethod "WBL">]
let copyObjectsOnLayers() =
    // Get the current document and database
    let doc = acApp.DocumentManager.MdiActiveDocument
    let ed = doc.Editor
    let db = doc.Database
    // Get the path to an appropriate template file
    let prefs = acApp.Preferences :?> Autodesk.AutoCAD.Interop.AcadPreferences
    let sTemplatePath =
        System.IO.Path.Combine(prefs.Files.TemplateDwgPath, "acadiso.dwt")
    // Get the current document's path and name without extension
    let currRoot = acApp.GetSystemVariable "DWGPREFIX" :?> string
    let currName =
        acApp.GetSystemVariable "DWGNAME" :?> string
        |> System.IO.Path.GetFileNameWithoutExtension
    let lrcoll = new System.Collections.Generic.List<string>()
    // Start a transaction
    use tr = db.TransactionManager.StartTransaction()
    // Collect all unlocked and not xref-dependent layers
    let lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead) :?> LayerTable
    for lrid in lt do
        let ltr = tr.GetObject(lrid, OpenMode.ForRead, false) :?> LayerTableRecord
        if not ltr.IsLocked && not(ltr.Name.Contains "|") then
            lrcoll.Add ltr.Name |> ignore
    tr.Commit()
    for lrname in lrcoll do
        let res =
            new SelectionFilter[|
                 new TypedValue(int DxfCode.LayerName, lrname)
                 new TypedValue(int DxfCode.LayoutName, "Model") |]
            |> acApp.DocumentManager.MdiActiveDocument.Editor.SelectAll
        if res.Status = PromptStatus.OK && res.Value.Count > 0 then
            let objcoll = new ObjectIdCollection(res.Value.GetObjectIds())
            let strFilename =   //<-- build filename as you need here
                    currRoot, currName + @"_" + lrname + @".dwg" )
            ed.WriteMessage("\n" + strFilename)
            // Create a new database to copy the objects to
            use newdb = new Database(false, true)
            // Read the template file into it
            newdb.ReadDwgFile(sTemplatePath, System.IO.FileShare.Read, true, "")
            // Get the ObjectId of the new ModelSpace BlockTableRecord
            let newbtrId = SymbolUtilityServices.GetBlockModelSpaceId newdb
            // Clone the objects to the new database
            let idmap = new IdMapping()
            db.WblockCloneObjects(
                objcoll, newbtrId, idmap, DuplicateRecordCloning.Ignore, false)
            newdb.SaveAs(strFilename, DwgVersion.Current)
All the best, Thorsten
Jeff H
Re: "Wblock Layers", saving the contents of each layer to a separate file
« Reply #1 on: October 15, 2010, 08:56:16 AM »
Is that your code posted at Through The Interface
or is there another Thorsten out there who likes F#?
kaefer
« Reply #2 on: October 15, 2010, 09:15:39 AM »
Hi Jeff,
see if you discover any similarities:
    // Late binding Interop workaround, casts obj to binding target
    let (?) (o: obj) prop : 'T  =
        let bf = System.Reflection.BindingFlags.GetProperty
        o.GetType().InvokeMember(prop, bf, null, o, null) :?> 'T
    let sTemplatePath =
            acApp.Preferences?Files?TemplateDwgPath, "acadiso.dwt" )
That should help against the Interop reference above, but at the price of making it much more difficult porting it back to C#.
With best wishes, Thorsten
« Reply #3 on: October 15, 2010, 10:14:45 AM »
System.IO.Path.Combine( acApp.Preferences?Files?TemplateDwgPath, "acadiso.dwt" )
? in place of \\    :|
Is that a typo ??
kaefer
« Reply #4 on: October 15, 2010, 10:56:48 AM »
? in place of \\    :|
Is that a typo ??
Hi Kerry,
nope. Read ? in place of .
The ?-operator is an underdocumented feature of the latest F#-compiler. Its main use is endorsed by the gurus at MS research as a replacement for the FrameworkElement.FindName method in WPF. That's why I thought I could borrow this for my little late binding exercise. The orig was:
    let sTemplatePath =
Regards, Thorsten
« Last Edit: October 15, 2010, 11:01:13 AM by kaefer »
Jeff H
« Reply #5 on: October 17, 2010, 10:09:09 AM »
Hi Jeff,
Sorry Thorsten I do not understand the question
Here is another idea I hope this helps
This is Fixo's code that obtains the entities ObjectId a different way.
1. It uses a dictionary and does one loop through model space adding each entity to the dictionary
2. Tries to create new drawing for each layer from the template "Fart.dwt" ---- Did this so it would fail and use default template
3. Save in same folder as layer Name
Not sure if this will help reduce the function a little more or is not efficient enough.
Here is the Code
************Edited************
Added a couple of comments in the code
using System;
using System.Collections;
[assembly: CommandClass(typeof(WblockLayers.MyCommands))]
namespace WblockLayers
    public class MyCommands
        // Dictionary to Store the Layer Name and the Entites that are on the Layer
        Dictionary<string, ObjectIdCollection> entFileDict = new Dictionary<string, ObjectIdCollection>();
        [CommandMethod("WblockLayers")]
        public void WblockLayers()
            // Get the folder that the current drawing is in
            string dwgDialog = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("DWGPREFIX") as string;
            DocumentCollection docMgr = Application.DocumentManager;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction trx = db.TransactionManager.StartTransaction())
                BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                BlockTableRecord btrMs = bt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForRead) as BlockTableRecord;
                ObjectIdCollection entIds = null;
                // For each entity in Model Space it checks if the Dictiony contains the layer name
                // If it does it adds the Entities Object Id to the value
                //If not it creates a new entry
                foreach (ObjectId entID in btrMs)
                    Entity ent = entID.GetObject(OpenMode.ForRead) as Entity;
                    string lyrName = ent.Layer;
                    if (entFileDict.TryGetValue(lyrName, out entIds))
                        entIds.Add(entID);
                    else
                        ObjectIdCollection entObjIds = new ObjectIdCollection();
                        entObjIds.Add(entID);
                        entFileDict.Add(lyrName, entObjIds);
                // Loop through the dictionary using the key values which are the layer names
                // Create new drawing add the entites on that layer
                // Save drawing in current drawing folder as the layer name and close drawing
                foreach (string lyrName in entFileDict.Keys)
                    using (Document newDoc = docMgr.Add("Fart.dwt"))
                        using (DocumentLock newLoc = newDoc.LockDocument())
                            using (Transaction newTrx = newDoc.Database.TransactionManager.StartTransaction())
                                BlockTable newBt = newDoc.Database.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                                BlockTableRecord newBtrMs = newBt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForRead) as BlockTableRecord;
                                IdMapping map = new IdMapping();
                                ObjectIdCollection newEntIds = null;
                                if (entFileDict.TryGetValue(lyrName, out newEntIds))
                                    db.WblockCloneObjects(newEntIds, newBtrMs.Id, map, DuplicateRecordCloning.Replace, false);
                                else
                                    continue;
                                newTrx.Commit();
                                newDoc.Database.SaveAs(dwgDialog +  lyrName + ".dwg", DwgVersion.Current);
                        newDoc.CloseAndDiscard();
                trx.Commit();
Thanks Fixo for the cool idea and code.
Thanks Thorsten for the F# code.
« Last Edit: October 17, 2010, 10:22:04 AM by Jeff H »
kaefer
« Reply #6 on: October 18, 2010, 02:56:30 AM »
Hi Jeff,
That was a reference to the ?-operator in F#, which allows unquoted string literals. Let's change the note now.
This idea is pretty snappy. I'll borrow it, may I?
This is cool and useful behaviour, since the fallback default seems to be either the last one used or it's based on the current drawing; it's not coming from QNEW settings, those are empty here.
Reduction: check. Efficiency: not sure, for large numbers of files the document manager is really slow.
Maybe it's the way to go if you want to run your code in the Session context.
Backport to C#, incorporates your dict, but takes the template from Preferences:
using System;
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
        [CommandMethod("WblockLayersC")]
        public static void WblockLayers()
            Database db = acApp.DocumentManager.MdiActiveDocument.Database;
            Editor ed = acApp.DocumentManager.MdiActiveDocument.Editor;
            // Dictionary to store the Layer Name and the Entites that are on the Layer
            string dwgDialog = acApp.GetSystemVariable("DWGPREFIX") as string;
            // Get the template folder from the preferences
            string sTemplatePath = get(get(acApp.Preferences, "Files"), "TemplateDwgPath") as string;
            string sTemplateFile = sTemplatePath + @"\acadiso.dwt";
                    if (!entFileDict.ContainsKey(lyrName))
                        entFileDict.Add(lyrName, new ObjectIdCollection());
                    entFileDict[lyrName].Add(entID);
                tr.Commit();
            foreach (KeyValuePair<string,ObjectIdCollection>entry in entFileDict)
                using (Database newDb = new Database(false, true))
                    newDb.ReadDwgFile(sTemplateFile, System.IO.FileShare.Read, true, "");
                        entry.Value,
                        SymbolUtilityServices.GetBlockModelSpaceId(newDb),
                    newDb.SaveAs(dwgDialog + entry.Key + ".dwg", DwgVersion.Current);
        static Object get(Object o, string prop)
            return o.GetType().InvokeMember(prop, System.Reflection.BindingFlags.GetProperty, null, o, null);
Cheers, Thorsten
Jeff H
« Reply #7 on: October 18, 2010, 01:11:44 PM »
Gladly I know I have picked up alot ideas from your post, wish I could I return the favour more often.
I like the way you did your code in the previous post. It is alot easier to read then mine.
« Reply #8 on: October 18, 2010, 06:17:04 PM »
? in place of \\    :|
Is that a typo ??
Hi Kerry,
    let sTemplatePath =
Regards, Thorsten
Thanks.
I'd planned on working through "Expert F# 2.0" (Styme et al) but decided I don't have the time or energy.
Jeff H
« Reply #9 on: October 19, 2010, 05:45:35 AM »
This makes a huge difference from my earlier post by changing the last foreach loop.
Setting the the first argument to true in the Database constructor
From docs
specifying whether or not to build an empty object
foreach (KeyValuePair<string, ObjectIdCollection> entry in entFileDict)
                    using (Database newDb = new Database(true, false))
                    using (Transaction newTrx = newDb.TransactionManager.StartTransaction())
                        BlockTable newBt = newDb.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                        db.WblockCloneObjects(entry.Value, newBtrMs.Id, map, DuplicateRecordCloning.Replace, false);
                        newTrx.Commit();
                        //newDb.CloseInput(true);
kaefer
« Reply #10 on: October 19, 2010, 06:03:53 AM »
Thanks for your patience with this one.
From docs
BTDT. That's where the imperial units came from. To use the Database.ReadDwgFile method, it has to be set to false.
...memory leaks, or worse, will result.
Sincerely, Thorsten
Glenn R
« Reply #11 on: October 19, 2010, 05:24:40 PM »
A slightly different approach for the Dictionary and it's population. It's a pity that the SymbolTables don't implement standard/generic collections or their interfaces.
    LayerTable lt = (LayerTable)db.LayerTableId.GetObject(OpenMode.ForRead);
    IEnumerable<ObjectId> layerIds = lt.Cast<ObjectId>();
    // get the count for collection initialisation
    int layerCount = layerIds.Count();
    // init our collection to predefined size to avoid overhead
    // of resizing. Also, we use ObjectId as the key for easy comparison/lookup
    Dictionary<ObjectId, ObjectIdCollection> layerMap = new Dictionary<ObjectId, ObjectIdCollection>(layerCount);
    // construct collection for easy access. We know layers are unique, so their
    // objectid's will be, which is perfect for keys
    layerIds.ForEach(id => layerMap.Add(id, new ObjectIdCollection()));
    // grab MS
    BlockTable bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
    BlockTableRecord msBtr = (BlockTableRecord)bt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForRead);
    // loop it
    msBtr.Cast<ObjectId>().ForEach(entId =>
            Entity msEnt = (Entity)entId.GetObject(OpenMode.ForRead);
            layerMap[msEnt.LayerId].Add(entId);
    tr.Commit();
Jeff H
« Reply #12 on: October 19, 2010, 05:57:24 PM »
Nice.
Thank you Glenn R very much for posting that.
It is nice to see how the pro's do it.
kaefer
« Reply #13 on: October 21, 2010, 03:36:58 AM »
Hi Glenn!
Wow, that's as functional as it gets.
Minor quibble: wouldn't it be advisable to check the IsDependent property of each LayerTableRecord, to avoid empty ObjectIdCollections for xref layers?
Same function in F# (as always); the dict keyword by the way returns an immutable (i.e. read-only) dictionary..
        let layerMap =
            db.LayerTableId.GetObject OpenMode.ForRead :?> LayerTable
            |> Seq.cast<ObjectId>
            |> Seq.filter(fun ltid -> not (ltid.GetObject OpenMode.ForRead :?> LayerTableRecord).IsDependent)
            |> Seq.map(fun ltid -> ltid, new ObjectIdCollection())
            |> dict
        (SymbolUtilityServices.GetBlockModelSpaceId db).GetObject OpenMode.ForRead :?> BlockTableRecord
        |> Seq.iter
            (fun entId ->
                let msEnt = entId.GetObject OpenMode.ForRead :?> Entity
                layerMap.[msEnt.LayerId].Add entId |> ignore )
        tr.Commit()
Regards, Thorsten
Glenn R
« Reply #14 on: October 21, 2010, 05:16:02 AM »
Minor reposte: Yes, of course it would, however it wasn't listed as a requirement; nobody else was doing it; and I was just showing a possible way of doing it - people could figure out the details themselves.
You'll also notice I'm not using any error checking either - shame on me.
