;;; + get_group_boundingbox.lsp +
;;; + Created by C. Alan Butler +
;;; + Copyright 2005 +
;;; + by Precision Drafting & Design All Rights Reserved. +
;;; + Contact at ab2draft@TampaBay.rr.com +
;;; Get a bounding box for a group of bounding boxes
;;; Use the base of the first box as a referance angle that will be
;;; the base angle of the box returned
;;; argument 'all; is a list of 4 point lists defining the group of boxes
(defun get_group_boundingbox (all / ld lb rd rb bd bb td tb tmp refpt angr
ang angr s1 s2 pt anglst intersect dist)
;; return intersect point between two borders
(defun intersect (s1 s2 ang / angr)
(if (>= ang (* pi 1.5)) ; ANGLE PLUS 90 DEG
(setq angr (- ang (* pi 1.5))) ; -270 deg
(setq angr (+ ang (/ pi 2))) ; +90 deg
(inters s1 (polar s1 angr 10) s2 (polar s2 ang 10) nil)
) ; end defun
;; calc distance & perpenduclar point on border
(defun dist (p1 ang p3 p4 / p2 p5 d angp1p5)
(setq p2 (polar p1 ang 10) ; point on line at angle
p5 (inters p1 p2 p3 p4 nil) ; perpendicular point
d (distance p1 p5)
;; this is needed when angp1p5 is = 2pi
(if (equal (angle p1 p5) (* 2 pi) 0.00001)
(setq angp1p5 0.0)
(setq angp1p5 (angle p1 p5))
(if (equal angp1p5 ang 0.00001)
(list (distance p1 p5) p5)
(list (- (distance p1 p5)) p5)
;; returns (dist point)
) ; end defun
;; start of get_group_boundingbox
(setq ld 0 ; ld Left Distance : lb Left Broder pt
rd 0
td 0
bd 0
;; constant referance point for calcs, it is within the first box
refpt (polar (caar all) (angle (caar all) (caddar all))
(/ (distance (caar all) (caddar all)) 2))
ang (angle (caar all) (cadar all)) ; constant angle for calcs
angr (if (>= ang (* pi 1.5)) ; ANGLE PLUS 90 DEG
(- ang (* pi 1.5)) ; -270 deg
(+ ang (/ pi 2)) ; +90 deg
;; this is needed when ang is = 2pi
(if (equal ang (* 2 pi) 0.00001)
(setq ang 0.0)
;; find point on outer most border
(foreach pt all
;; Right Border (ll lr ur ul) -> lr ur -> (cadr pt) (caddr pt)
(if (>= (car (setq tmp (dist refpt ang (cadr pt) (caddr pt)))) rd)
(setq rb (cadr tmp) ; new border point
rd (car tmp) ; new distance
;; Left Border (ll lr ur ul) -> ll ul -> (car pt) (cadddr pt)
(if (<= (car (setq tmp (dist refpt ang (car pt) (cadddr pt)))) ld)
(setq lb (cadr tmp) ; new border point
ld (car tmp) ; new distance
;; Top Border (ll lr ur ul) -> ur ul -> (cadr pt) (caddr pt)
(if (>= (car (setq tmp (dist refpt angr (caddr pt) (cadddr pt)))) td)
(setq tb (cadr tmp) ; new border point
td (car tmp) ; new distance
;; Bottom Border (ll lr ur ul) -> ll lr -> (car pt) (cadddr pt)
(if (<= (car (setq tmp (dist refpt angr (car pt) (cadr pt)))) bd)
(setq bb (cadr tmp) ; new border point
bd (car tmp) ; new distance
) ; foreach
;; get intersect point between two borders
;; Left Border & Bottom Border = Lower left pt
(list (intersect lb bb ang) ; ll
(intersect rb bb ang) ; lr
(intersect rb tb ang) ; ur
(intersect lb tb ang) ; ul
;; returns (ll lr ur ul)
) ; end defun get_group_boundingbox
;;; + box_text +
;;; VERSION
;;; 1.2 Jan 24, 2006 UCS corrections
;;; 1.3 Nov 26, 2008 Fixed Bug when text was rotated
;;; FUNCTION
;;; Return Box coordinates for an dtext object in any UCS, any angle.
;;; USAGE
;;; (box_text ent)
;;; ARGUMENTS
;;; ent = text ename
;;; RETURNS
;;; list of 4 points for box, (ll lr ur ul)
;;; PLATFORMS
;;; 2000+ Tested in 2000 only
;;; FUNCTION
(defun box_dtext (ent / i ename elist lst lst2 tb tb1 tb2 tlen thi ll lr
ur ul ang angg UCSang llx lrx urx ulx lly lry ury uly all
avg err cntlst
(setq UCSang (angle (trans '(0.0 0.0 0.0) 1 0)
(trans '(1.0 0.0 0.0) 1 0)
;; get the bounding box
(setq elist (entget ent)
ang (cdr (assoc 50 elist)) ; text angle
tb (textbox elist) ; Note that I had some problems with this
;tb (textbox (list (assoc 1 elist) (assoc 40 elist)(assoc 7 elist)));(textbox (list (assoc 1 elist))) ; CAB 11.11.08
tb1 (car tb) ; Lower Left Relative to text
tb2 (cadr tb) ; Upper Right relative to text
tlen (- (car tb2) (car tb1))
thi (- (cadr tb2) (cadr tb1))
(setq ang (- ang UCSang) ; correct for UCS
ll (polar (trans (cdr (assoc 10 elist)) 0 1)
(+(angle '(0 0) tb1) ang) (DISTANCE '(0 0) tb1)) ; CAB 11.26.2008
lr (polar ll ang tlen)
ur (polar ll (+ ang (angle tb1 tb2)) (distance tb1 tb2))
ul (polar ll (+ ang (/ pi 2)) thi)
) ;setq
(list ll lr ur ul)
) ; end defun box_dtext
;;; x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x
Test the drawing with the code.
(defun C:TT ()
(setq BOX_PTS '())
(setq SS (ssget '((0 . "TEXT"))))
(repeat (setq I (sslength SS))
(and (setq E (ssname SS (setq I (1- I))))
(setq BOX (BOX_DTEXT E))
(setq BOX_PTS (cons BOX BOX_PTS))
(setq 4PTS (GET_GROUP_BOUNDINGBOX BOX_PTS))
