Author Topic: Does Layer Exist?  (Read 13169 times)
hardwired
Does Layer Exist?
« on: October 11, 2010, 06:33:45 AM »
Hope you're all ok..
This is no doubt a very simple question but i can't seem to find all the answers i need..
I'm trying to check if a layer exists, and if it does, use it for a block insert and if it doesn't, create it and use it..
Here is my function (amended from one i found on here i think):
Private Function DoesLayerExist(ByRef LayerName As String) As Boolean
LayerName = "LSC-REVISIONS_" & revnumCOMBO.Text
      Dim objLayer As AcadLayer
      For Each objLayer In ThisDrawing.Layers
            If UCase(objLayer.Name) = UCase(LayerName) Then
                  DoesLayerExist = True
                  Exit Function
            End If
      Next objLayer
      DoesLayerExist = False
      RMlayer = ThisDrawing.Layers.Add("LSC-REVISIONS_" & revnumCOMBO.Text)
      RMlayer.Plottable = False
End Function
Firstly, is this function ok? and secondly, how do i use it in other subs within the program?
This is an extract of part of the main code and what i'm using:
'Insert block..
    Set RMblock = ThisDrawing.PaperSpace.InsertBlock(BlockPoint, "P:\CAD_Blocks\PaperSpace Stuff\Program Blocks\Revision Marker.dwg", 1#, 1#, 1#, 0)
    RMblock.Layer = RMlayer
Any ideas?
Arizona
Re: Does Layer Exist?
« Reply #1 on: October 11, 2010, 06:49:11 AM »
Once you know the layer exists you need to set it as the active layer, if you want your block inserted on that layer. Or the alternative would be to change the block to the layer after insertion.
hardwired
« Reply #2 on: October 11, 2010, 10:16:39 AM »
Hi Arizona,
My current code does change the layer of the block after its been inserted but something's awry with my function or something else i've overlooked..
Any ideas?
Bob Wahr
« Reply #3 on: October 11, 2010, 10:19:55 AM »
You're note setting a value for RMlayer if the layer exists.  Try this.
                  RMlayer = objLayer
                  Exit Function
            End If
      Next objLayer
End Function
hardwired
« Reply #4 on: October 11, 2010, 10:52:03 AM »
Hi Eric,
Ok tried that but still nothing. If i use the floowing code after the function.....
'Insert block..
....how does all this tie in with each other? How do i call the return of the function within my code for inserting the block?
Bob Wahr
« Reply #5 on: October 11, 2010, 11:10:02 AM »
it doesn't.  rusty+not fully awake+no coffee yet = bad answer
try
Private Function DoesLayerExist(ByRef LayerName As String) As acadlayer
                  DoesLayerExist = objLayer
                  Exit Function
            End If
      Next objLayer
      DoesLayerExist = ThisDrawing.Layers.Add("LSC-REVISIONS_" & revnumCOMBO.Text)
End Function
'Insert block..
    RMblock.Layer = DoesLayerExist
FYI, still haven't filled my cup up although the coffee is made now.  Haven't done any VBA for awhile and don't have it loaded so I can't test, so I'm just plugging blind.
hardwired
« Reply #6 on: October 11, 2010, 11:36:00 AM »
Hi Eric,
Hope you're coffee was nice..
I tired putting...
...but it breaks and says 'Argument Not Optional'
Bob Wahr
« Reply #7 on: October 11, 2010, 11:44:45 AM »
RMblock.Layer = DoesLayerExist(put the string you are passing to LayerName here)
coffee are gud
hardwired
« Reply #8 on: October 11, 2010, 12:09:19 PM »
Hi Eric,
I've tried various:
RMblock.Layer = DoesLayerExist("LSC-REVISIONS_" & revnumCOMBO.Text)
...but this didn't do anything.....
RMblock.Layer = DoesLayerExist(LayerName)
...but it said the variable was not defined (even though it is in the function).....
RMblock.Layer = DoesLayerExist(RMLayer)
...but it said 'ByRef argument type mismatch'.....
Bob Wahr
« Reply #9 on: October 11, 2010, 02:25:41 PM »
Hi Eric,
I've tried various:
Try
RMblock.Layer = DoesLayerExist(RMLayer.name)
or
Private Function DoesLayerExist() As acadlayer
dim LayerName as string
                  Exit Function
            End If
      Next objLayer
End Function
'Insert block..
Sorry, that's about as much good as I'm going to be able to do without being able to play with it first hand.
Bryco
« Reply #10 on: October 11, 2010, 07:04:47 PM »
DoesLayerExist needs to return a string (Layername not the acadlayer itself)
hardwired
« Reply #11 on: October 13, 2010, 05:34:49 AM »
Hi Eric / Bryco,
I have tried both your suggestions but it just doesn't change the layer of the block..
Just so i have it right in my head, where do i put the function? I'm taking it that it goes before the sub of the main command button or procedure inserting the block, so it calculates the function first. I have it this way but i can't get it to work..
If i post my whole code below (i can't post the userform to go with it but i'm sure you guys can imagine it lol) - oh and excuse any crudeness of coding, i'm pretty much self-taught so any pointers on clean code would be greatly appreciated if you have time:
Option Explicit
Dim response As Integer  'Yes/No..
Dim BlockPoint As Variant 'First Insertion point..
Dim RMblock As AcadBlockReference 'Inserted Revision Marker block..
Dim AttribZ As Variant
Dim CountX As Integer 'Counter..
Dim RMlayer As AcadLayer
' FINISHED..
Private Sub FINISHEDbtn_Click()
Unload Me
End Sub
' HELP..
Private Sub HELPbtn_Click()
'Dim retval
'retval = Shell("C:\Program Files\Internet Explorer\IExplore.exe ""X:\CAD_Tools\Help\RM_help.html""", vbMaximizedFocus)
End Sub
Private Function DoesLayerExist() As AcadLayer
Dim LayerName As String
                  RMlayer = objLayer
                  MsgBox "Layer Does Exist: " & objLayer
                  Exit Function
            End If
      Next objLayer
      MsgBox "Layer Does Not Exist: " & objLayer
End Function
'******** INSERT MARKERS ***********
Private Sub AddMArkersBTN_Click()
revmarkform.Hide
' Check if input is present..
If revnumCOMBO.Text = "" Then
    MsgBox "Please enter or select the Revision Number..", vbExclamation, "Revision Markers.."
    Exit Sub
End If
If revdateTXT.Text = "" Then
    MsgBox "Please enter or select the revision date..", vbExclamation, "Revision Markers.."
    Exit Sub
End If
'Get pick point..
'Error Test for GetPoint method..
On Error Resume Next
TryAgain:
BlockPoint = ThisDrawing.Utility.GetPoint(, vbCr & "Pick the first insertion point for the Revision Marker..")
'Insert block..
    RMblock.Layer = DoesLayerExist(objLayer.Name)
AttribZ = RMblock.GetAttributes ' Get Block attributes..
For CountX = LBound(AttribZ) To UBound(AttribZ)
    Select Case AttribZ(CountX).TagString
    Case "REV_NUM_INDICATOR"
        AttribZ(CountX).TextString = UCase(revnumCOMBO.Text)
    Case "COMMENTS_DATE"
        AttribZ(CountX).TextString = revdateTXT.Text
    End Select
Next CountX
ErrHndlr:
    If Err.Number <> 0 Then
        If Err.Number = -2145320928 Then
            GoTo END_DO
        End If
        Err.Clear
        GoTo TryAgain
    End If
    On Error GoTo ErrHndlr
'** Start the point pick loop **
Do
CountX = CountX + 1  'Add 1 to the counter..
' Error Test for GetPoint method..
'On Error Resume Next
TryAgain2:
BlockPoint = ThisDrawing.Utility.GetPoint(, vbCr & "Pick the insertion point for the next Revision Marker..")
'Insert block..
    End Select
Next CountX
ErrHndlr2:
            GoTo END_DO
        End If
        Err.Clear
        GoTo TryAgain2
    End If
    'On Error GoTo ErrHndlr2
    On Error GoTo END_DO 'Exit the loop if ENTER or another key is hit (basically an error)..
Loop
'******** End the loop *********
END_DO:
revmarkform.Show
End Sub
Private Sub revdateTXT_DblClick(ByVal Cancel As MSForms.ReturnBoolean)
revdateTXT.Text = Format(Date, "DD/MM/YYYY")
End Sub
'*************** FORM LOAD ******************
Private Sub UserForm_Initialize()
ThisDrawing.ActiveSpace = acPaperSpace
With revnumCOMBO
    .AddItem ("P2")
    .AddItem ("P3")
    .AddItem ("P4")
    .AddItem ("P5")
    .AddItem ("P6")
    .AddItem ("P7")
    .AddItem ("P8")
    .AddItem ("P9")
    .AddItem ("P10")
    .AddItem ("C1")
    .AddItem ("C2")
    .AddItem ("C3")
    .AddItem ("C4")
    .AddItem ("C5")
    .AddItem ("C6")
    .AddItem ("C7")
    .AddItem ("C8")
    .AddItem ("C9")
    .AddItem ("C10")
    .AddItem ("AB")
End With
End Sub
'*************** FORM UNLOAD ****************
Private Sub UserForm_QueryClose(Cancel As Integer, closemode As Integer)
response = MsgBox("Are you sure you've finished with the 'Revision Markers'?..", vbQuestion + vbYesNo, "End the Program..")
    If response = vbNo Then
    Cancel = 1
    End If
    If response = vbYes Then
        Unload Me
    End If
End Sub
Bryco
« Reply #12 on: October 13, 2010, 08:32:36 AM »
Private Function DoesLayerExist() As string
this function must return the string layername
hardwired
« Reply #13 on: October 13, 2010, 09:06:23 AM »
Hi Bryco,
I tried that (changed no other code than the line you showed) but it came back saying the objLayer variable was not set, even though its set in the function. Any Ideas?
Bob Wahr
« Reply #14 on: October 13, 2010, 10:23:58 AM »
This is going off of some vague memory, so I'll let you decide it's worth or worthlessness but it might be worth trying.  If I remember right, makinjg the layer with VBA doesn't hurt anything if the layer already exists, so you might try eliminating the check function and just make the layer every time.  Barring that, you could do the check in your main sub instead of breaking it out into a function.
