Author Topic: Edit Att  (Read 5234 times)
A_LOTA_NOTA
Edit Att
« on: October 06, 2010, 01:24:19 PM »
How do you search for an attribute tag if you don't know what the name of the block is going to be?
Re: Edit Att
« Reply #1 on: October 06, 2010, 01:28:50 PM »
You either search the block definitions to see if they are have the attribute, then grab the inserts from there.  Or you search the drawing checking each insert.
deegeecees
Re: Edit Att
« Reply #2 on: October 06, 2010, 01:31:41 PM »
Here's how I've done it, but I'm sure there are better ways:
(setq att_tag1 (ssget "x" '((2 . "wutthenameoftheatttagis"))))
Re: Edit Att
« Reply #3 on: October 06, 2010, 01:50:26 PM »
This will only work with attribute definitions that have not been added to a block.  Plus it is not limited to attributes.
Re: Edit Att
« Reply #4 on: October 06, 2010, 02:04:10 PM »
Perhaps flick through the INSERTs?
(defun GetAttrib ( att / ss )
  (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
      (lambda ( i / a e n l )
        (while (and (not a) (setq e (ssname ss (setq i (1+ i)))))
          (if (not (member (setq n (cdr (assoc 2 (entget e)))) l))
            (progn (setq l (cons n l))
              (while
                (not
                  (eq "SEQEND"
                    (cdr
                      (assoc 0
                        (setq l
                          (entget
                            (setq e (entnext e))
                (if (eq att (cdr (assoc 2 (entget e)))) (setq a n))
        a
      -1
Returns block name, but could return whatever is needed really.
Guitar_Jones
Re: Edit Att
« Reply #5 on: October 06, 2010, 02:07:50 PM »
This will give you a vla list of attributes matching the tagname.
(defun GetTagList (tagname / Doc layout i atts tag str taglist)
(setq Doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
  (vlax-for layout (vla-get-layouts Doc)
    (vlax-for i (vla-get-block layout)
      (if (= (vla-get-objectname i) "AcDbBlockReference")
        (if (and
              (= (vla-get-hasattributes i) :vlax-true)
              (safearray-value
                (setq atts
                       (vlax-variant-value
                         (vla-getattributes i)
          (foreach tag (vlax-safearray->list atts)
            (if (= (strcase tagname) (strcase (vla-get-tagstring tag)))
     (setq taglist (append taglist (list tag)))
taglist
deegeecees
Re: Edit Att
« Reply #6 on: October 06, 2010, 03:01:03 PM »
I see... shoulda looked at my 10 year old code a bit closer. I used some convoluted means of grabbing known att values at some point.
A_LOTA_NOTA
Re: Edit Att
« Reply #7 on: October 06, 2010, 06:07:06 PM »
              (while
                (not
                  (eq "SEQEND"
                    (cdr
                      (assoc 0
                        (setq l
                          (entget
        a
      -1
How could this be changed so I could pass it the new value for the att also? It already does all the work of finding the tag it might as well update it also. I tried to do it but I get lost in the "lambda" maybe some comments would help so I better understand what it's doing.
Re: Edit Att
« Reply #8 on: October 06, 2010, 06:31:15 PM »
Bear in mind that the INSERT in which the tag is found will just be the first one that it comes across in the SelectionSet - this may not be consistent everytime.
Would you be looking to update the attribute value for every INSERT?
A_LOTA_NOTA
Re: Edit Att
« Reply #9 on: October 06, 2010, 06:33:06 PM »
Yes, every INSERT would be great.
Re: Edit Att
« Reply #10 on: October 06, 2010, 07:23:50 PM »
Something like this perhaps then:
(defun SetAttribValue ( Tag Value / ss )
      (lambda ( i / e l )
        (while (setq e (ssname ss (setq i (1+ i))))
          (while
            (not
              (eq "SEQEND"
                (cdr
                  (assoc 0
                    (setq l
                      (entget
            (if (eq Tag (cdr (assoc 2 l)))
              (entupd
                (cdr
                  (assoc -1
                    (entmod
                      (subst (cons 1 Value) (assoc 1 l) l)
        t
      -1
Re: Edit Att
« Reply #11 on: October 06, 2010, 07:32:57 PM »
I playing catch up,  :-)
;;  From Tag name return ename list
(defun ssGetAttr ( attTag / ss i ename lst)
      (setq i -1)
      (while (setq ename (ssname ss (setq i (1+ i))))
        (foreach att (vlax-invoke (vlax-ename->vla-object ename) "getattributes")
          (if (= (vla-get-tagstring att) attTag)
            (setq lst (cons ename lst))
  lst
Re: Edit Att
« Reply #12 on: October 06, 2010, 07:44:48 PM »
Mind you there is no error checking. 8-)
;;  Given a Tag name update the text value
(defun AttrUpdate ( attTag NewValue / ss i ename lst)
      (setq i -1)
              (vla-put-textstring att NewValue)
              (vla-update att)
              (vla-update (vlax-ename->vla-object ename))
  lst
mkweaver
Re: Edit Att
« Reply #13 on: October 06, 2010, 10:16:38 PM »
Here is my routine:
(defun UpdateAtt (tagstring newvalue / newvalue ss1 tagstring)
  (if (setq tagstring (strcase tagstring)
    ss1       (ssget "X" '((0 . "INSERT") (66 . 1)))
    (mapcar
      (function (lambda (att) (vla-put-textstring att newvalue)))
      (vl-remove-if-not
    (= tagstring (strcase (vla-get-tagstring att)))
(apply
  'append
  (mapcar (function
    (lambda (ent)
      (vlax-invoke (vlax-ename->vla-object ent) 'GetAttributes)
  (vl-remove-if-not
    (function (lambda (x) (= 'ENAME (type x))))
    (apply 'append (ssnamex ss1))
Re: Edit Att
« Reply #14 on: October 07, 2010, 11:48:05 AM »
I feel left out, so here is one of my first ideas.  To step through the block table getting blocks that have the attributes desired.  Works with an associated list of attribute tags.
(defun UpdateAttributes ( attList / Blk FndAttList Ent Data tempList )
    (while (setq Blk (tblnext "block" (not Blk)))
        (setq FndAttList nil)
        (setq Ent (cdr (assoc -2 Blk)))
        (while Ent
            (setq Data (entget Ent))
                (and
                    (= (cdr (assoc 0 Data)) "ATTDEF")
                    (setq tempList (assoc (cdr (assoc 2 Data)) attList))
                (setq FndAttList (cons tempList FndAttList))
            (setq Ent (entnext Ent))
        (if FndAttList
                (setq Blk (tblobjname "block" (cdr (assoc 2 Blk))))
                (setq Blk (entget (cdr (assoc 330 (entget Blk)))))
                (foreach i (cdr (member '(102 . "}") (reverse (cdr (member '(102 . "{BLKREFS") Blk)))))
                    (if (entget (setq Ent (cdr i)))
                        (while (/= (cdr (assoc 0 (setq Data (entget (setq Ent (entnext Ent)))))) "SEQEND")
                                (and
                                    (= (cdr (assoc 0 Data)) "ATTRIB")
                                    (setq tempList (assoc (cdr (assoc 2 Data)) FndAttList))
                                    (entmod (subst (cons 1 (cdr tempList)) (assoc 1 Data) Data))
                                    (entupd Ent)
Called like
(UpdateAttributes '(("DETAIL" . "5")("SHEET" . "A-205")))
