David is correct. You need to at least turn off the "suppress zero inches" option. If you set DIMZIN to 1 it will resolve the issue, but may cause other issues with dimensioning. If that is the case, you may want to set the value of DIMZIN in your macro, then reset it to its previous value when done.
