Author Topic: LispFunction SubList  (Read 6688 times)
Re: LispFunction SubList
« Reply #15 on: October 05, 2010, 11:13:34 AM »
Good idea; i just created a generic List class in C++. Very good practice for me. Thanx guys.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #16 on: October 05, 2010, 01:42:22 PM »
here is the resbuf version   :-o
tatic resbuf* cloneNode( const resbuf* pRb )
    if (pRb == NULL)
      return NULL;
    struct resbuf* pRbTmp = NULL;
    if(pRb->restype > 5000)
      if(pRb->restype == RTSTR)
        pRbTmp = acutNewRb(pRb->restype);
        if(pRbTmp)
          pRbTmp->resval.rstring = _tcsdup(pRb->resval.rstring);
        return pRbTmp;
      else
        if(pRbTmp)
          memcpy(&pRbTmp->resval,&pRb->resval, sizeof(pRbTmp->resval));
        return pRbTmp;
    return pRbTmp;
  //(SubList '(0 1 2 3 4 5) 2 3)
  static int ads_sublist(void)
    struct resbuf *pRbOutHead = NULL;
    struct resbuf *pRbOutTail = NULL;
    struct resbuf *pRbInHead = acedGetArgs();
    INT_PTR rtlb = 0;
    INT_PTR rtle = 0;
    INT_PTR startPos = 0;
    INT_PTR length = 0;
    INT_PTR listLength = 0;
    INT_PTR inIdx = 0;
    INT_PTR outIdx = 0;
    for(const struct resbuf *piter = pRbInHead; piter!=NULL; piter=piter->rbnext)
      if(piter->restype==RTLB)
        rtlb = inIdx;
      else if (piter->restype==RTLE)
        rtle = inIdx;
        if(piter->rbnext)
          if(piter->rbnext->restype == RTSHORT ||
             piter->rbnext->restype == RTLONG)
            startPos = piter->rbnext->resval.rlong;
        if(piter->rbnext->rbnext)
          if(piter->rbnext->rbnext->restype == RTSHORT ||
             piter->rbnext->rbnext->restype == RTLONG)
            length = piter->rbnext->rbnext->resval.rlong;
      inIdx++;
    if(inIdx<4)
      return (RSERR);
    if(length == 0 || length > (rtle-1 - startPos) || length > (rtle-1+rtlb+1))
      length = rtle-1 - startPos;
      if(outIdx == startPos+1)
        pRbOutTail= pRbOutHead = cloneNode(piter);
      if(outIdx > startPos+1 && length + startPos+1 > outIdx && outIdx < rtle)
        pRbOutTail = pRbOutTail->rbnext = cloneNode(piter);
      outIdx++;
    acedRetList(pRbOutHead);
    acutRelRb(pRbOutHead);
    return (RSRSLT) ;
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: October 06, 2010, 03:55:40 AM »
This one uses the same memory received from lisp
    struct resbuf *pRbTmp = NULL;
    INT_PTR rtlb = 0;
    INT_PTR rtle = 0;
    INT_PTR length = 0;
    INT_PTR inIdx = 0;
    INT_PTR outIdx = 0;
        rtlb = inIdx;
        rtle = inIdx;
        if(piter->rbnext)
      inIdx++;
    if(inIdx<4)
      return (RSERR);
    for(struct resbuf *piter = pRbInHead; piter!=NULL; piter=piter->rbnext)
        pRbOutTail= pRbOutHead = piter;
        pRbOutTail = pRbOutTail->rbnext = piter;
      outIdx++;
    if(pRbOutTail->rbnext)
      pRbTmp = pRbOutTail->rbnext;
      pRbOutTail->rbnext = NULL;
    pRbOutTail->rbnext =pRbTmp;
    return (RSRSLT) ;
