Author Topic: LispFunction SubList  (Read 6690 times)
« on: October 04, 2010, 04:42:57 AM »
a little fugly ... anyone want to try making it pretty and faster.
Competes well with Lisp for small returns from large lists.
Refer  : http://www.theswamp.org/index.php?topic=35125.0
-={ Challenge }=- SubStr for Lists
(SubList <list> <start> [<length>])
start is zero based
if length is nil, return remainder of list
(setq TestList '(1   2   3   4   5   6   7   8   9   10  11  12  13  14  15
                 16  17  18  19  20  21  22  23  24  25  26  27  28  29  30
      StartIndex 9
      ReturnCount 13
(NetSubList TestList StartIndex ReturnCount)
;;-> (10 11 12 13 14 15 16 17 18 19 20 21 22)
// CodeHimBelonga kdub 2010.10.04
using System;
[assembly: CommandClass(typeof(kdub_Testing.MyCommands))]
namespace kdub_Testing
    public class MyCommands
        [LispFunction("NetSubList")]
        public ResultBuffer MyLispFunction_SubList
            (ResultBuffer rbArgs)
            ResultBuffer rb1 = new ResultBuffer();
            TypedValue[] tvArray = rbArgs.AsArray();
            int arraylen = tvArray.Length;
            int listCount = arraylen - 4;
            TypedValue rCount = tvArray[arraylen - 1];
            int StartIndex = (short)tvArray[arraylen - 2].Value;
            int ItemsToReturn = (short)rCount.TypeCode == (short)LispDataType.Nil
                                ? (int)listCount
                                : (short)rCount.Value;
            int StopIndex = listCount < StartIndex + ItemsToReturn
                            ? listCount + 1
                            : StartIndex + ItemsToReturn + 1;
            rb1.Add(new TypedValue((int)LispDataType.ListBegin, null));
            for (int i = StartIndex + 1 ; i < StopIndex ; i++)
                rb1.Add(tvArray[i]);
            rb1.Add(new TypedValue((int)LispDataType.ListEnd, null));
            return rb1;
It's Alive!
  • Retired
  • AKA Daniel
Re: LispFunction SubList
« Reply #1 on: October 04, 2010, 05:16:53 AM »
It's a lot harder in C++/C# as you really should identify the list within the Resultbuffer rbArgs,  Then test for the second and third arguments,
otherwise issuing TestList '( 1 2 3 4 5 6 7 8 9)  would try to use  '9' and the ')' as the index and count. right?
« Reply #2 on: October 04, 2010, 05:22:27 AM »
There IS an expectation that the correct quantum of parameters will be used :-D
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: October 04, 2010, 05:24:50 AM »
You would think  :laugh:
kaefer
« Reply #4 on: October 04, 2010, 08:02:48 PM »
Dunno about thinking, the fun part will be just trying to make that bullet-proof.
What needs to be special-cased? The input buffer can be empty or may have any number of arguments; the input list can be NIL or may be a list with 2 or 3 numeric elements; numeric parameters can have 16 or 32 bits, anything else? And what is an appropriate error-handling, apart from returning NIL at every corner?
I would start by rewriting the spec, with start and stop (instead of length) position first and the input list at the end of the arguments.
So here's my take, with heavy use of F# patterns:
open Autodesk.AutoCAD.DatabaseServices
open Autodesk.AutoCAD.Geometry
open Autodesk.AutoCAD.Runtime
let rb a = new ResultBuffer(a)
let (|RB|) (rb: ResultBuffer) = rb.AsArray() |> List.ofArray
let tv v = new TypedValue(int v)
let (|TV|_|) k (tv: TypedValue) =
    if tv.TypeCode = int16 k then Some tv.Value else None
let nil = rb [| tv LispDataType.Nil |]
let lispList listData =
    [ [| tv LispDataType.ListBegin |]; listData; [| tv LispDataType.ListEnd |] ]
    |> Array.concat |> rb
let (|Int16|) = unbox<int16> >> int
let (|Int32|) = unbox<int32> >> int
let (|Array|) = Array.ofList >> fun a -> a.[0 .. a.Length - 2]
let tvf f = new TypedValue(int LispDataType.Double, f)
let (|Point2d|) o = let p = unbox<Point2d> o in [| tvf p.X; tvf p.Y |]
let (|Point3d|) o = let p = unbox<Point3d> o in [| tvf p.X; tvf p.Y; tvf p.Z |]
[<LispFunction "MyNetSubList">]
let MyLispFunction_SubList = function
    | null -> nil
    | RB (TV LispDataType.Int16 (Int16 start) :: xs)
    | RB (TV LispDataType.Int32 (Int32 start) :: xs) ->
        match xs with
        | TV LispDataType.Int16 (Int16 stop) :: ys
        | TV LispDataType.Int32 (Int32 stop) :: ys ->
            match ys with
            | TV LispDataType.Point2d (Point2d zs) :: _
            | TV LispDataType.Point3d (Point3d zs) :: _
            | TV LispDataType.ListBegin _ :: (Array zs) ->
                let res = zs.[max 0 start .. min stop (zs.Length - 1)]
                if Array.isEmpty res then nil else lispList res
            | _ -> nil
        | _ -> nil
    | _ -> nil
Regards, Thorsten
« Reply #5 on: October 04, 2010, 08:34:58 PM »
:-D
I wanted to do that, but considered that the 'client' had defined the spec'
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: October 04, 2010, 10:23:36 PM »
Kerry's right, the client wrote the spec ! Plus to do right, the optional argument need not be used as in substr  :evil:
« Reply #7 on: October 04, 2010, 11:15:42 PM »
now you're getting picky.
... but I'll argue with you.
The function needs to be able to replace any of the lisp routines written for the challenge { though some of them don't meet the spec either    :angel:}
The routine I wrote still has some issues,
pass nil as start 2nd param
pass negative number as 2nd or 2rd param
pass anything other than integer as 2nd or 2rd param
pass anything other than a list as the 1st parameter
Other than that and the fact it looks ugly and is slower than most of the alternatives it's pretty good   :-P
Glenn R
« Reply #8 on: October 05, 2010, 06:54:30 AM »
public ResultBuffer netSubListLispFunction(ResultBuffer args) // This method can have any name
    TypedValue[] tvArray = args.AsArray();
                        ? (int)listCount
    ArraySegment<TypedValue> seg = new ArraySegment<TypedValue>(tvArray, StartIndex + 1, ItemsToReturn);
    for (int i = seg.Offset; i < (seg.Offset + seg.Count); i++)
        rb1.Add(seg.Array[i]);
    return rb1;
Glenn R
« Reply #9 on: October 05, 2010, 07:14:25 AM »
...with some LINQage...
using System;
using System.Linq;
[assembly: CommandClass(typeof(KwbLispList.MyCommands))]
namespace KwbLispList
                                ? (int)listCount
            tvArray.Skip(++StartIndex).Take(ItemsToReturn).ForEach(rb1.Add);
            return rb1;
    public static class Foo
        public static void ForEach<T>(this IEnumerable<T> enumeration, Action<T> action)
            foreach (T item in enumeration)
                action(item);
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: October 05, 2010, 09:08:59 AM »
mine
  //(SubList '(0 1 2 3 4 5) 2 3)
    [LispFunction("sublist")]
    static public ResultBuffer sublist(ResultBuffer InBuff)
      try
        Int32 listBegin = 0;
        Int32 listEnd = 0;
        Int32 startPos = 0;
        Int32 length = 0;
        if (InBuff == null)
          return null;
        List<TypedValue> InList = new List<TypedValue>(InBuff.AsArray());
        for (Int32 idx = 0; idx < InList.Count; idx++)
          switch ((LispDataType)InList[idx].TypeCode)
            case LispDataType.ListBegin: listBegin = idx+1; break;
            case LispDataType.ListEnd: listEnd = idx; break;
        startPos = Convert.ToInt32(InList[listEnd + 1].Value);
        if (InList.Count > (listEnd + 2))
          length = Convert.ToInt32(InList[listEnd + 2].Value);
        else
          length = listEnd-startPos-1;
        if (listEnd - startPos <= length)
          throw new System.Exception("out of range");
        return new ResultBuffer(InList.GetRange(startPos+1, length).ToArray());
      catch (System.Exception ex)
        return null;
« Last Edit: October 05, 2010, 09:24:30 AM by __declspec »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: October 05, 2010, 09:31:17 AM »
still not dan proof (SubList '((0 1 2 3 4 5)) 0 3) outputs junk
(SubList '(0 1 2 3 4 5) "1" "3") works though   :laugh:
gile
  • Marseille, France
« Reply #12 on: October 05, 2010, 09:58:39 AM »
Here're my 2 cents:
_$ (gc-sublist '(0 1 2 3 4 5 6 7 8 9) 4 3)
(4 5 6)
_$ (gc-sublist '(0 1 2 3 4 5 6 7 8 9) 4 nil)
(4 5 6 7 8 9)
_$ (gc-sublist '(0 1 2 3 4 5 6 7 8 9) 4)
(4 5 6 7 8 9)
_$ (gc-sublist '(0 1 2 3 4 5 6 7 8 9) 4 32)
(4 5 6 7 8 9)
[LispFunction("gc-SubList")]
        public ResultBuffer MyLispFunction(ResultBuffer args)
            if (args == null)
                return null;
            try
                List<TypedValue> tValues = new List<TypedValue>(args.AsArray());
                int lstEnd = tValues.LastIndexOf(new TypedValue(5017, -1));
                int start = Convert.ToInt32(tValues[lstEnd + 1].Value) + 1;
                int length = lstEnd - start;
                if(tValues.Count == lstEnd + 3 && tValues[lstEnd + 2].TypeCode != (short)LispDataType.Nil)
                    length = Math.Min(Convert.ToInt32(tValues[lstEnd + 2].Value), length);
                return new ResultBuffer(tValues.GetRange(start, length).ToArray());
            catch(System.Exception ex)
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.Message);
                return null;
It's Alive!
  • Retired
  • AKA Daniel
« Reply #13 on: October 05, 2010, 10:28:59 AM »
gile
  • Marseille, France
« Reply #14 on: October 05, 2010, 10:49:47 AM »
Thanks Daniel.
Here's a safer one (only allows LISP INT type (short or int) as second and [optional] third arguments)
            if (args == null)
                return null;
            try
                int start = 1;
                switch (tValues[lstEnd + 1].TypeCode)
                    case (short)LispDataType.Int16:
                        start += (short)tValues[lstEnd + 1].Value;
                        break;
                    case (short)LispDataType.Int32:
                        start += (int)tValues[lstEnd + 1].Value;
                        break;
                    default:
                        return null;
                if (tValues.Count == lstEnd + 3 && tValues[lstEnd + 2].TypeCode != (short)LispDataType.Nil)
                    switch (tValues[lstEnd + 2].TypeCode)
                            length = Math.Min((short)tValues[lstEnd + 2].Value, length);
                            break;
                            length = Math.Min((int)tValues[lstEnd + 2].Value, length);
                            break;
                        default:
                            return null;
            catch
                return null;
