Author Topic: Which is more beautiful . . .  (Read 10912 times)
Re: Which is more beautiful . . .
« Reply #15 on: September 29, 2010, 03:40:31 PM »
(if (eq 1 (getvar "cvport"))
                        'PaperSpace
                        'ModelSpace
So that's how you do that!! I have some ancient code to update now. LOL
thanks MP, always nice to see how your mind works.
LE3
« Reply #16 on: September 29, 2010, 04:10:21 PM »
If there are more options.... then will go with the alias:
Command: L
And forget about any complex customization -  :-P
« Reply #17 on: September 29, 2010, 04:33:37 PM »
What Luis said ^^
Form follows function
so, for the quoted example  'L'  via the PGP file definitions.
Otherwise, in principle , C
or to keep John happy, A  :)
(added:kdub] we all realise that beauty is not necessarily related to functionality, yes ??
« Last Edit: September 29, 2010, 05:06:34 PM by Kerry »
« Reply #18 on: September 29, 2010, 04:59:11 PM »
*sigh* I choose method Q!
Someone asking question: What came first the Chicken or the Egg?
Some people here: The Camel because it can live longer in the desert.
*palm to face*
jbuzbee
« Reply #19 on: September 29, 2010, 09:09:01 PM »
Thanks for playing!
As some of you know I'm no longer in the AutoCAD, AutoLISP, coding game.  This was a physiological profiling exercise.  Thanks for the feedback!
jb
« Last Edit: September 30, 2010, 07:07:03 AM by jbuzbee »
James Buzbee
Windows 8
« Reply #20 on: September 30, 2010, 12:01:19 AM »
This was a physiological profiling excesses.
That's funny - I don't care who you are !!
Daniel J. Ellis
« Reply #21 on: September 30, 2010, 03:27:51 AM »
C is so much better than the others. A, makes me cringe, and B provided a WTHIT moment.
I've not heard of a WITHIT moment before.
dJE
dJE
« Reply #22 on: September 30, 2010, 07:42:00 AM »
what the hell is that ?
/guess
jbuzbee
« Reply #23 on: September 30, 2010, 10:17:58 AM »
Think about it:  I've noticed an intersting trend in message boards.  People are more free to respond due to the anonymity of the internet.  This site, which attracts very intelligent and technically advanced users, illustrates very different personality traits.  This thread alone clearly identifies conservatism, complexity, and creativity (option C!).
That's what makes this site and forum such a wonderful resource.  I hope it never changes . . ..
James Buzbee
Windows 8
« Reply #24 on: September 30, 2010, 10:21:16 AM »
X2  :-)
HasanCAD
« Reply #25 on: September 30, 2010, 02:37:44 PM »
C with a litle change
(defun c:addline (/ e p1 p2)
  (and (setq p1 (getpoint "\nSpecify first point:"))
       (setq p2 (getpoint p1 "\nSpecify next point:"))
  (entmakex (list
             (cons 0 "LINE")
             (cons 10 p1)
             (cons 11 p2)
pkohut
« Reply #26 on: September 30, 2010, 02:44:46 PM »
  (entmakex (list
             (cons 0 "LINE")
             (cons 10 p1)
             (cons 11 p2)
You broke it. Pick first point. Right click for second point. "entmakex" should not run, p2 is nil.
New tread (not retired) - public repo at https://github.com/pkohut
« Reply #27 on: September 30, 2010, 02:54:03 PM »
  (entmakex (list
             (cons 0 "LINE")
             (cons 10 p1)
             (cons 11 p2)
From a code perspective it would be good if the function returned something so you could do something with it after it's drawn  :-D:
(if (setq line (addline))
  (command "_move" line "" pause pause)
  (alert "oh noes!!")
Matt__W
  • I like my water diluted.
« Reply #29 on: September 30, 2010, 03:23:54 PM »
Alright... my turn!!
Option Explicit
Public Sub MainLine()
    Dim Point1 As Variant
    Dim Point2 As Variant
    Dim line As AcadLine
    If MyGetPoints(Point1, Point2) = 0 Then  'no CANCEL
        Set line = ThisDrawing.ModelSpace.AddLine(Point1, Point2)
    End If
End Sub
Private Function MyGetPoints(pt1 As Variant, pt2 As Variant) As Integer
    ' This sub returns two points, or an error flag if cancelled
    On Error Resume Next
    pt1 = ThisDrawing.Utility.getPoint(, "Specify first point:")
    If Err Then
        MyGetPoints = -1
        Exit Function
    End If
    pt2 = ThisDrawing.Utility.getPoint(pt1, "Specify second point:")
    If Err Then
        MyGetPoints = -1
        Exit Function
    End If
On Error GoTo 0
End Function
 :roll:
Autodesk Expert Elite
