Author Topic: Help: How to go through layer list?  (Read 4023 times)
HasanCAD
« on: September 27, 2010, 10:52:20 AM »
This lisp to create a line with layer color and ltype and text with layer name
But do not know how to go through the layer table.
(defun c:Layers ()
  (setq AcObj (vlax-get-Acad-Object))
  (setq ActDoc (vla-get-ActiveDocument AcObj))
  (vla-EndUndoMark ActDoc)
  (vla-StartUndoMark ActDoc)
  (setq Cntr -1)
  (setq Pnt0 (trans (getpoint "\nBase point")1 0))
  (while
    (setq LayerLst0 (tblsearch "LAYER"))
    (setq LayerLst1 (ssname LayerLst0 (setq Cntr (1+ Cntr))))
    (setq LayerLst2 (entget LayerLst1))
      (and
  (setq Pnt1 (list (+ (car pnt0) 500) (cadr pnt0) (caddr pnt0)))
  (setq Pnt2 (list (+ (car pnt0) 600) (cadr pnt0) (caddr pnt0)))
      (entmakex (list
  (cons 0 "LINE")
                  (cons 10 Pnt0)
                  (cons 11 Pnt1)
      (entmakex (list
  (cons 0 "TEXT")
                  (cons 10  Pnt2)
                  (cons 40 110)
                  (cons 1  (getvar "CLayer"))
      (setq Pnt0 (list (car pnt0) (+ (car pnt0) 150) (caddr pnt0)))
(princ "\n Type c:Layers to start ")
roy_043
  • BricsCAD 18
Re: Help: How to go through layer list?
« Reply #1 on: September 27, 2010, 11:14:31 AM »
alanjt
  • Standby for witty remark...
« Reply #2 on: September 27, 2010, 11:18:41 AM »
 (while (setq e (tblnext "LAYER" (null e)))
    (setq l (cons (cdr (assoc 2 e)) l))
Dropbox
kpblc
« Reply #3 on: September 27, 2010, 11:31:01 AM »
(defun get-all-layers (doc show / res name)
  ;; doc  -> vla-pointer to document to proceed. nil -> current
  ;; show -> show xref-layers (t) or nor (nil)
  (vlax-for item (vla-get-layers (cond
                                   ((and doc (= (type doc) 'vla-object)))
                                   (t (vla-get-activedocument (vlax-get-acad-object)))
                                   ) ;_ end of cond
                                 ) ;_ end of vla-get-layers
    (setq name (vla-get-name item))
    (if (or (not (wcmatch name "*|*"))
            (and (wcmatch name "*|*")
                 show
                 ) ;_ end of and
            ) ;_ end of or
      (setq res (cons name res))
      ) ;_ end of if
    ) ;_ end of vlax-for
  (vl-sort res '<)
  ) ;_ end of defun
Sorry for my English.
HasanCAD
« Reply #4 on: September 28, 2010, 04:50:40 AM »
This is final
LEE please DO NOT look at the header  ;)
;;-------------------=={ Layers List }==----------------;;
;;  Create a line & text for each layer and have        ;;
;;  layer properties and text string is layer name      ;;
;;  for each layer                                      ;;
;;  Author: Hasan M. Asous, 2010                        ;;
;;  Copyright © 2010 by HasanCAD, All Rights Reserved.  ;;
;;  Contact: HasanCAD @ TheSwamp.org,                   ;;
;;           asos2000 @ CADTutor.net                    ;;
;;  Version: 1 20100928                                 ;;
;;     o_l_ll  \_ll o_l l \_l ;;
(defun c:Layers (/ AcObj ActDoc
Cntr Pnt0
e l
Pnt1 Pnt2 LyrName LyrLType LyrClr)
  (setq Cntr -1)
  (command "_.-style" "LyrNameTxt" "romans.shx" 110 0.8 0 "n" "n" "n")
  (while
    (setq Lyr (tblnext "LAYER" (null Lyr)))
    (setq LyrName (cdr (assoc 2 Lyr)))
    (setq LyrLType (cdr (assoc 6 Lyr)))
    (setq LyrClr (cdr (assoc 62 Lyr)))
      (and
  (setq Pnt1 (list (+ (car pnt0) 4000) (cadr pnt0) (caddr pnt0)))
  (setq Pnt2 (list (+ (car pnt0) 4500) (cadr pnt0) (caddr pnt0)))
      (entmakex (list
  (cons 0 "LINE")
  (cons 6 LyrLType)
                  (cons 8 LyrName)
  (cons 10 Pnt0)
                  (cons 11 Pnt1)
  (cons 62  LyrClr)
      (entmakex (list
  (cons 0 "TEXT")
  (cons 1  LyrName)
  (cons 7  "LyrNameTxt")
  (cons 8  LyrName)
                  (cons 10  Pnt2)
                  (cons 40 110)
  (cons 41 0.8)
  (cons 62  LyrClr)
      (setq Pnt0 (list (car pnt0) (+ (cadr pnt0) -200) (caddr pnt0)))
HasanCAD
« Reply #5 on: September 28, 2010, 09:28:26 AM »
I tried to make text alignment but create all test in 0,0
(entmakex (list
      (cons 0  "TEXT")
      (cons 1  LyrName)
      (cons 8  LyrName)
      (cons 10 Pnt2)
              (cons 40 220)
      (cons 41 0.8)
      (cons 62 LyrClr)
      (cons 72 2)
      (cons 73 2)
And this Version using Subroutine
;|-------------------Layers List----------------------
                q_|_|| _\|| q_|| _\|
  for each layer
           HasanCAD@gmail.com
  Version: 1     20100928
  Version: 1.1   20100928 Using Subroutine
____________________________________________________|;
;     q_|_|| _\|| q_|| _\|     ;
;       Mainroutine Start      ;
Cntr Pnt0
e l
  (setq Cntr -1)
  (while
    (and
      (and
  (setq Pnt1 (list (+ (car pnt0) 8000) (cadr pnt0) (caddr pnt0)))
  (setq Pnt2 (list (+ (car pnt0) 8200) (+ (cadr pnt0) -110) (caddr pnt0)))
(LyrLnType LyrLType LyrName Pnt0 Pnt1 Pnt2 LyrClr)
(setq Pnt0 (list (car pnt0) (+ (cadr pnt0) -600) (caddr pnt0)))
;       Mainroutine End        ;
;       Subroutine Start       ;
(defun LyrLnType (LyrLType LyrName Pnt0 Pnt1 Pnt2 LyrClr / )
  (entmakex (list
      (cons 0  "LINE")
      (cons 6  LyrLType)
              (cons 8  LyrName)
      (cons 10 Pnt0)
              (cons 11 Pnt1)
      (cons 62 LyrClr)
  (entmakex (list
      (cons 0  "TEXT")
      (cons 1  LyrName)
      (cons 8  LyrName)
      (cons 10 Pnt2)
              (cons 40 220)
      (cons 41 0.8)
      (cons 62 LyrClr)
;        Subroutine End        ;
Krushert
  • FREE BEER Tomorrow!!
« Reply #6 on: September 28, 2010, 08:23:10 PM »
Very Cool!.
I would suggest two improvements.  One draw the line and text in alphabetical order and two draw their lines with their correct line type settings.
Otherwise two comments, very cool.
HasanCAD
« Reply #7 on: September 29, 2010, 01:58:22 AM »
Very Cool!.
First Thanks for your encouragement and comments
for first one I Want to do this, but dont know How  :-(
for second I am using the layer line type. Is it correct? or what?
« Reply #8 on: September 29, 2010, 08:56:00 AM »
Write out in plain words what your current program is doing (this is called: "Pseudo Code"). After you do that we can talk.
HasanCAD
« Reply #9 on: September 30, 2010, 03:57:43 AM »
I am answing MedOffBud improvements
For first improvement I want to arrange in alphabetical order but I dont know how.
For second improvement I didn't understand what he said, so I told him what I did.
Is it OK
Krushert
« Reply #10 on: September 30, 2010, 07:32:20 AM »
Is it OK
Sorry for the confusion on the second part. Your code is drawing a line on certain layer right?  I was wondering why line was drawn as continuous when a layer (like a center line) should be drawn also with center line line type?
What Se7en "is trying to say" [before he hurts himself :evil:] is write out your code descriptively (Just words no code) on a piece of paper.  I do mine with the classic "Step 1:  blah blah blah"  "Step 2:  blah blah blah"  and so on.
Is that a little clearer?
« Reply #11 on: September 30, 2010, 09:06:49 AM »
Sorry, but there goes the chance for help from me; not because of a misunderstanding but because of lack of trying to understand (Frankly, I didnt try to say anything, i said it. I said PSEUDO CODE and if that wasnt clear, then a google search would have helped).
http://lmgtfy.com/?q=pseudo+code
