Author Topic: Transfer MEP2010 toolbars to MEP 2009  (Read 4677 times)
hyposmurf
« on: September 26, 2010, 07:56:41 AM »
After discovering that Autodesk have done away with the toolbars in the later MEP versions Im hoping to set up my new toolbars at home ready to quickly transfer across into my work version.I have MEP 2010 at home and MEP 2009 at work, I dont intend to use any toolbars that arent available in MEP 2009, so do you think this will work OK?
What else will I need to cop across?Ill need my bitmaps ready to.
Im limited on time at work and hoping to get a chance to customise my set up before my working day starts.Its a bind not having time to set myself up at new work and trying to work at speed on a installation that I find unfamiliar to work on on.
Jeff H
Re: Transfer MEP2010 toolbars to MEP 2009
« Reply #1 on: September 26, 2010, 08:11:46 AM »
If you are talking about menu bar's which I think you are type MENUBAR and set it to 1
Then you set your menu bars in the CUI like you want and export them for use at work.
