Author Topic: .net paletteset versus CAdUiPaletteSet  (Read 6262 times)
jgr
« on: September 23, 2010, 08:04:32 PM »
Sorry, my current Questions  += 1
From objectarx:
Windows derived from CAdUiDockControlBar—which includes CAcUiDockControlBar, CAdUiPaletteSet, and CAcTcUiToolPaletteSet—can register themselves using the global function AdUiRegisterTool(). Registered windows that were visible when a session of AutoCAD closed will be automatically started in the next session and will be saved and restored in workspaces.
Command
 REG_SZ
 Command to invoke the window
I use a guid...commands...REG_SZ....  but does not work. The window does not start automatically at the next session.
Thanks.
Jeff H
Re: .net paletteset versus CAdUiPaletteSet
« Reply #1 on: September 23, 2010, 08:33:18 PM »
Not familiar with CAdUiPaletteSet
but this seems to work for me
If your app is demand loaded or when you NetLoad
jgrPS = new Autodesk.AutoCAD.Windows.PaletteSet("jgr Palette", new Guid("24971F58-9504-4495-AF96-44389B271506"));
I sure you know about the Create Guid on tool Menu thought I mentioned it though
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: September 23, 2010, 08:41:47 PM »
There are a few examples of this somewhere in this forum, have a quick search
jgr
« Reply #3 on: September 23, 2010, 08:42:41 PM »
thanks for replying.
Yes: my app is demand loaded on Start Up and i use:
new Guid(...
Next weekend will send the full code
Thank you very much.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: September 23, 2010, 08:47:52 PM »
jgr
« Reply #5 on: September 23, 2010, 08:50:53 PM »
Sorry. But before asking: I have searched.
jgr
« Reply #6 on: September 23, 2010, 08:54:46 PM »
Thanks, and sorry
always answer later. To write I need a translator
It's Alive!
  • Retired
  • AKA Daniel
« Reply #7 on: September 23, 2010, 08:54:55 PM »
did you catch this?
...Have you ever wondered how AutoCAD remembers
where PalletteSets were docked, the size and position they
had in the last session?
It stores that information in a file, which is located in:
C:\Documents and Settings\<YourLoginName>\Application Data\Autodesk\AutoCAD 200X\RXX.x\enu\Support\Profiles\FixedProfile.aws
Find the file, and make a copy of it, and change the
extension of the copy to .XML and open it in IE or
another XML viewer, and take a look.
You'll see that tools are keyed to the GUIDs you
supply to the PalleteSet's constructor. If you don't
supply a GUID the I'm pretty sure that AutoCAD will
not persist the state of your PaletteSet.
maybe have a look at this file and see it looks correct.
jgr
« Reply #8 on: September 23, 2010, 09:07:39 PM »
Thanks but my problem is not the size and position
According ObjectARX:
Registered windows that were visible when a session of AutoCAD closed will be automatically started in the next session.
And my window does not start in the folowing session.
Language is a big problem for me. Sorry, sorry...
LE3
« Reply #9 on: September 23, 2010, 09:33:26 PM »
Creo que hablas Español (If not sorry about that, got that impression) - pero tu Ingles esta muy bien, por eso no te preocupes, la mayoria te va a entender, de eso no tengas duda.
Saludos.
jgr
« Reply #10 on: September 23, 2010, 09:53:40 PM »
(Gracias LE, aunque creo que no es asi ... google trans... etc)
Yes, i (only) speak spanish.
I use CommandFlags.Modal In CommandMethod. It may be that the problem?
Thanks.
« Last Edit: September 23, 2010, 10:00:42 PM by jgr »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: September 23, 2010, 10:03:55 PM »
maybe can you use IExtensionApplication to launch your pallet instead of a command? You can also test the visible state as LE mentions
« Last Edit: September 23, 2010, 10:15:47 PM by __declspec »
LE3
« Reply #12 on: September 23, 2010, 10:08:35 PM »
No he usado las paletas en un buen rato, pero creo que es algo asi (que ya te habian explicado antes):
       private static PaletteSet myPaletteSet;
        [CommandMethod("YourPalette")]
        static public void cmd_palette()
            if (myPaletteSet == null)
                myPaletteSet = new PaletteSet("Mi Paleta", new Guid("BF783B3B-8523-4e65-A6D3-72FE202C30FD"));
                // coloca el codigo para la pestaña aqui
            myPaletteSet.Visible = true;
Thanks.
« Last Edit: September 23, 2010, 10:12:01 PM by LE »
jgr
« Reply #13 on: September 23, 2010, 10:19:21 PM »
Thank you all.
Tomorrow proves all your options. I need some sleep.
Thanks.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: September 23, 2010, 10:28:31 PM »
I need some sleep.
an all night coder   :-D
