Author Topic: Tell me why I did it like this. :)  (Read 19019 times)
Re: Tell me why I did it like this. :)
« Reply #15 on: September 23, 2010, 04:38:18 PM »
I didn't say it was a benefit. I was stating that I would never have thought to create the dotted pair list and redefine the command.
Sorry, poor wording on my part, I just didn't understand the motivation to go the vl-remove-et-al route. :)
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
« Reply #16 on: September 23, 2010, 04:42:21 PM »
I did it because there is
(1) no reason to recreate the list every time the function is called <i.e. evaluate / create the list once, then redefine the function with static data>
(2) not palatable to me to hard code third party enum values <ok to do mine tho>
(3) easy to revise the enum values if additional enum members are added down the road ... etc. :)
I understand those reasons.
I Think I'd have done something like this
(Defun Getalignment (Value)
  (Cdr (Assoc Value
              (List (cons acAlignmentLeft "Left")
                    (cons acAlignmentCenter "Center")
                    (cons acAlignmentRight "Right")
                    (cons acAlignmentAligned "Aligned")
                    (cons acAlignmentMiddle "Middle")
                    (cons acAlignmentFit "Fit")
                    (cons acAlignmentTopLeft "TopLeft")
                    (cons acAlignmentTopCenter "TopCenter")
                    (cons acAlignmentTopRight "TopRight")
                    (cons acAlignmentMiddleLeft "MiddleLeft")
                    (cons acAlignmentMiddleCenter "MiddleCenter")
                    (cons acAlignmentMiddleRight "MiddleRight")
                    (cons acAlignmentBottomLeft "BottomLeft")
                    (cons acAlignmentBottomCenter "BottomCenter")
                    (cons acAlignmentBottomRight "BottomRight")
« Reply #17 on: September 23, 2010, 04:43:36 PM »
A variation?
(defun-q GetAlignment ( value / lst )
  (setq lst
    (mapcar
     '(lambda ( enum ) (vl-list* (vl-symbol-value enum) (substr (vl-symbol-name enum) 12)))
     '(acAlignmentLeft
       acAlignmentCenter
       acAlignmentRight
       acAlignmentAligned
       acAlignmentMiddle
       acAlignmentFit
       acAlignmentTopLeft
       acAlignmentTopRight
  (setq GetAlignment
    (cons (car GetAlignment)
      (list
        (cons (quote cdr)
          (list
            (list (quote assoc) (quote value) (list (quote quote) lst))
  (cdr (assoc value lst))
(quote quote) lol :D
alanjt
  • Standby for witty remark...
« Reply #18 on: September 23, 2010, 04:47:19 PM »
Only because I felt it was faster than creating the dotted pair list, then assoc'ing out what was needed.
eg.
(defun foo2 (v)
  (cdr (assoc v
              (mapcar
                '(lambda (enum) (cons (eval enum) (substr (vl-symbol-name enum) 12)))
                '(acAlignmentLeft acAlignmentCenter acAlignmentRight acAlignmentAligned
                  acAlignmentMiddle acAlignmentFit acAlignmentTopLeft acAlignmentTopCenter
                  acAlignmentTopRight acAlignmentMiddleLeft acAlignmentMiddleCenter
                  acAlignmentMiddleRight acAlignmentBottomLeft acAlignmentBottomCenter
The brilliance is you constructing the dotted pair list and then redefining the routine to included the newly constructed list.
Consider me educated. Thank you.  :-)
Dropbox
« Reply #19 on: September 23, 2010, 04:48:41 PM »
Re: vl-remove-et-al approach:
Would (car (vl-member-if ... )) be quicker?
alanjt
« Reply #20 on: September 23, 2010, 04:52:08 PM »
Quite a bit. I didn't know that one.
(defun foo3 (v)
  (if (and (numberp v) (<= 0 (setq v (fix v)) 14))
              (car (vl-member-if
                     (function (lambda (e) (eq v (eval e))))
            12
    (FOO3 2).....1638 / 2.81 <fastest>
    (FOO 2)......4383 / 1.05
    (FOO2 2).....4602 / 1 <slowest>
MP's method is still the powerhouse.
Dropbox
« Reply #21 on: September 23, 2010, 04:58:22 PM »
Some more 'purely fun for thought':
(defun MakeEnumFunction ( name enums trimfrom / lst )
    (setq lst
        (mapcar
           '(lambda ( enum ) (cons (eval enum) (substr (vl-symbol-name enum) trimfrom)))
            enums
    (eval
        (cons 'defun
            (list name '( value )
                (cons 'cdr
                    (list
                        (list 'assoc 'value
                            (list 'quote lst)
(MakeEnumFunction
   'GetAlignment
   '(   acAlignmentLeft
        acAlignmentCenter
        acAlignmentRight
        acAlignmentAligned
        acAlignmentMiddle
        acAlignmentFit
        acAlignmentTopLeft
        acAlignmentTopRight
    12
(MakeEnumFunction
   'GetHorizontalAlignment
        acHorizontalAlignmentAligned
        acHorizontalAlignmentCenter
        acHorizontalAlignmentFit
        acHorizontalAlignmentLeft
    22
(MakeEnumFunction
   'GetVerticalAlignment
        acVerticalAlignmentBaseline
        acVerticalAlignmentBottom
        acVerticalAlignmentMiddle
        acVerticalAlignmentTop
    20
(GetAlignment 0) >> "Left"
(GetHorizontalAlignment 1) >> "Center"
(GetVerticalAlignment 2) >> "Middle"
:whistle:
alanjt
« Reply #22 on: September 23, 2010, 05:01:52 PM »
Most impressive.
Dropbox
« Reply #23 on: September 23, 2010, 05:06:56 PM »
For you guys that find this remotely interesting and are into python you might consider reading about functors and closures. :) PS: Thanks Alan/all.
« Reply #24 on: September 23, 2010, 06:03:02 PM »
:whistle:
The bonus of the ac.. enumerators being consistantly named ...
Now it's getting interesting !!
Great concept post Michael.
« Reply #25 on: September 24, 2010, 10:33:18 AM »
*Gack*
Turns out the TextGenerationFlags are not consistently named because they are the partial union of two enums:
        acTextFlagBackward
        acTextFlagUpsideDown
        acHorizontalAlignmentMiddle
        acHorizontalAlignmentRight
So it would be better to return the full enum member string rather than truncated ones, i.e. "acHorizontalAlignmentMiddle" instead of "Middle". Which I can live with. So, code revised --
(defun MakeEnumFunction ( name enums / lst )
    (setq lst
        (mapcar
           '(lambda ( enum ) (cons (eval enum) (vl-symbol-name enum)))
            enums
    (eval
        (cons 'defun
                (cons 'cdr
                    (list
                        (list 'assoc 'value
                            (list 'quote lst)
(MakeEnumFunction
   'GetAlignment
   '(   acAlignmentLeft
        acAlignmentCenter
        acAlignmentRight
        acAlignmentAligned
        acAlignmentMiddle
        acAlignmentFit
        acAlignmentTopLeft
        acAlignmentTopRight
(MakeEnumFunction
(MakeEnumFunction
(MakeEnumFunction
   'GetTextGenerationFlag
        acTextFlagBackward
(GetAlignment 0) >> "acAlignmentLeft"
(GetHorizontalAlignment 1) >> "acHorizontalAlignmentCenter"
(GetVerticalAlignment 2) >> "acVerticalAlignmentMiddle"
(GetTextGenerationFlag 4) >> "acTextFlagUpsideDown"
Thank you Kerry.
Maverickฎ
« Reply #26 on: September 24, 2010, 10:40:21 AM »
Sometimes I feel smarter just "hanging around" you guys.
Usually I just feel dumberer.
Carry on.  :-D
« Reply #27 on: September 24, 2010, 10:49:52 AM »
Here's a general StripEnumPrefix function one can use after the fact ...
(defun StripEnumPrefix ( enum / result )
    (vl-some
       '(lambda ( pair )
            (if (wcmatch enum (car pair))
                (setq result (substr enum (cdr pair)))
       '(   ("acAlignment*" . 12)
            ("acHorizontalAlignment*" . 22)
            ("acVerticalAlignment*" . 20)
            ("acTextFlag*" . 11)
            [color=green];; add additional filters to suit ...[/color]
    (if result result enum)
(StripEnumPrefix "acTextFlagBackward") >> "Backward"
(StripEnumPrefix "acHorizontalAlignmentMiddle") >> "Middle"
(StripEnumPrefix "acVerticalAlignmentBottom") >> "Bottom"
Kerry(Mav) you be funny. :D
« Last Edit: September 24, 2010, 10:55:35 AM by MP »
« Reply #28 on: September 24, 2010, 03:37:08 PM »
Perhaps for a touch grammatical house-keeping  :wink:
(defun _SplitbyCaps ( s / _f )
  (defun _f ( s )
    (if (wcmatch s "*[A-Z]*")
      (strcat (if (< 64 (ascii s) 91) " " "") (substr s 1 1) (_f (substr s 2)))
      s
  (strcat (substr s 1 1) (_f (substr s 2)))
(_SplitByCaps "MiddleCenter")
"Middle Center"
Yeah I was bored.   :-D
« Reply #29 on: September 24, 2010, 05:10:25 PM »
Lee,
This would be a far faster method (NOTE: I reformatted this function in the VLIDE for Kerry :D ).
(defun SplitbyCaps (mstr / imstr)
  (setq imstr (vl-string->list mstr))
  (apply
    (function strcat)
    (cons
      (chr (car imstr))
      (mapcar
    '(lambda (x)
       (if (< 64 x 91)
         (strcat " " (chr x))
         (chr x)
    (cdr imstr)
Benchmarking ...........Elapsed milliseconds / relative speed for 256 iteration(s):
    (SPLITBYCAPS SUPERLONGSTRING).......1670 / 54.24 <fastest>
    (_SPLITBYCAPS SUPERLONGSTRING).....90574 / 1.00 <slowest>
Tested on a string:
_$ (strlen superlongstring)
6176
_$
I will need time to read and re-read this thread but my initial impression is: "a code {re}generator". would that be correct?
EDIT: Added Benchmark test.
« Last Edit: September 24, 2010, 05:16:16 PM by Se7en »
