Author Topic: Tell me why I did it like this. :)  (Read 19014 times)
« on: September 23, 2010, 03:34:46 PM »
(defun GetAlignment ( value / lst )
    (setq lst
        (mapcar
           '(lambda ( enum ) (cons (eval enum) (substr (vl-symbol-name enum) 12)))
           '(   acAlignmentLeft
                acAlignmentCenter
                acAlignmentRight
                acAlignmentAligned
                acAlignmentMiddle
                acAlignmentFit
                acAlignmentTopLeft
                acAlignmentTopCenter
                acAlignmentTopRight
                acAlignmentMiddleLeft
                acAlignmentMiddleCenter
                acAlignmentMiddleRight
                acAlignmentBottomLeft
                acAlignmentBottomCenter
                acAlignmentBottomRight
    (eval
        (cons 'defun
            (list 'GetAlignment '( value )
                (cons 'cdr
                    (list
                        (list 'assoc 'value
                            (list 'quote lst)
    (cdr (assoc value lst))
(GetAlignment 1)
>> "Center"
Later. :)
Re: Tell me why I did it like this. :)
« Reply #1 on: September 23, 2010, 03:44:57 PM »
I can only think of obfuscation,
You didn't want strings in the compiled code.
« Last Edit: September 23, 2010, 03:49:13 PM by Kerry »
« Reply #2 on: September 23, 2010, 03:47:00 PM »
Nice performance enhancement after first call - similar to your recursive double-defun trick with the vl-remove-if...
Perhaps might improve readability to use defun-q  ?
« Reply #3 on: September 23, 2010, 03:53:39 PM »
Lee, if it was for performance I think just building the associative list in the initial definition would be better.
I've changed my vote.
It's to encourage posts of more than 4 characters long :)
LE3
« Reply #4 on: September 23, 2010, 03:54:31 PM »
No se (means I do not know)
Have a look at this:
_$ (GetAlignment 0)
"LEFT"
_$ (GetAlignment -0)
"LEFT"
_$ (GetAlignment -00)
"LEFT"
_$ (GetAlignment -000000000000)
"LEFT"
« Reply #5 on: September 23, 2010, 04:17:22 PM »
Ok, I change my reason: because you can. Next question.  :-D
alanjt
  • Standby for witty remark...
« Reply #6 on: September 23, 2010, 04:17:51 PM »
After the first execution, the routine is rewritten with the dotted pair already constructed. From there, assoc from a list is a lot faster than stepping through it with vl-remove-if-not. Am I close?
Seems really clever, I would have just done it this way...
(defun foo (v)
  (if (and (numberp v) (<= 0 (setq v (fix v)) 14))
              (car (vl-remove-if-not
                     (function (lambda (e) (eq v (eval e))))
                     '(acAlignmentLeft acAlignmentCenter acAlignmentRight acAlignmentAligned
                       acAlignmentMiddle acAlignmentFit acAlignmentTopLeft acAlignmentTopCenter
                       acAlignmentTopRight acAlignmentMiddleLeft acAlignmentMiddleCenter
                       acAlignmentMiddleRight acAlignmentBottomLeft acAlignmentBottomCenter
            12
... but I'm dumb.
Cool stuff, gives me a lot to think about.
« Last Edit: September 23, 2010, 04:22:18 PM by alanjt »
Dropbox
« Reply #7 on: September 23, 2010, 04:20:58 PM »
_$ (GetAlignment 0)
"LEFT"
"LEFT"
"LEFT"
"LEFT"
ZOMG, look at this:
(zerop 0) >> T
(zerop -0) >> T
(zerop -00) >> T
(zerop -000) >> T
What does it mean??  :-o
It means the argument is normalized to 0 (what the heck is a negative zero) when the function call is unpacked, i.e. before it gets to the body of the function, but that's merely a guess.
« Reply #8 on: September 23, 2010, 04:24:44 PM »
 I did it because there is (1) no reason to recreate the list every time the function is called <i.e. evaluate / create the list once, then redefine the function with static data> (2) not palatable to me to hard code third party enum values <ok to do mine tho> (3) easy to revise the enum values if additional enum members are added down the road ... etc. :)
« Reply #9 on: September 23, 2010, 04:25:00 PM »
_$ (GetAlignment 0)
"LEFT"
"LEFT"
"LEFT"
"LEFT"
ZOMG, look at this:
(zerop 0) >> T
(zerop -0) >> T
(zerop -00) >> T
(zerop -000) >> T
lol spooky stuff  :lol:
JCTER
« Reply #10 on: September 23, 2010, 04:28:42 PM »
Nope
« Reply #11 on: September 23, 2010, 04:32:27 PM »
Truly neither -- I actually tried to pen it so it would be easy for people to see what I did. I fail.
« Reply #12 on: September 23, 2010, 04:33:49 PM »
I don't understand the benefit of that approach, but I am open to enlightenment. :)
alanjt
« Reply #13 on: September 23, 2010, 04:34:04 PM »
I fail.
I wouldn't say that.
Dropbox
alanjt
« Reply #14 on: September 23, 2010, 04:34:50 PM »
I didn't say it was a benefit. I was stating that I would never have thought to create the dotted pair list and redefine the command.
Dropbox
